    Having problems with Anycubic Kossel Linear Plus calibration
    calibration
    7.6k
    • SnakeSPundefined
      SnakeSP
      Here are config.g, config-override.g and bed.g.
      I tried to change bed temperature to 80 С with no success.
      Thermistor used on hotend is this one: HT-NTC100K
      2_1567334916468_config-override.g 1_1567334916468_config.g 0_1567334916467_bed.g
      BTW i'm on Firmware Version: 2.0(RTOS) (2018-06-05b3)
      WiFi Server Version: 1.21
      Web Interface Version: 1.22.6
      Do you think updating to 2.04 RC1 will do anything better?
      • Vetiundefined
        Veti
        does this happen for pla as well?
        SnakeSPundefined 1 Reply Last reply Reply Quote 0
        • SnakeSPundefined
          SnakeSP @Veti
          @veti yes, just the same with PLA
          • Vetiundefined
            Veti
            M208 Z0 S1 ; Set minimum Z
            this will disallow babystepping below 0 i believe
            • Vetiundefined
              Veti
              also you have 271.5 as the rod length. marlin has 267 for it.
                jay_s_uk
                Your steps per mm are wrong. These should be 80 and not 100.
                Are you using mesh compensation as well in case your bed is slightly tilted?
                • SnakeSPundefined
                  SnakeSP @Veti
                  @veti Good point, will double check.
                  • SnakeSPundefined
                    SnakeSP @Veti
                    @veti Yes, Marlin has 267, i took 271.5 after one of the calibration attempts. Will change to 267 and try again (actial measurements show 266.5, but not sure that those are really accurate as i was using just a metal ruler).
                    • SnakeSPundefined
                      SnakeSP @jay_s_uk
                      @jay_s_uk No, steps are correct, i'm using 16 teeth pulleys now, not 20 teeth as in the original build.
                      Tried bed compensation - did not help.
                      • SnakeSPundefined
                        SnakeSP
                        Set L=267, recalibrated with S6:
                        6:22:32 PMM666
                        Endstop adjustments X-0.86 Y0.95 Z-0.09, tilt X0.00% Y0.00%
                        6:22:27 PMM665
                        Diagonal 267.000, delta radius 133.934, homed height 287.589, bed radius 115.0, X 0.517°, Y -0.986°, Z 0.000°
                        6:22:11 PMG32
                        Calibrated 6 factors using 16 points, deviation before 0.041 after 0.041
                        Checked with S-1:
                        6:28:52 PMG32
                        G32 bed probe heights: 0.061 0.048 -0.070 -0.012 0.047 0.035 -0.052 -0.038 0.061 0.031 -0.060 -0.030 0.000 0.011 0.019 -0.029, mean 0.001, deviation from mean 0.043
                        Checked that the nozzle goes to correct position: lowered nozzele to Z=0 and was hardly able to put paper between nozzle and bed (just as back then when i was on Marlin), so Z=0 is about 0.08 mm above the bed at center. Tried moving nozzle at Z=0 - height is about the same.
                        Commented M208 Z0 S1 in the config.goes
                        Tried printing PLA at bed 50C and hotend at 190C. Layer = 0.2, no offsets applied. Printing goes mid air.
                        Tried using baby stepping. No changes till -0.2. With baby stepping = -0.2 plastic hardly sticks to bed but is moved away by the nozzle when it goes to the next line.
                        Baby stepping = -0.22 made plastc smash into the bed.
                        I really do not understand what's wrong...
                        • Vetiundefined
                          Veti
                          @snakesp said in Having problems with Anycubic Kossel Linear Plus calibration:
                          while printing do a M122 and show us the output. just to make sure that no mesh bed leveling is active.
