Height map has a substantial Z offset error with mesh
30
4.6k
    Veti
    your bed and hotends have the default B4138 value.
    this is most likely incorrect for your thermistor and will report the wrong temperature.
    undefined 1 Reply Last reply 24 Jul 2019, 06:17 Reply Quote 0
      Origami @Veti
      @veti hmm what should I set it to? I have the stock cr10s thermistor for both hotend and bed
        Veti
        according to the marlin config
        https://github.com/MarlinFirmware/Marlin/blob/bugfix-2.0.x/config/examples/Creality/CR-10S/Configuration.h
        the hotend is a epcos 100k and the bed is a semitec 104GT-2, both can be selected in the duet configurator.
        undefined 1 Reply Last reply 24 Jul 2019, 06:49 Reply Quote 0
          Origami @Veti
          @veti this may sound stupid but how do i select it in the duet configurator lol... is it the rrf config tool? It just asks me to type in the b value there are no preset selections.
          I have found the Semitec b value in the wiki here but Epcos 100k have 3 different model so not sure which one I should be using...
          https://reprap.org/wiki/Thermistor
            Veti
            click into the beta field and the selector will open
            undefined 1 Reply Last reply 24 Jul 2019, 07:01 Reply Quote 0
              Origami @Veti
              @veti OH now i feel dumb xD thanks for the tip there, got my bed at 4267 and nozzle at 4092 now 😄
              I looked up datasheet for both thermistor and used that instead of the preset since it seem to be incorrect as the EPCOS was only 10k ohm on the rrf.
                Veti
                you are correct. that is a mistake in the configurator. it is supposed to be 100k and 4092 B
                see
                https://github.com/MarlinFirmware/Marlin/blob/bugfix-2.0.x/Marlin/src/module/thermistor/thermistor_1.h
                  Origami
                  Back on topic tho... I'm running a new bed mesh now with the bed heated up to 60c... I'm sure the temp will be more accurate than before now.
                  but mesh has no luck, bed is still floating in midair on the mesh for some reason..
                    Veti
                    but it does work if you probe before every print?
                    undefined 1 Reply Last reply 24 Jul 2019, 15:16 Reply Quote 0
                      Origami @Veti
                      @veti that will have same result, basically my mesh is like 0.7 mm higher than what its supposed to be, I can use the Z baby stepping in web gui to lower the nozzle to around -0.95 mm and it'll print OK. Before the lowest I have used is like -0.25 mm
                        Veti
                        i am guessing the you are doing the homing with the hotend and bed turned on.
                        did you create the heighmap under the same conditions?
                        undefined 1 Reply Last reply 24 Jul 2019, 19:53 Reply Quote 0
                          Origami @Veti
                          @veti yes everytime mesh is done it is at printing temp
                            gueee78
                            @dc42 do you have any idea what could cause that behavior. I tried to help him find the issue but since z-homing with the mini IR works flawlessly I can't think of what it actually is.
                            it seems like it just adds a certain offset value to the probe values at some point for no reason.
                            as if z0 gets redefined after initial z homing.
                              Origami
                              Just an update.. I did absolutely no modifications beside the heater stuff yesterday, however today i just did another mesh and there was 1 point that was below 0 and the warning message went away. I started another print and my z babystepping value went from -0.95mm to -0.45mm which is much better than before but still not what I had before which is max -0.25mm.
                              undefined 1 Reply Last reply 22 Feb 2021, 13:53 Reply Quote 0
                                Veti
                                you are probing on glass with an Ir sensor.
                                check that the point where you are probing does not have any special feature, since its the center and that is where the thermistor is.
                                do check the repeatrability of your probe at different places.
                                https://forum.duet3d.com/topic/6962/m48-measure-z-probe-repeatability-and-print-to-serial-output/7
                                  gueee78
                                  Hey Veti,
                                  no he's not probing on glass he uses a TH3D sheet, completely opak and it worked flawlessly before. That phenomenonm started to appear all of a sudden with nothing changed. Btw it got better again, but the repeatability is still rather bad.
                                  Switchin the printer off and on again usually trows the settings off by about 0.3mm wich is way too much imo.
                                    mjnewman
                                    I'm now having the identical issue. Origami did you ever solve this issue you were having???
                                      pkos
                                      I'm also seeing the problem.
                                      Home Z works flawlessly, sets the distance exactly right, but mesh is always too high, which impacts the quality of the print...
                                      Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
                                        ziggymanpopo
                                        Im wondering if it might have somthing to to with the distance of the sensor from the print surface, more than the progaming or the ver. Instaled. Could a new ver. affect the readout of bed leveling mesh? And does the value returned by the senor get funky at a certain hight??? I know sensors have a sweet spot. That would chainge with type of sensor Just a thought 🙂
                                          pkos
                                          That is a good question.
                                          What I see is really weird.
                                          I run G28 - everything gets set perfectly. I check if the nozzle touches the bed on z0 - it does. I move the carriage around a bit, come back to probing point - still, nozzle touches the bed just fine.
                                          But the moment I hit G29 - it seems as if 0.25 is added to the readings. I don't exactly understand why only then this happens.
                                          fcwiltundefined 1 Reply Last reply 11 Feb 2021, 20:56 Reply Quote 0
