    Duet 2 Wifi Driver 1 Short to Ground
    597
      T3P3Tony administrators @creepercube
      @creepercube to confirm you get the sort to ground error on driver 1, with no motor plugged in? Also if you swap the motors around the issue stays with Driver 1?
      creepercubeundefined 1 Reply Last reply Reply Quote 0
      • creepercubeundefined
        creepercube @T3P3Tony
        @t3p3tony if i swap the motors around the issue remains with driver 1, if i remove the board and connect it to the pc via usb and YAT M122 shows every driver ok
        this is the result of m122 on machine startup:
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
        Board ID: 08DGM-917DA-G4MSD-6J9DG-3S46S-9SVRA
        Used output buffers: 3 of 20 (6 max)
        Static ram: 25524
        Dynamic ram: 98640 of which 12 recycled
        Exception stack ram used: 320
        Never used ram: 6576
        Tasks: NETWORK(ready,648) HEAT(blocked,1232) MAIN(running,3844) IDLE(ready,200)
        Owned mutexes:
        Last reset 00:02:45 ago, cause: power up
        Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6668 bytes (slot 1)
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
        Error status: 0
        Free file entries: 10
        MCU temperature: min 14.9, current 21.6, max 21.6
        Supply voltage: min 24.0, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
        Date/time: 2019-08-15 21:38:51
        Cache data hit count 584091307
        Slowest loop: 2.71ms; fastest: 0.07ms
        I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
        Bed compensation in use: none
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is idle in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 23.04ms; fastest: 0.00ms
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is running
          WiFi firmware version 1.22
          WiFi MAC address ec:fa:bc:25:33:65
          WiFi Vcc 3.38, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 29288
          WiFi IP address 192.168.1.100
          WiFi signal strength -44dBm, reconnections 0, sleep mode modem
          === Filament sensors ===
          Extruder 0 sensor: ok
        this is m122 after attempting to move either x or y (z moves with no problem)
        M122
        Used output buffers: 3 of 20 (15 max)
        Static ram: 25524
        Exception stack ram used: 344
        Never used ram: 6552
        Owned mutexes:
        Last reset 00:09:28 ago, cause: power up
        Error status: 0
        MCU temperature: min 21.4, current 24.1, max 24.4
        Supply voltage: min 23.8, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: standstill, SG min/max 0/1023
        Driver 1: short-to-ground standstill, SG min/max 0/1023
        Driver 2: standstill, SG min/max 0/0
        Date/time: 2019-08-15 21:45:34
        Cache data hit count 2037966704
        Slowest loop: 2.71ms; fastest: 0.08ms
        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 236, MaxWait: 346347ms, Underruns: 0, 0
        Scheduled moves: 47, completed moves: 47
        Segments left: 0
        === Network ===
        Slowest loop: 203.48ms; fastest: 0.08ms
        • WiFi -
          Failed messages: pending 0, notready 0, noresp 1
          creepercube
          can someone help me? is it a board fault?
            A Former User
            You didn't answer
            You swapped the drivers, I'd vager the end result is the same, but still. Seems like it a board fault indeed, maybe answer the question asked, and add where you purchased the board, the kit from AliExpress wouldn't be supported by Duet3d, but if you bought the Duet board from the authorized resellers you may get it replaced.
              creepercube @A Former User
              @bearer said in Duet 2 Wifi Driver 1 Short to Ground:
              You didn't answer
              there is no error with no motor plugged in. if i plug in motors the error always remain with driver 1. the board is not a clone and was bought from e3D official site. i tought my answer was clear in my first line of response, sorry but english is not my first language
                A Former User
                No worries, it is clear now at least.
                Are the two motors drivers configured the same, and the motors you swap are also the same? I think that should be enough information to confirm or rule out a problem with the board, but you'll have to wait for the admins to check back and call it a warranty replacement or not.
                creepercubeundefined A Former User? 2 Replies Last reply Reply Quote 0
                  @bearer yes, they are the same motor.
                    A Former User @A Former User
                    maybe just post your config.g file (and config-override.g if you have one). just to rule out any problems with configuration.
                      creepercube
                      config-override.g
                      config.g
                      they are the same provided on thingiverse for the blv cube... i have edited nothing to avoid problems
                        @creepercube please contact e3d for a warranty replacement referencing this thread.
                          @t3p3tony ok, thanks
