    Programming a smart effector
    Smart effector for delta printers
    3.0k
    • curieosundefined
      curieos
      I got some custom white PCB smart effectors made. I'm going to populate them sometime soon, and I would like to know how you guys program them. I planning on using one of my Teensys as an ISP for avrdude and connecting it up with a little pogo-pin connector I'm printing. I was looking at the firmware repo though, and I saw for the compilation output only a .elf was available. Don't I need a .hex?
      Besides that, any other holes in my plan?
      She/Her
      I work at a local 3D printing shop.
      Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
        That sounds viable. Most attiny programmers accept both .elf and .hex files. I don't know about avrdude, I haven't used it for years. I program the prototypes of our attiny based units using an AVRISP Mk 2 and Atmel Studio.
        • curieosundefined
          curieos
          @dc42 great! Do you know if a micro loaded up with the ISP arduino sketch will work with Atmel Studio, or is this more something that I'd be alone on?
          She/Her
            dc42 administrators @curieos
            @curieos said in Programming a smart effector:
            I don't think Atmel Studio can drive an Arduino running ArduinoISP. But you can convert a .elf file to a .hex file. See https://stackoverflow.com/questions/19458031/how-to-create-a-executable-hex-from-elf-file-format for one possible way. I haven't tested this, but I think Arduino IDE uses a similar command.
            • curieosundefined
              curieos
              @dc42 do I need to burn a bootloader? I think I have everything wired up correctly, but I seem to be having some issues.
              She/Her
              • curieosundefined
                curieos
                I think I got the wrong model of ATiny44s, mine are too small to solder on the board reliably. What model of ATiny are you guys using?
                She/Her
                • Danalundefined
                  Danal @curieos
                  No.
                    We use the smallest second smallest Attiny44a, that comes in a square leadless package. You have to reflow solder them. I soldered the prototypes myself, using a Mylar stencil to place the solder paste accurately, and a hotplate.
                    ken340undefined 1 Reply Last reply Reply Quote 0
                    • curieosundefined
                      curieos
                      Is that a 3x3mm chip? That’s what I have I think, and the pads on the chip barely touch the pads on the board
                      She/Her
                        A Former User
                        schematic says attiny44a-mmh which is the 3x3 mm vqfn version, pads are supposed to be under the chip
                          That's right, the pads are under the chip.
                          • curieosundefined
                            curieos
                            Okay, guess I’ll have to give it another shot. Thanks for the help!
                            She/Her
                              A Former User
                              You can pull it of in a frying pan, but there really isn't any substitute for solder paste or pre-tinning the pads and applying good flux. Google and youtube will show lots of home gamer ways to do smd assembly with basic tools.
                              • curieosundefined
                                curieos
                                I have access to a reflow oven, hot air station, and several soldering irons. Also solder paste and flux. Might have gotten too much solder on the center pad, we will see when i try again.
                                She/Her
                                • curieosundefined
                                  curieos
                                  No matter how hard I try it wont line up, I don't think these fit on my board. I suspect that when I opened up the board files in KiCAD, since my libraries are different, it chose a slightly different footprint, maybe for the 4mm version. I'm ordering some new ones that should hopefully work just fine.
                                  She/Her
                                  • curieosundefined
                                    curieos
                                    It was the wrong part number, I got the new one installed and avrdude accepted it for programming.
                                    She/Her
                                    • curieosundefined
                                      curieos
                                      To continue this, several months later. I finally got around to building a second one. Unfortunately neither of them seem to work. I am able to program them, avrdude recognizes them as attiny44s, but the status light never comes on, and the probe seems to trigger somewhat randomly. Any ideas on troubleshooting? Everything else works fine, all the other lights light up, the only issue is probing. Both boards seem to have this issue.
                                      She/Her
                                        If the green trigger LED never comes on, I suggest you sort that out first. Check that it is fitted the right way round and the value of the series resistor is correct. Also, make sure you are using the correct firmware version - there are different firmwares for the version 1 and version 2 effectors.
                                        • ken340undefined
                                          ken340 @dc42
                                          @dc42 can you tell me the part number for the Attiny44a on ver 2.0
                                            It's the 4mmx4mm version of the chip, which is attiny44a-mu.
