New RepRapFirmware 3.0 early beta
So I think I figured out the problem:
It seems that between the last move of tfree0.g and the first move of tpre1.g it is doing a recovery of the old position ( G1 R2).
@smoki3 said in New RepRapFirmware 3.0 early beta:
Does it behave differently from firmware 2.03? There shouldn't be a difference.
It was definitely not like this on 2.02 and the older 3.0.And its a really wired behaviour. Because I use:
; tfree0.g ; called when tool 0 is freed ; ; generated by RepRapFirmware Configuration Tool on Wed Sep 19 2018 21:12:53 GMT+0200 (Mitteleuropäische Sommerzeit) G91 G1 Z10 F7200 G90 G53 G1 X0 F25000 ;XPOS G53 G1 Y190 G53 G1 Y195 F5000 M400 M98 P"/macros/Toolhead/1. Toolhead unlock" G4 P320 G53 G1 Y207 F5000 M400 G53 G1 Y165 F25000 M400 ; tpre1.g ; called before tool 0 is selected ; ; generated by RepRapFirmware Configuration Tool on Wed Sep 19 2018 21:12:53 GMT+0200 (Mitteleuropäische Sommerzeit) G1 X76 F25000 M400 G1 Y192 M400 M98 P"/macros/Toolhead/1. Toolhead unlock" G4 P400 G1 Y207 F5000 M116 P3 M400 M98 P"/macros/Toolhead/2. Toolhead lock" G4 P260 G1 Y150 F15000 The I only expect that only a X movement is done while the start of the tpre1.g but it first moves in X and Y.
If you read the firmware update motes for 2.03 you will see that tool offsets are now applied during tfree and tpost (but still not in tpre). Does that explain the issue? You can use G53 to prevent tool offsets being applied.
@dc42 Small hijack here: I realized that tool offsets are not applied for
G32
when doing manual bed leveling assist. Is that how it is supposed to be? -
(I think) I found a bug with PID tuning. When I try to run
M303 Hn Snn
it will always give meError: Heater is not ready to perform PID auto-tuning I tracked it down to
Heater.cpp:CheckGood()
where it saysreturn GetMode() == HeaterMode::fault && CheckProtection();
and I think the first comparison should be
or the heater is only good it if actually is infault
state.P.S.: Recompiled with
and at least it started the PID tuning - not sure if it will stop heating before the thermal cut-off will activate though, yet.EDIT 2:
I more or less successfully ran a PID tune for my heated bed. But: in the end it gave meWarning: Auto tune of heater 0 failed due to bad curve fit (A=238.4, C=854.2, D=0.5)
This was the misleading result of
Heater.cpp::SetModel()
returningGCodeResult::warning
due to the "heater appears to be overpowered" fact butLocalHeater::CalculateModel()
only checks forGCodeResult::ok
or anything else and in the latter case (including theGCodeResult::warning
) it will issue the above warning message to DWC.And one more EDIT: it did not output the
Warning: heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 263C.
as part of the Auto-Tuning procedure.
@dc42 said in New RepRapFirmware 3.0 early beta:
That change I now, as you can see in my script they already include G53 commands in the tfree.g
But the problem is:
Look at the last movement of my tfree.g: It move to G53 Y165 (no tool offset)
Then the script is finished. Then it starts with the G1 X76 in the tpre (still no tool offset)What I then expect is that the printer is just moving form G53 X0 (from the tfree.g) to the G1 X76.
But it is also moving in the Y axis.For me it sound like more that it is a bug of this change:
What new:
Restore points (created by G60 and created automatically at the start of a pause or a tool change) now have their coordinates stored independently of any workplace offsets. So if you create a restore point and then change the workplace offsets, when you go back to the restore point it will go back to the same machine position regardless of the change in workplace offsets. It seem like it is restore the old positions from the tool coordinate system during a tool change. Because also tries to restore the Z position during the tool change.
