    how to change homing sequence
    My Duet controlled machine
    912
    • grizewaldundefined
      grizewald
      @patel said in how to change homing sequence:
      M3D promega
      There's a full guide to this on M3D's Promega support pages. See: Promega Support
        dc42 administrators @patel
        corexy printer setup
        how to change sequence homing x,y
        i am using M3D promega and i need to change sequence first y axis home after x axis
        manual working fine by hand trigger switch x limit and y limit
        See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_files and then https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Homing_files.
        patelundefined 2 Replies Last reply Reply Quote 0
        • patelundefined
          patel @dc42
          This post is deleted!
          patelundefined 1 Reply Last reply Reply Quote 0
          • patelundefined
            patel @patel
            @patel
            Error: Height map file heightmap.csv not found
            • Vetiundefined
              Veti @patel
              @patel
              you need to either replace G29 S1 with G29
              or do a probing manually with G29 once
              • patelundefined
                patel @Veti
                @veti
                https://youtu.be/YL8uC7bgR6U
                i try to change s2 to s1 but same did not change anything. x axis did not stop why switch located to corner .
                • Vetiundefined
                  Veti @patel
                  @patel
                  my response was to your heightmap.csv not found
                  • patelundefined
                    patel @Veti
                    @veti still popup massage during all home axis process
                    • patelundefined
                      patel @dc42
                      patel 5 Aug 2019, 12:13
                      this file copy from M3D promega
                      ; homeall.g
                      ; called to home all axes
                      ; Front left corner is (0,0)
                      ; ============ HOME X & HOME Y ==============
                      M98 Phomex.g ; Run the homex.g file, also homes the Y axis
                      ; ============ HOME Z ==============
                      M98 Phomez.g ; Run the homez.g file
                      this is homex.g file
                      ; homex.g
                      ; called to home the X axis
                      ; October 4, 2018
                      ; same as homey.g because of coreXY
                      ; ============= PRE-HOMING =====================
                      ; Ignore Machine boundaries
                      M564 H0 S0
                      ; Turn off bed leveling during homing
                      G29 S2 ; Does the same as M561!
                      ; Switch to Origin Tool
                      T0
                      ; Relative positioning
                      G91
                      ; Provide Z height clearance
                      G1 Z10 F750 S1
                      ; ================== HOME Y ============================
                      ; Rapid Y until limit switch triggers
                      G0 Y450 F1500 S1
                      ; Back off to release limit switch
                      G0 Y-6 F1500
                      ; Slow advance to trigger limit switch
                      G0 Y10 F120 S1
                      ; Set this location as Y = 384mm
                      G92 Y384
                      ; Move the gantry slightly away from back of printer, to allow travel past the bolt mounting the gantry bracket
                      G0 Y-5 F1200
                      ; ============= HOME X ====================
                      ; Rapid X until limit switch triggers
                      G0 X450 F1500 S1
                      G0 X-6 F1500
                      G0 X10 F120 S1
                      ; Set this location as X = 380mm
                      G92 X380
                      ; Move away from the limit switch, to prevent damage to it upon next move
                      G0 X-5 F1500
                      ; ============ Post-Homing ==============
                      ; Revert to absolute coordinates
                      G90
                      ; Re-enable mesh leveling
                      G29 S1
                      M98 Pmachine_axisdimension.g ; Set Axes Limits
                      ; Stop movement across limits, enable boundaries, homing requirement
                      M564 H1 S1
                      • Vetiundefined
                        Veti @patel
                        G29 S1
                        because you still have the same command in your homing file
                        • patelundefined
                          patel @Veti
                          @veti
                          need to delete or just change G29 only
                          can you enplane more detail
                          • Vetiundefined
                            Veti
                            G29 S1
                            https://duet3d.dozuki.com/Wiki/Gcode#Section_G29_Mesh_bed_probe
                            S0 (default if no S parameter) Probe the bed, save the height map in a file on the SD card, and activate bed compensation. The height map is stored in file is
                            S1 Load the height map from file and activate bed compensation. The default filename is as for S0 but a different filename an be specified using the P parameter.
                            • patelundefined
                              patel
                              I need to fix first homing problem if you have idea.
                              • patelundefined
                                patel
                                M569 P1 S0 ; Drive 1 goes forwards, CoreXY_1
                                change S1 to S0 know homing process fix
