    DuetWifi 1.01 Updated to 1.24 - No Z Axis after update
    Firmware installation
    1.5k
      Did adding the X and Y parameters to G31 fix it?
        dc42 administrators @nophead
        @nophead said in DuetWifi 1.01 Updated to 1.24 - No Z Axis after update:
        Seems like a bug if missing or incorrect probe offsets can cause the X and Y axes to crash. Once they are homed shouldn't they be limited to their defined range regardless of what G-code is executed?
        The probe offsets default to zero; so leaving them out won't cause a crash.
          dc42 administrators @dirtybirdnj
          @dirtybirdnj said in DuetWifi 1.01 Updated to 1.24 - No Z Axis after update:
          M558 is definiltey responding to the extra settings, but I still have to run M564 H0 to home the z-axis.
          Do you mean you always need to run M564 H0 to home the Z axis; or only if you try to home the Z axis before X and Y have been homed?
          When homing Z with a Z probe, the firmware won't let you do it if X and Y have not been homed first; otherwise it would probe at unknown XY coordinates.
          Did you add the S2 parameter to the following command in homez.g as @Phaedrux said?
          G1 Z1 F200 ; raise head 1mm to ensure it is above the Z probe trigger height
          dirtybirdnjundefined 1 Reply Last reply Reply Quote 0
          • dirtybirdnjundefined
            dirtybirdnj @dc42
            Yes, this is exactly the case. Please see the screenshot above, I posted a log from the g-code console to document this.
            I did and the S2 allows for upward movement before the probe, but it still refuses to execute the G30 that does Z-probing unless I run M564 H0 first.
              Can you try deleting the deployprobe.g and retractprobe.g files?
                dirtybirdnj @Phaedrux
                @phaedrux
                THIS WORKED 🙌 The "random movements" issue has been solved! I didn't delete the files I just commented out their contents, but I'll prob remove them soon for good measure.
                Still need to run M564 H0 before z-axis is unlocked, but I feel way more confidant about doing some test prints now that the machine is homing correctly and behaving as expected again.
                Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  Phaedrux Moderator @dirtybirdnj
                  Repost your homing files. There is a G1 move in there somewhere that needs S2.
                    What did they contain?
                      @phaedrux said in DuetWifi 1.01 Updated to 1.24 - No Z Axis after update:
                      I copied the contents of the files over to a scratch pad before I commented them out, here they are. I don't recall setting these up so it seems like something that was on the SD card that the previous firmware didn't run / care about? Not sure... either way I am elated that I had two successful prints tonight!
                      // deployprobe.g
                      ; Probe deployment routine for Mini Kossel
                      M564 S0					; don't apply limits
                      G1 X25 Y93 Z40 F10000	; put probe arm next to belt
                      G1 X-5 F500				; move probe arm across belt
                      G1 X12 F1000			; move probe back
                      G1 X0 Y0 F10000			; move to somewhere sensible
                      M564 S1					; apply limits again
                      //retractprobe.g
                      ; Probe retraction routine for Mini Kossel
                      G1 Z40 F10000			; raise head
                      G1 X-59 Y66 Z35			; move over the post
                      G1 Z7 F500				; push probe down on post
                      G1 Z35 F10000			; raise head again
                      G1 X0 Y0				; move to somewhere sensible
                      After taking a look at these I can clearly see it's setting M564 S1 at the end of each which is prob what was causing the "axes not homed" errors! I commented out the M654 H0 in my config.g and it homes the Z with no problem now. These files also account for the "random" x+y movements that were happening with the homing process as well... mysteries solved and case closed.
                      This thread can be marked solved! Thanks again to @dc42 @Phaedrux for your help!
                        Glad it's all working now.
