    Validating Linear (/non) Extrusion Correction Settings
    600
    • fcwiltundefined
      fcwilt
      Thanks for the info.
      Interesting topic.
      • samlogan87undefined
        samlogan87
        I had a play with it a few nights back and I was having some inconsistency problems as well. I used someone’s macro that they put up on here, did the tests, added the values into my config file, and ran the test again. I was still out by 2-3 mm across the board. Not 100% what is going on tbh.
        Sam
        Custom Core-XY
        • DocTruckerundefined
          DocTrucker @samlogan87
          @samlogan87 that's roughly what I saw. Ran a load of tests and determined I needed 0.007 on the linear correction. Checked it, and it was out. Doubled the correction and it was still out. Need to run more tests to check things out better but something weird going on.
            samlogan87
            Let us know how you get on. I will be intrigued to see what you find out.
            Regards
            Sam
            Custom Core-XY
              DocTrucker
              Currently running test 3 of 18 mapping the required correction. Will follow it with 6 tests with the extrusion commands within build files, and a further 6 outside build files. My test files are:
              G1 X0 Y-50 Z50 F6000
              G1 F27
              G1 Y50 E50 F27
              G1 Y-50 E50 F27
              My test F rates are 27, 82, 137, 192, 247, 302. Filament diameter 1.75. Stock E3D V6 with 0.4 nozzle.
                DocTrucker
                Ran back to back tests before M592 correction, after correction with G1 commands in a build and after. I can confirm they both give the same results and a correction is applied. Not sure what went wrong on my first trial!
                Thanks again.
                • fcwiltundefined
                  fcwilt
                  So what is the result of this correction? Does it make a significant difference in the printed items?
                    DocTrucker
                    My working print speeds are 10mm/sec through to 90mm/sec. In this range I was getting perfect 100mm lengths of extruded filament at low speed through to a 5% under extrusion at the higher extrusion rates. With the correction the requested length is all within 1%. It'll have a similar effect to being able to increase the extrusion multiplier by 0.05 for the large open areas, but leaving it at a lower value for slower sections. Makes it easier to tune.
                    Note: Below 40 is only used if the Slic3r thinks the layer time is too short - in other works I have prepared a bad build, on purpose or otherwise!
                    • fcwiltundefined
                      fcwilt @DocTrucker
                      @doctrucker
                      But does that improvement from 5% to 1% result in a significant difference in the printed items?
                        DocTrucker
                        In the past it has for me yes, so I just continue with the calibration process so that things are as close as possible to requested. The issue I was getting was if settings were good for large areas of solid fill small areas were over extruded, or visa versa. I don't think a benchy will show the difference but I will run two back to back with and without the M592 correction to see if you can see the difference on that. I suspect not.
                        To be honest if not apparent on the benchys the build times of the sort of files I had difficulties with (Panel Due mounts, Duet mounts, etc) are not something I'm likely to trial for the sake of it in the near future.
