What is command for turning off wifi?
1.7k
    Arkadiusz
    I'm using Cncjs and I constantly get message about failed connection and wifi being idle. How can I turn it off?
    Cheers
      Arkadiusz
      I know that command M552 S0 works for turning on wifi so I tried M552 S1 but it doesn't work.
        PaulHew
        M552 S0 turns off the WiFi for a Duet, is that what you are trying to achieve?
        Or M552 S-1 disables the WiFi module, according to this; https://duet3d.dozuki.com/Wiki/Gcode#Section_M552_Set_IP_address_enable_disable_network_interface
        HTH Paul.
          M552 S-1 resets the WiFi module (it stays reset until you send another M552 command)
          M552 S0 puts the wifi module in idle mode
          M552 S1 tries to connect to one of the known networks (use M587 to set them up)
          M552 S2 runs as an access point (use M589 to set up the AP parameters)
          Are you running DuetWiFiServer version 1.23?
            Arkadiusz
            Thanks, both answers worked for me M552 S-1 it was.
            I'm not sure which is my duetwifiserver version:
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1<LF>ok<LF>
              To check the DuetWiFServer version, turn the WiFi module on (idle mode will do), send M122 and look at the WiFi section of the report. If using USB/YAT then change the line terminator in YAT to LF only.
              undefined 1 Reply Last reply 16 Jul 2019, 15:13 Reply Quote 0
                A Former User
                Its covered in the wiki
                (too late, never mind, post got flagged for spam and when it went through there were more replies..)
                undefined 1 Reply Last reply 16 Jul 2019, 15:17 Reply Quote 1
                  Arkadiusz @dc42
                  @dc42 I tried your method but I'm still not sure what duetwifiserver version I'm running:
                  === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-917DA-G4MS8-6J9D6-3S46N-9TT7B<LF>Used output buffers: 1 of 20 (4 max)<LF>=== RTOS ===<LF>Static ram: 25524<LF>Dynamic ram: 98424 of which 0 recycled<LF>Exception stack ram used: 320<LF>Never used ram: 6804<LF>Tasks: NETWORK(ready,1260) HEAT(blocked,1232) MAIN(running,3844) IDLE(ready,200)<LF>Owned mutexes:<LF>=== Platform ===<LF>
                  I managed to put wifi into idle, but I have to do it every time I start machine otherwise I'm constantly getting annoying message "wifi reported error"
                  How can I disable wifi completely ?
                    Arkadiusz @A Former User
                    @bearer
                    Section in link you provided is misleading, it says that S0 will disable wifi where it only puts wifi into idle:
                    Parameters for Duet 2 Ethernet and 06/085
                    Pnnn IP address, 0.0.0.0 means acquire an IP address using DHCP
                    Snnn 0 = disable networking, 1 = enable networking
                    Rnnn (optional, RepRapFirmware 1.17 and earlier only) HTTP port, default 80
                    I don't know what you mean with post being flagged.
                      A Former User
                      @arkadiusz said in What is command for turning off wifi?:
                      Not really, if you read the section pertaining to the wifi board you'll see S-1 disables it.
                      Forum initially didn't allow the reply because it thought it was spam, so I tried again later and did't see it had been answered already.
                        Arkadiusz
                        You're right, I copied wrong section, I tried S-1 as suggested before but it only works at the beginning after executing command.
                        When duet is rebooted it goes back to idle and keep searching for wifi.
                        undefined 1 Reply Last reply 16 Jul 2019, 17:35 Reply Quote 0
                          A Former User
                          try adding the disable command to your config.g file? (at least it will run the disable command automatically on boot).
                            Phaedrux Moderator @Arkadiusz
                            You need to edit config.g. There is probably M552 S1 in there already to start wifi at bootup. Either remove it, or change it to M552 S-1
                              Arkadiusz
                              Thanks for help everyone, I'm still beginner here and I appreciate all help provided.
                              Like bearer and Phaedrux said I had to modify config.g.
                              2 out of 14
