    G28 Z Error: M280: Invalid servo index 3 in M280 command
    523
    • 57buickundefined
      57buick
      I just installed a Piezo Orion board so the nozzle is the probe. It reacts when I touch the tip, the light changes but I obviously have something wrong in my firmware settings I cant figure out. Getting the error
      G28 Z
      When I try to home Z, what am I missing?
      It is plugged into the Z endstop connection power, ground, signal
      My bed.g file
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v2 on Mon May 20 2019 16:31:14 GMT-0700 (Pacific Daylight Time)
      G29 ; probe the bed and enable compensation
      My config file
      M667 S1 ; Select CoreXY mode
      M550 P"DaveHevo" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Physical drive 0 goes forwards
      M569 P1 S0 ; Physical drive 1 goes forwards
      M569 P2 S0 ; Physical drive 2 goes backwards
      M569 P3 S0 ; Physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z400.00 E420.00 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; Set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z20.00 E10000.00 ; Set accelerations (mm/s^2)
      M906 X1000.00 Y1000.00 Z1200.00 E800.00 I50 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X568 Y498 Z700 S0 ; Set axis maxima
      M574 X1 Y2 S0 ; Set active low endstops
      M574 Z1 S2 ; Set endstops controlled by probe
      M558 P1 I1 R0.4 F300 X0 Y0 Z1 ;analogue mode,NC, delay, speed, not used as axis endstop
      G31 P600 X0 Y0 Z-.2 ; Set Z probe trigger value, offset and trigger height
      M557 X10:5 Y15:195 S20 ; Define mesh grid
      M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P1 D0 H1 ; Define tool 1
      G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
        A Former User
        post your homeall, homez and deploy/retract files? Suspect its trying to deploy a probe for some reason?
        • 57buickundefined
          57buick
          the firmware was originally setup for a bltouch but I thought I changed everything but apparently not. Here is my homeall.g
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v2 on Mon May 20 2019 16:31:15 GMT-0700 (Pacific Daylight Time)
          G91 ; relative positioning
          G1 S1 X-505 Y-505 F8000 ; move quickly to X or Y endstop and stop there (first pass)
          G1 S1 X-505 ; home X axis
          G1 S1 Y-505 ; home Y axis
          G1 S1 X-505 F360 ; move slowly to X axis endstop once more (second pass)
          G1 S1 Y-505 ; then move slowly to Y axis endstop
          G90 ; absolute positioning
          G1 X10 Y15 F6000 ; go to first bed probe point and home Z
          ;G91 ; relative positioning
          ;G1 S2 Z5 F100 ; lift Z relative to current position
          ;G90 ; absolute positioning
          and my homez.g
          ; homez.g
          ; called to home the Z axis
          G1 X250 Y250 F6000 ; go to first probe point
            A Former User
            maybe there is something in your config override file?
            • 57buickundefined
              57buick
              i dont have an overide file
              • 57buickundefined
                57buick
                Ok I figured out I just needed to delete the deploy and retract macros from when I had the bltouch hooked up and that got rid of the error.
                Now im just trying to figure out why the piezo does not stop the bed when homing Z now. The sensors led changes when i touch the tip but the duet doesnt respond, the bed keeps moving
                  Phaedrux Moderator @57buick
                  @57buick said in G28 Z Error: M280: Invalid servo index 3 in M280 command:
                  M558 P1 I1
                  Is P1 correct for the piezo? I thought they used P8 for digital input.
                  Double check wiring. Are the crimps good? Are they going to the right places?
                  • 57buickundefined
                    57buick
                    its my understanding you can use P1, P5, or P8 they all should work with a little different filtering?
                      I suggest you use P8 for a piezo.
