    gearbox stepper motors on Duet2wifi
    setup gearbox stepper motors settings duet 2 wifi acceleration
    924
    • jarekkundefined
      jarekk
      I have a problem setting up motors with gearboxes
      I have 2 NEMA 17 with 26.85:1 gearbox for XY
      0.067° Step Angle Planetary Gearbox Ratio 26.85:1
      • NEMA-17 bipolar 4-wire with motor length 40mm
      • Rated current 1.68A & resistance 1.65ohms
      • Rated Speed 7rpm/Rated Torque 3Nm
        https://www.amazon.com/gp/product/B00WAUKZWG/ref=ppx_yo_dt_b_asin_title_o03_s01?ie=UTF8&psc=1
      Nema 11 with 100:1 gearbox for my Z axe
      0.018 deg. Step Angle
      NEMA 11 bipolar 4-wire
      Planetary Gearbox Ratio 99.05:1
      Rated current 0.67A & resistance 9.2ohms
      https://www.amazon.com/gp/product/B00PNEQPCU/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
      all with
      Lead Screw Diameter: 8mm
      Screw Pitch: 2mm
      Lead: 8mm
      how can I set them up on config
      steps per mm
      max speed change
      max speed
      acceleration
      can anybody help, please?
      Thanks
      deckingmanundefined A Former User? mrehorstdmdundefined 3 Replies Last reply Reply Quote 0
        deckingman @jarekk
        @jarekk I find it's generally best to do the maths for full steps per mm then multiple the result by the desired micro stepping.
        So taking your first example, your (full) step angle is 0.067 degrees. So 1 revolution (360 degrees ) will be 5373.134328 full steps. Now we need to know how much linear travel you get in mm for one revolution. If you use a 20 tooth pulley and 2mm pitch belts (such as GT2) then 1 revolution will equate to 40mm. So your full steps per mm will be (5373.134328/40) 134.3283582. Using 16x micro-stepping which is normal, then the steps per mm become (134.3283582 x 16) =2149.253731.
        If you use 16 tooth pulleys, then one revolution will be 32mm so the steps per mm would be 2586.567164.
        For the Z axis, the step angle is 0.018 degrees which gives 20,000 full steps per revolution. The lead of your screw is 8mm so 1 revolution gives 8mm of linear travel so the (full) steps per mm are 2,500 and at 16x micro stepping this becomes 40,000.
        Your maximum speed will be limited by the step pulse frequency. You need to check because this has recently changed from what I think was 200,000 Hz to 120,000 Hz.
        Assuming it's 120,000, then for X and Y it will be (120,000/2149.253731) = 55.8 mm/second using a 20 tooth pulley or 44.6667 mm/sec using a 16 tooth pulley. For Z it will be 120,000/ 40,000 = 3mm/sec (which is pretty slow).
          A Former User @jarekk
          You'll want to use the gear ratios and not the steps angle as they'll give you rounding errors. And you'll want to decide on a compromise between high resolution and high speed before moving on to speeds/jerk/acceleration i think.
          @jarekk said in gearbox stepper motors on Duet2wifi:
          10740 steps/mm (assuming the usual 16 microsteps, unless you need the resolution, you'd probably want less microstepping to increase the speed?)
          0.018 deg. Step Angle Planetary Gearbox Ratio 99.05:1
          39620 steps/mm (again assuming 16 microsteps which is probably not what you want?).
          360  / MotorStepAngle * MotorGearRatio * Microsteps / ScrewLead
          Motor step angle  1.8     1.8
          Motor gear ratio 99.05   26.85
          Screw lead        8       8
          Microsteps       16      16
          Steps/mm      39620   10740
          Microsteps        4       4
          Steps/mm       9905    2685
          Microsteps        1       1
          Steps/mm       2476.25  671.25
          Edit: The 26.85:1 motor for your X/Y is only rated for 7RPM. With the screw having a 8mm lead thats maximum 56mm/min or 0.93mm/sec regardless of your microstepping and step frequency. Thats pretty high resolution and slow speeds, and would require quite the rigid structure to make sense.
          jarekkundefined 1 Reply Last reply Reply Quote 0
          • jarekkundefined
            jarekk @A Former User
            @bearer said in gearbox stepper motors on Duet2wifi:
            8mm lead
            Thank you Bearer.
            • mrehorstdmdundefined
              mrehorstdmd @jarekk
              @jarekk what are you building that requires such fine stepping in all axes?
              • jarekkundefined
                jarekk @mrehorstdmd
                @mrehorstdmd A high resolution micro printer .
                  You may want to lead with that if you have more questions.
                    mrehorstdmd
                    With the very high resolution your printer's speeds will be limited to a few mm/sec. If the hot nozzle is depositing plastic on top of a previous layer, and moving only a few mm/sec, the nozzle may melt previously deposited plastic, wrecking print quality.
                    Have you checked backlash in the gearboxes?
                    • jarekkundefined
                      jarekk @mrehorstdmd
                      @mrehorstdmd thanks Im not going to use plastics nor heated nozzle 🙂
