    Closed loop for X and Y
    closed loop odrive
    11
    26
    3.3k
    • Iamturbo1978undefined
      Iamturbo1978 @Veti
      @veti I currently have a hypercube. I might do that as an upgrade. Thanks
      • DocTruckerundefined
        DocTrucker @Iamturbo1978
        @iamturbo1978 fair enough. Just feeling the aims need to be a little tighter. Appreciate cost isn't as much of an issue, but all the same if you're throwing hundreds at the drive it would be nice for you to be able to have a little confidence in what you hope to achieve.
        But on the other hand, I would have better precision, accuracy, no missed steps, faster travel speeds (non printing).
        No missed steps aren't much of a thing. If you miss steps in a build with the extruder things can get a little messy. If you miss steps on the axis then you are going to be out of position by at least 2 physical steps. In other words, generally game over. A well set up machine won't do that unless something else has gone wrong, which is likely to be looking poop anyway.
        Precision and accuracy are however valid aims. Stepper motor manufacturers have a state accuracy of step size in the order of a few percent of the step size. While the error will be repeatable there is currently no way to tune for and dial out these errors. encoders on the rails effectively ignore these errors. Microstep sizes when running at highest resolution for the duet2 are likely to be a fraction of the positional error of the major step.
        Take this one: http://motechmotor.com/productDetail-0104-40.html A 200 step motor with a 5% accuracy in step position. So positioning the stepper at 1.8deg is 1.8 +/- 0.09deg. The step size of a 256 microstep is 0.007, meaning that your positional accuracy of a single microstep is within about 12 microsteps. Splitting one rotation of the motor into 12.8 microstep lumps gives 4000 steps per full rev. So, to match the level of control you have from a stepper you'd likely need in the order of 40000 pulses per rev at the motor.
        ...but this is probably overkill when you look at the other uncontrolled errors that we have already hinted at. The wobble and surface patterns on parts can get significant before missed steps because the stepper can lag (or advance) target position by upto 2 whole steps before it snaps back or forth. So, taking that into consideration an encoder measuring the actual final axis position may only need to have the equivalent resolution of 1000 steps per revolution of the motor in order to hope to achieve better control than the current stepper systems. With a GT2 16 pulley axis on a simple machine that would be 1000 steps per 32mm.
        Finally I think the encoder + motor system has the potential to be far more energy efficient.
          DocTrucker
          The stepper is only likely to lag or advance on it's actual position when you are pushing the steppers hard in terms of acceleration or max speed. So, if you were looking at guarding from missing steps then around 800 pulses per inch maybe plenty. if you are looking to be better resolution than a 256 microstep stepper system that isn't heavily loaded you'd need to get as many as you can handle, somewhere between 16,000 - 32,000.
          Edit: Gut feeling is I'm guessing that a system based around your 8k encoder will be easier to setup than a stepper based system and generally very nice. However, there is potential for someone to tune a stepper based system to make higher detail parts.
            I think it's probably needless overkill for a Voron2. Quality steppers driven to spec and print settings tuned to the printer will be as good as the Voron frame design can provide anyway.
              Iamturbo1978
              Thank you everyone for your insight. Because of your input, I think I am going to go forward with doing a closed loop system for a couple reasons... One, to add one more example of using a closed loop system on a FFF printer. Two, move out of my personal comfort zone doing the designing and planning.
              Phaedruxundefined deckingmanundefined 2 Replies Last reply Reply Quote 1
                Phaedrux Moderator @Iamturbo1978
                @iamturbo1978 keep us updated. I'm interested to see how it goes.
                  deckingman @Iamturbo1978
                  @iamturbo1978 Those are two eminently sound reasons for going ahead. Even if the end result shows no advantages, you will have gained knowledge along the way, which is never a bad thing. As @Phaedrux said, keep us posted.
                    DocTrucker
                    Other thing is the torque characteristics of BLDC motors, and perhaps lower inertia may be beneficial to the systems.
                    Don't get me wrong, I'm not trying to put you off the idea, merely trying to help develop it and ensure your idea of how the system will perform is not at a level that is setting yourself up for a fall.
                    Keep an eye on inertia ratios to give yourself an easier ride to begin with. It's taken me a while to start getting my head around them but it is definately not just can the motor deliver the required torque.
                    • Urbanundefined
                      Urban
                      @iamturbo1978 You could check out this:
                      SimplexMotion
                      They use Out-runners and Hall sensors to read the magnetic field instead of encoders. Contact them directly with a project description if you are interested. I do not think they support linear encoders for position feedback.
                      One advantage with a servo is that you can use a stiffer Polyurethane belt to get a stiffer system with better response and accuracy. The downside is the tuning of the servo that can be time consuming.
                      In my experience from industrial servo application with linear encoders, the inner loop is the encoder in the rotating servo and the outer loop is from the linear encoder. I think it would be difficult to control a servo with only the linear encoder.
