    RepRapFirmware 3.0
    176
    30.6k
      dc42 administrators @t9
      @t9 said in RepRapFirmware 3.0:
      I am testing the newly added function M581.
      How would you ignore output, in Reprap 2.03 this was done with S-1, but there is no S parameter available.
      Thanks
      Use M280 M581 Tn P"nil" to select no input ports.
      t9undefined 1 Reply Last reply Reply Quote 0
      • t9undefined
        t9 @dc42
        Thanks, I found that M581 Tn P"nil" works. Im not sure if that's what you meant, rather than M280
          Latest RRF3 builds are now at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
          • moosiundefined
            moosi
            I´m just playing around with the new version.
            One thing I stmbled across is M558
            How do I set up a second probe?
            I tried:
            M558 K1 P5 C"!e0stop" H5 F120 T300
            M585 Z100 F600 P1 S0
            but I get the error:
            "M558 invalid z probe index"
            I can change K1 and P1 to 0 and it works, so there might be a problem with additional probes?
            thanks
            Moosi
              dc42 administrators @moosi
              @moosi said in RepRapFirmware 3.0:
              I tried:
              You are right, it wasn't working. Try the new binary that I've just put at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
              moosiundefined 1 Reply Last reply Reply Quote 0
              • moosiundefined
                moosi @dc42
                Thanks, that was fast 😄
                It is working now. Not exactly as expected, but I think it is my fault and I need to dive deeper into the configs.
                • Cavemanundefined
                  Caveman
                  How to setup probe on anycubic linear plus? In 2.xx probe worked fine. In 3.xx Probe is not even registered when connected.
                  Am I missing something?
                    A Former User
                    which board and which probe?
                    @caveman said in RepRapFirmware 3.0:
                    • Cavemanundefined
                      Caveman
                      duet meastro and original probe
                        A Former User
                        Maestro was discussed mid may if you scroll up, not familar with what probe is original for anycubic, but hopefully the pin definition earlier in this thread will help.
                        • Cavemanundefined
                          Caveman @dc42
                          @dc42 So what does have to change if z probe is connected to endstop before?
                            dc42 administrators @Caveman
                            Use the C parameter ni the m558 command to specify that endstop pin. See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M558.
                            • clearlynotstefundefined
                              clearlynotstef
                              Ok, I've updated to 3.0 to run my weird cnc contraption. I'm a bit stuck on how to set it up. I have two Y motors and endstops, z, x and e (which is actually a tangential cutter but rotates based on E moves). I have Y hooked up to the Z driver and mapped as M584 Y0 Z1 X2 E3. Does this make sense given I have two endstops and motors on that axis? Should I be defining the second y motor as its own axis to use an second endstop? What should my M574 look like?
                              As always, appreciate any help!
                                A Former User @clearlynotstef
                                @clearlynotstef said in RepRapFirmware 3.0:
                                Seems off me? "Z driver" should be driver number 2, so you should probably have Y2 in there. Are you connecting both motors to the same driver output? If not you need something like Y2:1 or Y2 U1 (if the two Y motors are connected to the Y and Z drivers which ar drivers 1 and 2 respectively) ... or so i think at least.
                                If you clarify that bit I'm sure someone can help you with the M574
                                clearlynotstefundefined 1 Reply Last reply Reply Quote 0
                                  clearlynotstef @A Former User
                                  @bearer that's what I guess I'm trying to figure out. I currently have both Y motors hooked up to driver 0 (typically used for Z) so I can drive them off of the same driver without merging cables. This means I can't drive one without driving the other, which I guess means the best case scenario with two end stops is smashing one side into the endstop until the other catches up and hits the other endstop. Given I have an extra driver still, maybe I should drive each y motor off its own driver with it's own endstop, but still define both drivers as being the y axis? Not sure how to define the motors and end stops in either scenario on 3.0!
                                    Which board are you using?
                                      @bearer duet 2 Wi-Fi
                                        A Former User
                                        Then maybe you should wait for someone else to tell you that driver 0 is not the one labeled for Z as you seem to ignore me telling you that ... because you're not going to have much success until you do.
                                          @bearer... I'm not disagreeing with you, I thought you were proposing a different way of achieving this setup, not trying to correct the way I currently have it setup, it wasn't particularly clear. "Should be driver 2" sounds like a suggestion, not a fact. One would think the drivers would be numbered sequentially from one side of the board to the other.
                                            dc42 administrators @clearlynotstef
                                            You would think that; but they are not. The order is 2 1 0 3 4.
