Ender 3 Pro RepRap config.g
1.5k
    keith @dc42
    Had a couple of issues with that links configuration. The Bed heater is now working but the hotend is still reading 2000.
    undefined 1 Reply Last reply 16 Jul 2019, 08:01 Reply Quote 0
      dc42 administrators @keith
      @keith said in Ender 3 Pro RepRap config.g:
      Please tell us what the issues were (so that we can improve that wiki page), and post your config.g file as it now is.
      undefined 1 Reply Last reply 16 Jul 2019, 08:07 Reply Quote 0
        keith @dc42
        The x motor homed to the right instead of the left.
        The z motor homed up instead of down.
        I switched those from S1 or S0 to S0 or S1 in the config.g
        Can't figure out why the hotend is still reading 2000c.
        I have a Micro-Swiss hotend and Bondtech extruder setup in direct drive configuration, with a BLTouch.
        M569 P0 S0 ; Physical drive 0 goes forwards
        M569 P1 S1 ; Physical drive 1 goes forwards
        M569 P2 S1 ; Physical drive 2 goes forwards
        M569 P3 S0 ; Physical drive 3 goes backwards
        M350 E16 I0 ; Configure microstepping without interpolation
        M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
        M92 X80.00 Y80.00 Z400.00 E415.00 ; Set steps per mm
        M566 X600.00 Y600.00 Z60.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
        M203 X9000.00 Y9000.00 Z600.00 E6000.00 ; Set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z120.00 E5000.00 ; Set accelerations (mm/s^2)
        M906 X800.00 Y800.00 Z800.00 E500.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X235 Y235 Z260 S0 ; Set axis maxima
        M574 X1 Y1 S1 ; Set active high endstops
        M574 Z1 S2 ; Set endstops controlled by probe
        M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
        M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
        G31 P500 X-28 Y10 Z0.6 ; Set Z probe trigger value, offset and trigger height
        M557 X10:220 Y10:220 S20 ; Define mesh grid
        M305 P0 T98801 B4185 R4700 ; Set thermistor + ADC parameters for heater 0
        M305 P1 T98801 B4185 R4700 ; Set thermistor + ADC parameters for heater 1
        M106 P0 S0 I0 F20 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S1 I0 F20 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P2 S1 I0 F20 H1:0 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M563 P0 D0 H1 ; Define tool 0
        ; Automatic power saving
        M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
        ; Custom settings
        M918 P1 E4 ; Enable 12864 LCD with 1 menu item per encoder click
        M501 ; Load saved parameters from non-volatile memory
        T0 ; Select first tool
          Check that you have the hot end thermistor plugged into the correct connector, the E0_THERM connector. See https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_Wiring_Diagram. If it's definitely in the right connector, it's probably a bad crimp connection or a break in the thermistor cable. You can temporarily plug the bed thermistor wire into E0_THERM to check that the thermistor port is working.
          undefined 1 Reply Last reply 16 Jul 2019, 08:33 Reply Quote 0
            keith @dc42
            . Ok, had a bad crimp. The hotend temp is now working. I have a Duet2Wifi those instructions are for a Maestro, are they the same config wise?
            undefined 1 Reply Last reply 16 Jul 2019, 08:40 Reply Quote 0
              They are almost the same, except for the R value in the M305 command, if you have one. R4700 is correct for the Duet WiFi.
                keith
                Now I just need to get the BLTouch working properly. It seems to home ok, but the BLTouch alarm comes on every time I home, and the M280 P0 S160 Alarm release isn't working.
                undefined 1 Reply Last reply 16 Jul 2019, 08:47 Reply Quote 0
                  M280 P0 S160
                  That implies that you have the BLTouch connected to the Heater 0 output, which isn't right. Use the same P value in that command that you do in the deployprobe.g and retractprobe.g commands (usually P3 or P7).
                  I am not an expert on BLTouch, but I think it may help to add parameter R0.2 to your M558 command in config.g.
                  undefined 1 Reply Last reply 16 Jul 2019, 08:53 Reply Quote 0
                    keith @dc42
                    None of that worked.
                    ; retractprobe.g
                    ; called to retract a physical Z probe
                    ; generated by RepRapFirmware Configuration Tool v2 on Tue Jul 16 2019 01:25:02 GMT-0600 (Mountain Daylight Time)
                    M280 P3 S90 I1
                      Are saying that M280 P3 S160 doesn't reset the BLTouch error?
                      Do M401 and M402 commands work (they should deploy and retract the probe)?
                      Please post your homeall.g and homez.g files.
                      undefined 1 Reply Last reply 16 Jul 2019, 09:17 Reply Quote 0
                        keith @dc42
                        M280 P3 S160 does not reset the BLTouch error.
                        M401 works M402 retracts but the alarm comes on.
                        ; homeall.g
                        ; called to home all axes
                        G91 ; relative positioning
                        G1 S1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 S1 X-240 Y-240 F360 ; move slowly to X and Y axis endstops once more (second pass)
                        G90 ; absolute positioning
                        G1 X38 Y20 F6000 ; go to first bed probe point and home Z
                        ;G91 ; relative positioning
                        ;G1 S2 Z5 F100 ; lift Z relative to current position
                        ;G90 ; absolute positioning
                        ; homez.g
                        ; called to home the Z axis
                        ; generated by RepRapFirmware Configuration Tool v2 on Tue Jul 16 2019 01:25:03 GMT-0600 (Mountain Daylight Time)
                        G1 X38 Y20 F6000 ; go to first probe point
                        undefined 1 Reply Last reply 16 Jul 2019, 17:54 Reply Quote 0
                          Phaedrux Moderator @keith
                          I think you may have a damaged probe, or the pin may be bent. There is a set screw at the top of the probe body that you can remove to get the pin out and check it.
                          You need the I1 at the end of the command to release the alarm. M280 P3 S160 I1
                          What happens if you put the probe into self test mode using M280 P3 S120 I1
                          undefined 1 Reply Last reply 16 Jul 2019, 18:23 Reply Quote 0
                            keith @Phaedrux
                            @phaedrux
                            All the other BLTouch commands work fine. Self test, retract, deploy, etc... It's just the M280 P3 S160 I1 that doesn't work.
                              A Former User
                              Could it be the command actually works but the sensor goes back into alarm straight away? Seems odds only S160 wouldn't work if the probe is working properly.
                                Recreate the retract probe file from scratch just to be on the safe side.
                                When it's doing the self test the probe goes in and out repeatedly no problem?
                                15 out of 20