                          • SnakeSPundefined
                            SnakeSP @Veti
                            @veti said in Having problems with Anycubic Kossel Linear Plus calibration:
                            7:03:57 PMM122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
                            Board ID: 08DGM-9T6BU-FG3SW-6J1FG-3SS6L-KBTHH
                            Used output buffers: 3 of 20 (15 max)
                            Static ram: 28380
                            Dynamic ram: 95920 of which 16 recycled
                            Exception stack ram used: 372
                            Never used ram: 6384
                            Task NETWORK ready, free stack 396
                            Task HEAT blocked, free stack 1256
                            Task MAIN running, free stack 3624
                            Last reset 00:18:40 ago, cause: software
                            Last software reset at 2019-09-01 18:45, reason: User, spinning module GCodes, available RAM 6384 bytes (slot 1)
                            Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
                            Error status: 0
                            Free file entries: 9
                            SD card longest block write time: 0.0ms
                            MCU temperature: min 56.2, current 56.4, max 56.6
                            Supply voltage: min 23.2, current 23.9, max 24.3, under voltage events: 0, over voltage events: 0
                            Driver 0: ok, SG min/max not available
                            Driver 1: ok, SG min/max not available
                            Driver 2: ok, SG min/max 75/194
                            Driver 3: ok, SG min/max not available
                            Date/time: 2019-09-01 19:03:55
                            Slowest loop: 174.92ms; fastest: 0.08ms
                            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 228, MinFreeDm 213, MaxWait: 0ms, Underruns: 0, 0
                            Scheduled moves: 56, completed moves: 53
                            Bed compensation in use: none
                            Heater 0 is on, I-accum = 0.1
                            Heater 1 is on, I-accum = 0.2
                            Segments left: 1
                            Movement lock held by null
                            http is idle in state(s) 0
                            telnet is idle in state(s) 0
                            file is doing "G1 X9.475 Y-40.525 F900" in state(s) 0
                            serial is idle in state(s) 0
                            aux is idle in state(s) 0
                            daemon is idle in state(s) 0
                            queue is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 3.74ms; fastest: 0.01ms
                            HTTP sessions: 1 of 8
                            • WiFi -
                              Network state is running
                              Failed messages: pending 338, notready 0, noresp 0
                              WiFi firmware version 1.21
                              WiFi MAC address 4c:11:ae:02:e3:cf
                              WiFi Vcc 3.33, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 16200
                              WiFi IP address 192.168.1.37
                              WiFi signal strength -70dBm, reconnections 0, sleep mode modem
                              === Expansion ===
                            M122
                            • Vetiundefined
                              Veti
                              you are using a very old version of the firmware. just to rule out any problems there update to 2.04RC1
                              but the problems comes down to this? with marlin pla sticks on the ultrabase. with duet it does not?
                              • SnakeSPundefined
                                SnakeSP @Veti
                                @veti Simply put, yes, with Marlin prints were ok, with Duet plastic does not stick (not only PLA, PETG also).
                                But i'm almost sure this is due to i'm doing something wrong.
                                Will try updating to 2.04 RC1 today and recalibrate.
                                Also it may occur that thermistors are configured incorrectly (hotend thermistor is changed from original one, but the bed is the same except changing it to 24V).
                                Possibly bed or hotend or both produce lower temperature than expected, but not sure how test this. But on the other hand PLA should stick even to cold bed.
                                • Vetiundefined
                                  Veti @SnakeSP
                                  this means that your offset is wrong btw. if there is space between the nozzle and bed for paper, then z=0 is not z=0 rather something like z=0.1+movement space.
                                  • Vetiundefined
                                    Veti
                                    what thermistors have you configured in marlin?
                                    • SnakeSPundefined
                                      SnakeSP @Veti
                                      @veti
                                      Current Z probe offset is Z15.791, do you mean i should change it to 15.891 ?
                                      It was
                                      5 : 100K thermistor - ATC Semitec 104GT-2/104NT-4-R025H42G (Used in ParCan & J-Head) (4.7k pullup)
                                      in Marlin, but that was original Anycubic thermistor. Same one for the bed.
                                      • Vetiundefined
                                        Veti
                                        that is significantly different.
                                        semitec is B4725 C7.060000e-8
                                        • SnakeSPundefined
                                          SnakeSP @Veti
                                          @veti Yes, you are right, looks like i really need to change B from 3950 to 4725 at least for the bed thermistor, but what about the hotend thermistor? It is different from the bed one. And should i use С parameter?
                                          And about Z offset for the probe: should i change it to 15.891?
                                          • Vetiundefined
                                            Veti
                                            yes without that the B parameter is wrong.
                                            for the offset. what i do is do a first layer print. if i need to adjust it with microstepping to get a good first layer i update the offset with the microstepping used.