Means if you positioned the tool with G53 Y165 in the machine coordinate system then the tool stays at Y210 (depending on the tool offset) in the workplace coordinate system. Then you drop the tool! With the next movement of the tpre.g it tries to move with the machine cordnatesystem to Y210. Which is wrong at this point because for the tpre.g no tool offset is applied and it should just move in the axis you are calling.
There is a workaround for this issue:
If you put in the tpre.g the same command (G53 G1 Y165 F25000) on the first place then the printer is just restoring the Z position and the you can start with the tool change -
@wilriker said in New RepRapFirmware 3.0 early beta:
state.Thanks, I've corrected the source.
But the problem is:
For me it sound like more that it is a bug of this change:Please clarify. Are you saying that the G1 X76 command in tpre causes a move in the Y direction too? If so then this is certainly a bug. The coordinates stored in the tool change restore point should only be relevant at the end of the entire tool change sequence.
@dc42 Yes the G1 X76 also do a move in the Y direction. Also the Z axis is moving.
It restores the coordinates where the nozzle was before. The reference point of the printer tries to reach the point where the nozzle was before.
The only way actually can avoid this behavior is to put also a G53 G1 Y165 into the tpre.g script. Then only a Z move is done (but also this movement shouldn't be done).
Have you also seen my edit if the post regarding misleading message output?
@dc42 I switched now back to 2.02.
Here is everything fine. Also 2.04 and 2.03 has this issue. I tried also the old v3 build from the dropbox. Here also everthing is fine.
I assume that it has something to do with the commits from May 25th.
I will later do a build an try it out -
I was trying to build a older build but it seems that it's necessary to build wifisocketserver. But I don't geht it to build in my mac
This is now on my list to investigate, and fix in 2.04 if I can confirm the problem.
I was trying to build a older build but it seems that it's necessary to build wifisocketserver. But I don't get it to build in my mac
You don't need to build wifisocketserver, you just need the include directory in it to be present in the Eclipse workspace.
@dc42 using the tip of the current RRF v3-dev...
Sent: M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 C0 R4700 Sent: M308 S0 Sensor 0 type Thermistor using pin bedtemp, last error: sensor not ready, T:100000.0 B:4138.0 C:0.00e+0 R:4700.0 L:0 H:0 Sent: M308 S2 Y"thermistor" P"e1temp" A"HotEnd" T100000 B4725 C7.06e-8 Sent: M308 S2 Sensor 2 (HotEnd) type Thermistor using pin e1temp, last error: sensor not ready, T:100000.0 B:4725.0 C:7.06e-8 R:4700.0 L:0 H:0 Is there something wrong with this M308 syntax? All temps are 2000.0
I always get this when I trying to compile from a older source. If I try the actual branch everything is fine
../src/Networking/ESP8266WiFi/WiFiInterface.cpp:1857:10: error: 'APIN_SPI_MISO' was not declared in this scope make: *** [src/Networking/ESP8266WiFi/WiFiInterface.o] Error 1 -
@smoki3 You have to make sure that all of the repositories are at about the same point in time to compile. Most of the times having all repos except RepRapFirmware at the latest commit works but every once in a while there are bigger changes across repos (as in the case you show where some constants had been renamed) that require you to revert the according repo (I think it is CoreNG in this case) to a commit prior to the breaking change.
I have done some further testing:If I put not only "G1 X76" at the beginning of the tpre rather a "G1 X76 Y165" (Y165 same Y position as tfree) then just the X axis and Z axis is moving and Y axis stays as it should. Anyway the Z axis shouldnt move at this point.
So if you don't but every single axis into the first command of tfree it will restore the old position of the tool head
That's right, the APIN_SPI_MISO message means that the RepRapFirmware project is not in sync with CoreNG.
@gtj0 said in New RepRapFirmware 3.0 early beta:
There are some reported bugs in the current v3-dev. In particular, you need a quarter second delay between creating a sensor using M308 and creating a heater that uses it. I also have a report that configuring thermistors using M308 doesn't work (at least on Duet 3), which I am about to investigate.
