    Having problems with Anycubic Kossel Linear Plus calibration
    calibration
    7.8k
    • SnakeSPundefined
      SnakeSP @Veti
      @veti Good point, will double check.
      • SnakeSPundefined
        SnakeSP @Veti
        @veti Yes, Marlin has 267, i took 271.5 after one of the calibration attempts. Will change to 267 and try again (actial measurements show 266.5, but not sure that those are really accurate as i was using just a metal ruler).
        • SnakeSPundefined
          SnakeSP @jay_s_uk
          @jay_s_uk No, steps are correct, i'm using 16 teeth pulleys now, not 20 teeth as in the original build.
          Tried bed compensation - did not help.
          • SnakeSPundefined
            SnakeSP
            Set L=267, recalibrated with S6:
            6:22:32 PMM666
            Endstop adjustments X-0.86 Y0.95 Z-0.09, tilt X0.00% Y0.00%
            6:22:27 PMM665
            Diagonal 267.000, delta radius 133.934, homed height 287.589, bed radius 115.0, X 0.517°, Y -0.986°, Z 0.000°
            6:22:11 PMG32
            Calibrated 6 factors using 16 points, deviation before 0.041 after 0.041
            Checked with S-1:
            6:28:52 PMG32
            G32 bed probe heights: 0.061 0.048 -0.070 -0.012 0.047 0.035 -0.052 -0.038 0.061 0.031 -0.060 -0.030 0.000 0.011 0.019 -0.029, mean 0.001, deviation from mean 0.043
            Checked that the nozzle goes to correct position: lowered nozzele to Z=0 and was hardly able to put paper between nozzle and bed (just as back then when i was on Marlin), so Z=0 is about 0.08 mm above the bed at center. Tried moving nozzle at Z=0 - height is about the same.
            Commented M208 Z0 S1 in the config.goes
            Tried printing PLA at bed 50C and hotend at 190C. Layer = 0.2, no offsets applied. Printing goes mid air.
            Tried using baby stepping. No changes till -0.2. With baby stepping = -0.2 plastic hardly sticks to bed but is moved away by the nozzle when it goes to the next line.
            Baby stepping = -0.22 made plastc smash into the bed.
            I really do not understand what's wrong...
            • Vetiundefined
              Veti
              @snakesp said in Having problems with Anycubic Kossel Linear Plus calibration:
              while printing do a M122 and show us the output. just to make sure that no mesh bed leveling is active.
              SnakeSPundefined 1 Reply Last reply Reply Quote 0
              • SnakeSPundefined
                SnakeSP @Veti
                @veti said in Having problems with Anycubic Kossel Linear Plus calibration:
                7:03:57 PMM122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
                Board ID: 08DGM-9T6BU-FG3SW-6J1FG-3SS6L-KBTHH
                Used output buffers: 3 of 20 (15 max)
                Static ram: 28380
                Dynamic ram: 95920 of which 16 recycled
                Exception stack ram used: 372
                Never used ram: 6384
                Task NETWORK ready, free stack 396
                Task HEAT blocked, free stack 1256
                Task MAIN running, free stack 3624
                Last reset 00:18:40 ago, cause: software
                Last software reset at 2019-09-01 18:45, reason: User, spinning module GCodes, available RAM 6384 bytes (slot 1)
                Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
                Error status: 0
                Free file entries: 9
                SD card longest block write time: 0.0ms
                MCU temperature: min 56.2, current 56.4, max 56.6
                Supply voltage: min 23.2, current 23.9, max 24.3, under voltage events: 0, over voltage events: 0
                Driver 0: ok, SG min/max not available
                Driver 1: ok, SG min/max not available
                Driver 2: ok, SG min/max 75/194
                Driver 3: ok, SG min/max not available
                Date/time: 2019-09-01 19:03:55
                Slowest loop: 174.92ms; fastest: 0.08ms
                Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 228, MinFreeDm 213, MaxWait: 0ms, Underruns: 0, 0
                Scheduled moves: 56, completed moves: 53
                Bed compensation in use: none
                Heater 0 is on, I-accum = 0.1
                Heater 1 is on, I-accum = 0.2
                Segments left: 1
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is doing "G1 X9.475 Y-40.525 F900" in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 3.74ms; fastest: 0.01ms
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is running
                  Failed messages: pending 338, notready 0, noresp 0
                  WiFi firmware version 1.21
                  WiFi MAC address 4c:11:ae:02:e3:cf
                  WiFi Vcc 3.33, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 16200
                  WiFi IP address 192.168.1.37
                  WiFi signal strength -70dBm, reconnections 0, sleep mode modem
                  === Expansion ===
                M122
                • Vetiundefined
                  Veti
                  you are using a very old version of the firmware. just to rule out any problems there update to 2.04RC1
                  but the problems comes down to this? with marlin pla sticks on the ultrabase. with duet it does not?
                  • SnakeSPundefined
                    SnakeSP @Veti
                    @veti Simply put, yes, with Marlin prints were ok, with Duet plastic does not stick (not only PLA, PETG also).
                    But i'm almost sure this is due to i'm doing something wrong.
                    Will try updating to 2.04 RC1 today and recalibrate.
                    Also it may occur that thermistors are configured incorrectly (hotend thermistor is changed from original one, but the bed is the same except changing it to 24V).
                    Possibly bed or hotend or both produce lower temperature than expected, but not sure how test this. But on the other hand PLA should stick even to cold bed.
