    DuetWifi 1.01 Updated to 1.24 - No Z Axis after update
    Firmware installation
    1.5k
    • dirtybirdnjundefined
      dirtybirdnj @Phaedrux
      @phaedrux said in DuetWifi 1.01 Updated to 1.24 - No Z Axis after update:
      I just occured to me now that it looks like you have a duet wifi but are running 1.24? I think you're eligible to upgrade further to 2.03 if you wished.
      This was one part of the update that was super confusing, I wasn't sure if the Duet2 and the DuetWifi I have are directly compatible with the firmware offered.
      The file I sent during firmware writing using BOSSA was Duet2CombinedFirmware.bin from what appears to be the latest release.
      https://github.com/dc42/RepRapFirmware/releases/tag/2.03
        @dirtybirdnj said in DuetWifi 1.01 Updated to 1.24 - No Z Axis after update:
        G31 P1000 Z2
        Your G31 needs to define the X and Y offset between the probe and the nozzle.
          What does the settings page say you have installed for firmwares?
          dirtybirdnjundefined 1 Reply Last reply Reply Quote 0
            @phaedrux
            First off thank you so much for your help with this!
            Settings / software info
            !!!! wow lol seems like a critical thing to be missing... measuring this now and figuring out the distance 😌
              Looks like you're all up to date.
              This may help with getting the probe setup: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Static_test_of_the_Z_probe
              • nopheadundefined
                nophead
                Seems like a bug if missing or incorrect probe offsets can cause the X and Y axes to crash. Once they are homed shouldn't they be limited to their defined range regardless of what G-code is executed?
                  Did adding the X and Y parameters to G31 fix it?
                    dc42 administrators @nophead
                    @nophead said in DuetWifi 1.01 Updated to 1.24 - No Z Axis after update:
                    The probe offsets default to zero; so leaving them out won't cause a crash.
                      dc42 administrators @dirtybirdnj
                      M558 is definiltey responding to the extra settings, but I still have to run M564 H0 to home the z-axis.
                      Do you mean you always need to run M564 H0 to home the Z axis; or only if you try to home the Z axis before X and Y have been homed?
                      When homing Z with a Z probe, the firmware won't let you do it if X and Y have not been homed first; otherwise it would probe at unknown XY coordinates.
                      Did you add the S2 parameter to the following command in homez.g as @Phaedrux said?
                      G1 Z1 F200 ; raise head 1mm to ensure it is above the Z probe trigger height
                        dirtybirdnj @dc42
                        Yes, this is exactly the case. Please see the screenshot above, I posted a log from the g-code console to document this.
                        I did and the S2 allows for upward movement before the probe, but it still refuses to execute the G30 that does Z-probing unless I run M564 H0 first.
                          Can you try deleting the deployprobe.g and retractprobe.g files?
                            @phaedrux
                            THIS WORKED 🙌 The "random movements" issue has been solved! I didn't delete the files I just commented out their contents, but I'll prob remove them soon for good measure.
                            Still need to run M564 H0 before z-axis is unlocked, but I feel way more confidant about doing some test prints now that the machine is homing correctly and behaving as expected again.
                            Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              Phaedrux Moderator @dirtybirdnj
                              Repost your homing files. There is a G1 move in there somewhere that needs S2.
                                What did they contain?
                                  I copied the contents of the files over to a scratch pad before I commented them out, here they are. I don't recall setting these up so it seems like something that was on the SD card that the previous firmware didn't run / care about? Not sure... either way I am elated that I had two successful prints tonight!
                                  // deployprobe.g
                                  ; Probe deployment routine for Mini Kossel
                                  M564 S0					; don't apply limits
                                  G1 X25 Y93 Z40 F10000	; put probe arm next to belt
                                  G1 X-5 F500				; move probe arm across belt
                                  G1 X12 F1000			; move probe back
                                  G1 X0 Y0 F10000			; move to somewhere sensible
                                  M564 S1					; apply limits again
                                  //retractprobe.g
                                  ; Probe retraction routine for Mini Kossel
                                  G1 Z40 F10000			; raise head
                                  G1 X-59 Y66 Z35			; move over the post
                                  G1 Z7 F500				; push probe down on post
                                  G1 Z35 F10000			; raise head again
                                  G1 X0 Y0				; move to somewhere sensible
                                  After taking a look at these I can clearly see it's setting M564 S1 at the end of each which is prob what was causing the "axes not homed" errors! I commented out the M654 H0 in my config.g and it homes the Z with no problem now. These files also account for the "random" x+y movements that were happening with the homing process as well... mysteries solved and case closed.
                                  This thread can be marked solved! Thanks again to @dc42 @Phaedrux for your help!
                                    Glad it's all working now.
