    Wrong position after homing axes
    3.8k
    • Vetiundefined
      Veti @CoolM8
      @coolm8 said in Wrong position after homing axes:
      Somehow I believe the printer thinks moving from real X0 Y0 to X0 Y15 is an impossible move (the motors sound quit like when the run in to force and cannot move any further), but it still executes it.
      find out where its grinding on. the endstops?
      • CoolM8undefined
        CoolM8
        It is not grinding anywhere. It makes the move correctly just the sound is weird.
        This is not a mechanical issue, it is only software side.
        It only happens wile probing, i can make exactly the same move just fine before the Z-axis is homed (i cannot do it afterwards because the software does not allow me to go negativ on the X axis).
        I alread had the following:
        M574 X1 Y1 Z1 S0
        changing to the following did not bring any changes:
        M574 X1 Y1 S0
        M574 Z1 S2
        Why is G30 affecting the X and Y axes anyway?
        Might it be that i have the Duet Wifi 1 but running recently updated Version:
        Firmware Electronics: Duet WiFi 1.0 or 1.01
        Firmware Version: 2.03 (2019-06-13b2)
        WiFi Server Version: 1.23
        Web Interface Version: 1.22.6
        • Vetiundefined
          Veti
          M558
          its not but it might be picking up your X1 in M558 command
          try replacing the entire line with
          M558 P1 H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
          • CoolM8undefined
            CoolM8
            @veti said in Wrong position after homing axes:
            This still has no effect on this behavior.
            To be exact, the X offset after homing is 58mm. When execute an emergency stop after homing Z, I can move the X-axis to -58 until the endstop triggers. I then can manually go forward 204mm until I reach the end of the other side of the X axis (from -58 to 164). This shows that the motors and the stepping is set up correctly.
            I have taken a video of the steps from Z-Axis homing. The strange movement beginns at 1:00 minute into the video. See: https://youtu.be/9m7Y-PwS-pI
            • Vetiundefined
              Veti
              the video is private
              • Vetiundefined
                Veti
                M564 H0
                can you remove this? this should not be in a normal config.
                also the normal place for the M208 command is after the M84. This should not be a problem for your config i think, but on certain commands the order is important.
                • CoolM8undefined
                  CoolM8
                  If I remove M554 H0 I cannot home any axis anymore. No matter what i choose homeall, home X, ... I get this error: G0/G1: insufficient axes homed
                  I fixed the video and it should now be accessible:
                    Phaedrux Moderator @CoolM8
                    This is because of this
                    ; Lift Z
                    G1 Z5 F6000
                    You need to add S2 to that G1 Z move so that it can move without being homed first.
                    • CoolM8undefined
                      CoolM8
                      This is not what I'm looking for. I do not need to disable manual movement before homing and i do not need to overwrite that with manual commnands to move. All i want is G30 to work properly and not do to that strange additional movement that you can see in the video.
                        Can you send G31 P1 in the gcode console? I suspect that the offset may not be applied correctly.
                        Have you verified that the steps per mm is correct so that 10mm of requested movement equals 10mm of actual movement?
                        You can do as you wish, I'm merely explaining what's happening. Please keep in mind that we are only trying to volunteer our time to help you solve your problem. If you would prefer, I can stop trying to assist.
                        • CoolM8undefined
                          CoolM8
                          I did not want to be rude. I just wanted to clarify what I'am trying to solve. Any help is welcome and I am thankful for all your support. Too sad it has not helped yet.
                          G31 P1 does not do anything. Do I understand correctly that it should set the probe trigger value? Should the change be visible in the web view?
                            In the gcode console, what does M558 return?
                            Try sending
                            G31 P500 X40 Y0 Z0.35
                            Then alter your homeall "first probe point" to move the probe to the center of the bed. Say G1 X100 Y100. Before the G30.
                            and then test homing all.
                            • CoolM8undefined
                              CoolM8
                              @phaedrux said in Wrong position after homing axes:
                              Hmm, this is strange. Now it behaves completely different. The final position after G30 is now at X100 Y100 but the probed point which should be X100 Y100 is done at X0 Y100.
                              As long is I do not execute G30 the axes are working correctly. Homing X and Y puts the head to left front corner, G1 X100 Y100 moves the head to the center. According to the documentation I have set the front left corner to be 0,0. Somehow after G30, X100 Y100 is 0,0.
                                That definitely doesn't make sense. Are you sure you don't have any G92 commands in your homing files?
                                • CoolM8undefined
                                  CoolM8
                                  No, I don't see any G92 commands in my homing files.
                                    Could you upload your config files here? It would be helpful to see first hand everything that's going on. Slicer start gcode as well, since you stated it happens when starting a print, but otherwise works fine.
                                    • CoolM8undefined
                                      CoolM8
                                      I haven't had time the last couple of time.
                                      The problem happens not only when starting a print, but also when i execute homeall or home Z. Starting a print executes G30 first, homeall and home Z execute G30 at the ind.
                                      I wonder why G30 is modifying my X Axis. I thought it should not do it when no Parameter is passed with it.
                                      The config.g is not much different now, that what I have in the first post. Here it is:
                                      M111 S1 ; Debugging off
                                      G21 ; Work in millimetres
                                      M555 P2 ; Set firmware compatibility to look like Marlin
                                      M564 H0 S0
                                      M208 X180 Y180 Z205 S0 ; Set axis maxima
                                      M669 K0
                                      M574 X1 Y1 S0 ; Define active low and unused microswitches
                                      M574 Z1 S2
                                      M557 X0:180 Y15:180 S20 ; Define mesh grid
                                      G31 P500 X40 Y0 Z0.35 ; Set Z probe trigger value, offset and trigger height
                                      M569 P0 S0 ; Drive 0 goes forwards
                                      M569 P2 S0 ; Drive 2 goes forwards
                                      M350 X32 Y32 Z8 E16 I0 ; Configure microstepping without interpolation
                                      M92 X157.4804 Y157.4804 Z533.3333 E832 ; Set steps per mm
                                      M566 X1200 Y1200 Z480 E120 ; Set maximum instantaneous speed changes (mm/min)
                                      M203 X8100 Y8100 Z300 E1200 ; Set maximum speeds (mm/min)
                                      M201 X500 Y500 Z100 E250 ; Set accelerations (mm/s^2)
                                      M906 X1200 Y1200 Z1100 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M143 S290; Set maximum heater temperature to 310C
                                      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                                      ;M305 P1 R4700 T100000 B4388
                                      M305 P1 X200
                                      M563 P0 D0 H1 ; Define tool 0
                                      M550 PUltimaker ; Set machine name
                                      M552 S1 ; Enable network and acquire dynamic address via DHCP
                                      M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                      ;M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                      ;M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                        ; Go to first bed probe point and home Z
                                        G1 X0 Y15 F1800
                                        Have you changed the position used to probe the bed as I suggested earlier?
                                        If the Probe is +40 in X away from the nozzle, when you try and move the nozzle to X0, the probe would be at -40 in X over the edge of the bed. Get what I mean?
                                        • CoolM8undefined
                                          CoolM8
                                          When i run G1 X0 Y15 F1800 before Z is homed it goes to the right position.
                                          After G30 X0 it is actually 58mm away from real X0. With the current config I can move below 0 to X-58 until I hit the endstop.
                                          It makes no difference if configured Probe to have an offset in X or not. G31 P500 X40 Y0 Z0.35 or G31 P500 X0 Y0 Z0.35 both configs bring the same result. I don't understand how the offset of 58mm is calculated.
                                            Ideally you should position the probe so that it's in the center of the bed before sending G30 to probe. Have you tried changing your homeall to do that?
