    Z-Probe input signal
    • FelixHundefined
      FelixH
      Hi all,
      I'm fitted my cartesian printer with a small PINDA probe for the Z axis. Since the probe needs 5v I connected it to the 5v on the extension pins instead of the Z-Probe connector.
      My question is however regarding the signal voltage. Since the PINDA works at 5v, it must return 5 volts also. Can I plug the signal cable from the PINDA directly to the board or do I have to add a diode like with the bigger capacitive/inductive sensors?
      Thanks in advance,
      FH
      • Vetiundefined
        Veti
        it depends on your duet version.
        see
        https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
        • FelixHundefined
          FelixH
          Duet Wifi 2, 1.04
          • Vetiundefined
            Veti
            the duet v1.04 endstop pins can tolerate higher voltage
            so you can connect it directly as written in the guide
            FelixHundefined 1 Reply Last reply Reply Quote 1
            • FelixHundefined
              FelixH @Veti
              @veti said in Z-Probe input signal:
              Thanks a lot. I read the link you sent me through, but it's a bit overwhelming, I must admit...
