    Always different Z probe trigger height...
    829
    • SPAXundefined
      SPAX
      Hello everybody.
      I still can't start to print normally...First layer very poor. I have need to Baby Stepping +-1mm.
      When I tying to calibrate the Z probe trigger height, I have always different value...
      What I do:
      1. Jog the nozzle down until it is just gripping a sheet of paper.
      2. G92 Z0
      3. Jog the head up by 5 to 5.8mm
      4. G30 S-1
        After repeat steps 1-4 for the other XY positions.
      And received this results:
      X0 Y0 3.781 3.775
      X60 Y130 3,671 3,658
      X-50 Y-100 3.491 3.485
      X100 Y-110 3.529 3.516
      Then I try to Auto Calibrate...
      13:02:54M666
      Endstop adjustments X0.08 Y-0.61 Z0.53, tilt X0.00% Y0.00%
      13:02:36M665
      Diagonals 484.350:484.350:484.350, delta radius 231.654, homed height 425.792, bed radius 190.0, X 0.943°, Y 0.626°, Z 0.000°
      13:02:23G32
      Calibrated 6 factors using 16 points, deviation before 0.176 after 0.107
      13:03:45M666
      Endstop adjustments X0.43 Y-0.84 Z0.41, tilt X0.00% Y0.00%
      13:03:43M665
      Diagonals 484.350:484.350:484.350, delta radius 231.967, homed height 425.853, bed radius 190.0, X 0.504°, Y 0.035°, Z 0.000°
      13:03:40G32
      Calibrated 6 factors using 16 points, deviation before 0.233 after 0.066
      13:04:45M666
      Endstop adjustments X0.13 Y-0.55 Z0.42, tilt X0.00% Y0.00%
      13:04:44M665
      Diagonals 484.350:484.350:484.350, delta radius 231.514, homed height 426.220, bed radius 190.0, X 1.075°, Y 0.688°, Z 0.000°
      13:04:41G32
      Calibrated 6 factors using 16 points, deviation before 0.172 after 0.083
      13:06:17M666
      Endstop adjustments X0.53 Y-1.02 Z0.49, tilt X0.00% Y0.00%
      13:06:15M665
      Diagonals 484.350:484.350:484.350, delta radius 232.251, homed height 425.637, bed radius 190.0, X 0.360°, Y 0.070°, Z 0.000°
      13:06:12G32
      Calibrated 6 factors using 16 points, deviation before 0.225 after 0.066
      Firmware Version: 2.03 (2019-06-13b2)
      WiFi Server Version: 1.23
      Web Interface Version: 1.22.6
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P2 ; Set firmware compatibility to look like Marlin
      M665 M665 L484.350:484.350:484.350 R231.324 H426.042 B190.0 X1.009 Y1.687 Z0.000 ; Set diagonal rod length, delta radius, printable radius and homed height
      M666 X-0.179 Y-0.944 Z1.123 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them
      M208 Z0.1 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P1 X0 Y0 Z0 F300 H5 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X15 Y15 Z3,6 ; Set Z probe trigger value, offset and trigger height
      M557 R135 S14 ; Define mesh grid
      M581 T2 E1 S0 ; Endstop E0 EMERGENCY
      M92 X160 Y160 Z160 ; Set steps per mm
      M92 E859 ; Set steps per mm Titan flying ABS &PLA
      M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without (I1 with) interpolation
      M566 X1200 Y1200 Z1200 E900 ; Set maximum instantaneous speed changes (mm/min) (jerk)
      M203 X12000 Y12000 Z12000 E5000 ; Set maximum speeds (mm/min)
      M201 X3500 Y3500 Z3500 E1200 ; Set accelerations (mm/s^2) Было по 2000
      M906 X2000 Y2000 Z2000 E1200 I10 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M572 D0 S0.2 ; Pressure advance
      • Vetiundefined
        Veti
        @spax said in Always different Z probe trigger height...:
        there is a bug in 2.03 with delta homing.
        see bugfix in 2.04RC1
        https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
        SPAXundefined 1 Reply Last reply Reply Quote 0
        • SPAXundefined
          SPAX @Veti
          @veti, thanks, I'll try to update now.
          • SPAXundefined
            SPAX
            New flashing did not help...
            Yes, now Auto Calibrating going good, but when I start to print the nozzle so high above bed...approx 1.5mm...
            It is mean what Auto Calibrating measure wrong homed height.
            19:50:58G32
            Calibrated 6 factors using 16 points, deviation before 0.061 after 0.060
            19:50:05G32
            • Vetiundefined
              Veti @SPAX
              duet uses . and not ,
              please read
              https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
              and test your z offset
              SPAXundefined 1 Reply Last reply Reply Quote 1
              • SPAXundefined
                SPAX @Veti
                @veti Ofcourse I tested and change it in config.g
                • Vetiundefined
                  Veti
                  how are you saving the G32 results?
                  • SPAXundefined
                    SPAX @Veti
                    @veti said in Always different Z probe trigger height...:
                    M500
                    • Vetiundefined
                      Veti
                      you dont have a M501 in your config. so those will be ignored.
                      • SPAXundefined
                        SPAX @Veti
                        @veti ouh man, I pasted not full config, special for low text... )))
                        • SPAXundefined
                          SPAX
                          Baby stepping don't worked too!
                          I set -2mm, but nozzle don't changed position....
                          • Vetiundefined
                            Veti
                            because you disallowed it
                            • SPAXundefined
                              SPAX @Veti
                              @veti But before that, everything worked well ... really don't know what happen...
                              And why is Z position 0.1 above the bed by 2 mm. I think Auto Calibration don't work well..
                              • Vetiundefined
                                Veti
                                that would indicate a wrong z trigger height
                                • SPAXundefined
                                  SPAX @Veti
                                  @veti I do all what in first post and correct config.g after ....
                                  • Vetiundefined
                                    Veti
                                    does your probe have problems?
                                    check the repeatability
                                    https://forum.duet3d.com/topic/6962/m48-measure-z-probe-repeatability-and-print-to-serial-output
                                    • SPAXundefined
                                      SPAX @Veti
                                      I think no.
                                      It is repeatability
                                      M98 P"0:/macros/M48"
                                      G32 bed probe heights: 0.088 0.095 0.088 0.088 0.088 0.095 0.095 0.088 0.101 0.095, mean 0.092, deviation from mean 0.004
                                      • Vetiundefined
                                        Veti
                                        hmm?
                                        problem with your endstops?
                                        do a the macro.
                                        then home with G28 and doe the macro again
                                        • SPAXundefined
                                          SPAX @Veti
                                          @veti omg....
                                          I wrote a comma instead of a dot
                                          Now I heat a bed and try again auto calibrate.
                                          • SPAXundefined
                                            SPAX
                                            Ok, now started print cube 20x20, first layer is well)