                    • Vetiundefined
                      Veti @SnakeSP
                      this means that your offset is wrong btw. if there is space between the nozzle and bed for paper, then z=0 is not z=0 rather something like z=0.1+movement space.
                      • Vetiundefined
                        Veti
                        what thermistors have you configured in marlin?
                        • SnakeSPundefined
                          SnakeSP @Veti
                          @veti
                          Current Z probe offset is Z15.791, do you mean i should change it to 15.891 ?
                          It was
                          5 : 100K thermistor - ATC Semitec 104GT-2/104NT-4-R025H42G (Used in ParCan & J-Head) (4.7k pullup)
                          in Marlin, but that was original Anycubic thermistor. Same one for the bed.
                          • Vetiundefined
                            Veti
                            that is significantly different.
                            semitec is B4725 C7.060000e-8
                            • SnakeSPundefined
                              SnakeSP @Veti
                              @veti Yes, you are right, looks like i really need to change B from 3950 to 4725 at least for the bed thermistor, but what about the hotend thermistor? It is different from the bed one. And should i use С parameter?
                              And about Z offset for the probe: should i change it to 15.891?
                              • Vetiundefined
                                Veti
                                yes without that the B parameter is wrong.
                                for the offset. what i do is do a first layer print. if i need to adjust it with microstepping to get a good first layer i update the offset with the microstepping used.
                                • SnakeSPundefined
                                  SnakeSP
                                  The firmware upgrade guide tells to update not only the firmware itself, but DuetWiFiServer and DuetWebControl.
                                  WHATS_NEW.md for 2.04RC1 says, that compatible files are:
                                  DuetWiFiServer 1.23
                                  DuetWebControl 1.22.6 or 2.0.0-RC6 or 2.0.0-RC7
                                  But i cannot find those files. Can you point me where to get those?
                                  And also a question: what is an appropriate order to upgrade firmware? Upload all 3 files to /sys through Settings-General-Upload files declining update offers and run M997 S0:1:2 after that, correct? Will it preserve my network settings or i'll need to connect using usb and terminal to restore those?
                                  Nevermind. Found those:
                                  WiFiServer in 2.0.3 release
                                  WebControl
                                  • SnakeSPundefined
                                    SnakeSP
                                    Results so far:
                                    updated firmware
                                    changed bed thermistor to B4725 C7.060000e-8
                                    recalibrated with 15.881 (recalibrated Z probe, at Z=0 no paper can be placed under the nozzle)
                                    tried printing
                                    1. 190C 50C babystep=0 - no sticking to bed at all
                                    2. 190C 50C babystep=-0.5 - partially sticking, corners not sticking
                                    3. 190C 50C babystep=-0.8 - smashed into the bed
                                    4. 200C 60C babystep=-0.5 - better sticking, some corners not sticking
                                    5. 200C 60C babystep=-0.6 - same
                                      But when trying to print at center of the bed - no sticking until babystep=-0.12 at all
                                    Looks like the calibration is still not consistent, although with S-1 it reports height deviations less than 0.07:
                                    G32
                                    G32 bed probe heights: 0.056 0.037 -0.068 -0.010 0.041 0.026 -0.060 -0.038 0.058 0.032 -0.059 -0.034 -0.000 0.021 0.029 -0.031, mean -0.000, deviation from mean 0.042
                                    Thoughts:
                                    either calibration is still incorrect or temperature is still incorrect.
                                    • Vetiundefined
                                      Veti
                                      can you check with 7 factor what the rod length is calculated to be.
                                      and maybe try 8 factor.
                                      https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
                                      SnakeSPundefined 1 Reply Last reply Reply Quote 1
                                      • SnakeSPundefined
                                        SnakeSP @Veti
                                        @veti Will do a bit later.
                                        For now i've got some more interesting findings. Near the morning i've got crazy and ended up with Hotend at 235C and bed at 80C. And suddenly PLA sticked to bed even without any babystep. The print quality was bad, but plastic sticks. So it looks like more likely the problem is not with calibration itself, but with thermistors showing fake temperatures.
                                        Hotend thermistor was set to B3950 (as on Biqu site where i've bought it).
                                        Bed was B4267 as in Marlin.
                                        I took a multimeter and tried to measure the temperature with it. For bed it was about 5С under on multimeter till 60C on Duet and about 8-9C under from 60С till 85C on Duet.
                                        But with hotend this is a different story. I tried to put a thermocouple from multimeter to the heating cube near the thermistor shaft and the results on multimeter were absurdly low:
                                        173C when it was 235C on Duet.
                                        So the problem for now is: how to make printer thermistors show actual temperature (or at least close to real)?
                                        • Vetiundefined
                                          Veti
                                          the chinese B3950 are a bit of a pain. that beta is only accurate for the range of 25-50C.
                                          There seem to be different variation of these that behave differently at higher temperature ranges.
                                          I had some trouble with those and in the end got a pt1000.
                                          • SnakeSPundefined
                                            SnakeSP @Veti
                                            @veti Don't have PT1000 right now, but looks like i'll end with it.
                                            But i need to make prints by the end of this week and won't be able to get PT1000 by then.
                                            As for the current thermistor, i've managed to get almost acceptable results up to 100C so far by using boiling water and measuring thermistor resistance (B3988). Now thinking how to get resistance at 200-250C. Possibly can steal curling iron from my wife and use it to get needed temperature 🙂
