    first time delta experience, autocalbration
    760
    • johnjohn1990undefined
      johnjohn1990
      Done a S8 autocal now 🙂
      so basically i should run S6, S7, S8 and S9 as individual calibrations after eachother, ? 🙂
      • Dougal1957undefined
        Dougal1957
        no each one does something slightly different to each other in what is adjusted if you know your arm length accurately you should stick to either S6 or S8 S8 does the same as S6 but also adjusts for tower tilts should there be any IIRC
          johnjohn1990
            Dougal1957
            you need to reset the M665 to have the measured rod length first
            johnjohn1990undefined 1 Reply Last reply Reply Quote 0
              johnjohn1990 @Dougal1957
              @dougal1957
              did that, and now i get this, which is more right, with the standard settings which made perfect sized parts..
              tried a 6 and 8...
              that should be enough then? i just need to run a lot to get the deviation down0_1566404093705_autocal3.JPG
              • Danalundefined
                Danal
                To recap:
                • You SHOULD have a PRECISE measure of your diagonal rod length "joint center to joint center" before calibration, and put that in M665 L before calibration.
                • If for some reason you do NOT have this, you can run one of the calibrations that sets rod length... and you should expect to run it over and over. It will take as many as ten or fifteen runs to settle on the 'tradeoffs' between the various parameters.
                • The better way is to set the rod length (M665 L) to the exact physical, and run the calibrations, such as 6 and 8, that set everything else, but do NOT attempt to adjust rod length. These style calibrations should only need to be run a couple of times to 'converge', meaning get a decent deviation.
                • If deviation won't drop below 0.05 (or better) even after several runs, something else is wrong. Slop, loose belts, loose hub on a motor, something.
                And... as mentioned above... after you are happy with calibration, enter M500 manually. Then be sure M501 is somewhere near the end of config.g.
                  dc42 administrators @johnjohn1990
                  @johnjohn1990 said in first time delta experience, autocalbration:
                  @dougal1957
                  tried a 6 and 8...
                  Which firmware version are you using? There is a bug in 2.03 firmware that causes slow convergence when auto calibrating a delta. It isn't present in firmware versions 2.02 or 2.04RC1.
                  johnjohn1990undefined 1 Reply Last reply Reply Quote 1
                    johnjohn1990 @dc42
                    @danal said in first time delta experience, autocalbration:
                    To recap:
                    yep i did that 🙂 and it works! i kept the arm distance what i know it is - i cant measure more precise than the visibility of a difference in a mm scale.. i do not have calipers above 150mm... otherwise i could get it more precise.. but it is somewhere between 216 and 217mm... 216.5 is standard.. radius of 102 is also more exact, to what i have seen it can do, if i move it by hand..
                    could it be a shitty endstop? - using that as a probe, with the lever on it.. - i am intending to get something better..
                    @dc42 said in first time delta experience, autocalbration:
                    @dougal1957
                    tried a 6 and 8...
                    in fact i am running 2.03!
                    what exactly does that mean? 🙂 other than i need to update, asap 😄
                      johnjohn1990
                      i will say i am printing right now!
                      so, if i ever need to change my offset, i just home, jog down to where i want my new Z0, and then do a G92 Z0 ? 🙂
                      as said before, im used to an inductive probe, i have never had the need to use G92 in my case 🙂 might seem a bit dumb, lol.. feels like that 😛
                      and thank you VERY MUCH for giving you the time to cut it out for me 🙂 youre just great 🙂
                      • Danalundefined
                        Danal @johnjohn1990
                        yep i did that and it works! i kept the arm distance what i know it is - i cant measure more precise than the visibility of a difference in a mm scale.. i do not have calipers above 150mm... otherwise i could get it more precise.. but it is somewhere between 216 and 217mm... 216.5 is standard.. radius of 102 is also more exact, to what i have seen it can do, if i move it by hand..
                        Pre-made arms should have a sticker on them with xx.xx level precision.
                        Do repeated calibrations converge? Meaning below 0.05?
                        Fantastic!! By the way, I recommend a simple (probably 8 point) calibration before every print (if your probe supports that).
