BL Touch Issues
@phaedrux Thank you for your time! I will definitely update and make the changes you have suggested, I will also post an update afterwards! Thanks again!
@phaedrux just so I understand. It should be :
G91 ; relative positioning
G1 Z20 F6000 S2 ; lift Z relative to current position
G1 S1 X-235 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 X39.5 Y15 F6000 ; go back a few mm
G1 S1 X-235 Y-235 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 X39.5 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
G1 S2 Z20 F100 ; lift Z relative to current position
G90 ; absolute positioning -
@peterpeter said in BL Touch Issues:
Yes that looks good but I would probably change this to move the probe to the center of the bed.
@phaedrux ok cool. Thanks for all your help this far. I still haven't had any luck actually getting the mesh generated. My brain is starting to hurt, so I'll give it a break for a while and revisit when I am able to give it my full attention. Again, thank you!
How are you trying to generate the mesh?
This may help: https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
@phaedrux I was trying to use the probe for the mesh but never could get it to work. I just updated my firmware but there were several files for the 2.04 RC does everything look up to date?
Firmware Version: 2.04RC1 (2019-07-14b1)
WiFi Server Version: 1.23
Web Interface Version: 1.22.6 -
What happens when you send g29?
Those versions look up to date.
@phaedrux sorry I've taken so long to respond. When I first tried it, the hotend smashed into the bed lol. I figured my best option was to reset everything and start over from the beginning since I have updated the firmware. I'll let you know the outcome!
@phaedrux Unless......I have taken it outside and destroyed it
This post is deleted! -
