    motors mapping with Duet Expansion Breakout Board
    376
    • JVundefined
      JV
      Hi Guys
      I'm working with a duet2 ethernet and i connect an external drivers for the axis X,Y & Z axis (cartesian) using an Duet Expansion Breakout Board and my two extruders are working with the two drivers in the board E0 and E1.
      I would to connect two steppers motors (U,V axis) to the X and Y drivers present in the board, but i don't know how to mapping the motors in the RRF.
      Actually my configuration in the RRF is:
      M584 X5 Y6 Z7 E3:4 ; Apply custom drive mapping
      If i put the next line in the RRF should it work ok?
      M584 X5 Y6 Z7 E3:4 U0 V1 ; Apply custom drive mapping
      Thanks for your help guys.
      • Vetiundefined
        Veti
        yes.
        you will need to create homing files for them i.e. homeu.g
        JVundefined 1 Reply Last reply Reply Quote 0
        • JVundefined
          JV @Veti
          @veti
          i don't need to homing this axis, because they doesn't works like real axis, they just have to move in relative mode with a macro.
          should i do homing anyway?
          • Vetiundefined
            Veti
            well you need to configure the parameters for the additional axis
            motor current (M906)
            steps/mm (M92)
            acceleration (M201)
            maximum speed (M203)
            jerk (M566)
            axis limits(M208)
            endstop type and position M574 (M574)
            how would you know the position of the axis without homing?
            • JVundefined
              JV @Veti
              @veti
              for the application that i should do i don't need to know the position, they are not real axis, they must make a number of revolutions established in a macro.
              Thank you for your help
              • Vetiundefined
                Veti
                @veti said in motors mapping with Duet Expansion Breakout Board:
                steps/mm (M92)
                acceleration (M201)
                jerk (M566)
                you will still need to configure these regardless
                  dc42 administrators @JV
                  @jv said in motors mapping with Duet Expansion Breakout Board:
                  @veti
                  In that case you can just include G92 U0 V0 in homeall.g so that RRF considers that they have been homed.
                  • JVundefined
                    JV @dc42
                    Perfect David Thanks