                      I have build a screw based system that can go fast (1m/s) and accurate and the limiting factor I found was the extruder (with gear) that has difficulties providing a smooth flow during accelerations, specially with pressure advance that creates higher pressure. The effect is similar to ghosting, so it took a while to figure out the cause. I print at 150mm/s (limited by the melting of plastic) and with conservative values for acceleration.
                        DocTrucker @Urban
                        @urban said in Closed loop for X and Y:
                        BLDC motors can run sensor less, however yes, I think it is far easier to get the timing of energising the coils correct and at an appropriate advance or retard with an encoder on the motor.
                        Danalundefined 1 Reply Last reply Reply Quote 1
                          Iamturbo1978
                          Thank you for the encouragement, and the additional advice. I did a quick check into SimplexMotion, there are no distributors in the US at this time. I will contact them to see what options they can do.
                          • Danalundefined
                            Danal @DocTrucker
                            @doctrucker said in Closed loop for X and Y:
                            The keyword being "run". Sensorless is based on back EMF from the un-energized phase. No motion, no back EMF. Small motion, not enough EMF to (properly) sense. Not a great thing for start/stop tracking of rotor position. Very un-suitable for stepper alternative, regardless of "closed" or "open" tracking of position over time.
                            DocTruckerundefined dc42undefined 2 Replies Last reply Reply Quote 1
                              DocTrucker @Danal
                              This project looks interesting:
                              https://odriverobotics.com/
                              ...and it's statement about most industrial motion being done by brushless servos.
                              Neatly it looks like this is likely to have CAN support soon, which will mean not masses of work to get it to play ball with duet3, or maybe with earleir duets with a bit more hardware since CAN is on Arduino Due.
                              @danal more-or-less an expansion of what I said? Hence 'can run'.
                              The rotor position encoder doesn't have to be particually high resolution to achieve decent start control. You could also send signals through one of the coils which won't move the rotor, but allow you to locate it.
                              The sensorless techniques result in a vague knowledge of true rotor position when in use, much like only knowing a stepper rotors position is within two physical steps of that assumed. This is acceleration/instant speed tuning come in. Essentially a patch on open loop control.
                              The downside of using BLDC like this is a 'lost step' would result in a larger angular displacement, but equally you'd need a greater torque to cause this. You could also slap an encoder on a stepper, but by that point you've lost most of the cost benefits of a stepper system.
                                dc42 administrators @Danal
                                @danal said in Closed loop for X and Y:
                                Exactly. Running BLDC motor sensorless is great in drones and similar applications where the motors always run fast, but in 3D printers and similar applications you must have a position sensor that works at speeds down to zero. You could possibly use a combination of a BLDC using sensorless commutation, gearbox (because BLDCs are suited to higher speeds than we need in 3D printers), and an encoder after the gearbox.
                                • Maboverundefined
                                  Mabover
                                  I always cringe a little bit when I see people using hobby/rc bldc motors for moto in control, as dc42 points out they are designed for high rpm operation, and not the low rpm position control a cnc machine needs, but I will say I am impressed people make it work as I have seen with the odrive.
                                  There are low cost industrial options emerging for bldc motors from some of the same suppliers as stepper motors, they even cone in standard NEMA motor frame sizes.
                                  Here is an example motor
                                  https://www.omc-stepperonline.com/bldc-motor/24v-4000rpm-0185nm-775w-48a-42x42x80mm-brushless-dc-motor-42bls80-24-01.html
                                  combined with an encoder such as
                                  https://www.omc-stepperonline.com/encoder/1000-cpr-optical-rotary-encoder-ab-2-channel-id-5mm-w-shielded-cable-hkt30.html
                                  Or
                                  https://www.cui.com/product/motion/rotary-encoders/incremental/modular/amt10-series
                                  And all you need is a drive of some sort.
                                  If the demand grows for these motors due to support by a future duet 3 expansion boards and support from other boards in the market the price will likely drop just like they have with steppers.
                                  Perhaps vendors will even sell the motors with an encoder attached saving the trouble of sourcing and mounting one.
                                    On Duet 3 we're also looking at supporting stepper drivers with encoders, such as these https://www.aliexpress.com/store/group/stepper-servo-motor/5053149_515433734.html?spm=a2g0o.detail.0.0.133274b9HAWpmu. We think we can drive them from the existing 3-drive expansion board, using a small adapter PCB to connect the encoder outputs of 3 motors to 3 of the I/O connectors on the expansion board.
                                    Maboverundefined 1 Reply Last reply Reply Quote 0
                                    • Maboverundefined
                                      Mabover @dc42
                                      @dc42 that would be awsome, I am guessing that the encoder will be used primarily for position/movement verification.
                                      I have a stepper driver that supports the use of an encoder for position verification and commutating the stepper motor as high pole count bldc to run a control loop on the curent of being applied to maintain rotor position. It can help quite the stepper down versus the standard noisier position verification mode but I don't think there is much to be gained over the existing silent nature of the trinamic drivers using that approach. One advantage it does provide is the ability to momentarily over drive the motor to overcome a high torque demand that would normally cause a stepped to miss a step.
                                      All in all really exciting news
