RepRapFirmware 3.0 first official beta is out
Beta Firmware
15
132
9.0k
    gtj0
    On Duet2 Z-Probe seems to still be broken. Mine is reading 1000 when the piezo status led is red (untriggered)
    I'm also seeing lots of http instability. The duet frequently send back a RST immediately after receiving a SYN.
    Actually that might have been a switch port issue. 😞
      You need to see declare the ports used by the zprobe in the M558 command. For probes that are connected to the Z probe connector but don't use the MOD pin, use C"zprobe.in".
      undefined 1 Reply Last reply 13 Sept 2019, 11:34 Reply Quote 0
        gtj0 @dc42
        @dc42 said in RepRapFirmware 3.0 first official beta is out:
        Yeah that was it. Must be a recent change I missed.
        I'm also still having the issue where the reported Z height changes depending on X/Y position when a heightmap is loaded. For instance, if I home all 3 axes, move Z5, then X150 Y150, Z will still show 5.000. If I then home XY, Z will show 5.173. Move X150 Y150 and Z still shows 5.173. Home XY and Z now shows 5.346 (the error has doubled).
        Also getting odd bed levelling results. With XYZ homed and a dive height of 5.000, I start bed levelling. After the sequence completes, Z reports 5.700. If I move Z-5, the nozzle is touching the bed and not at 0.700 actual height. Also If I run the sequence again as is, I get a nice converged result although Z is still showing 5.700. If I home Z and re-run, I get a reported correction of -0.1xx at all 3 points.
        ; config.g
        M574 Z1 S2
        M558 C"zprobe.in" P5 I1 R1 F300 H5 T6000 A4 S0.05
        G31 P500 X0 Y0 Z0
        M557 X0:460 Y0:450 S25 ; Define mesh grid
        ;Lead Screw
        M671 X-23:238:498 Y13:485:13 S5
        ; bed.g
        M561
        G29 S2
        M201 X600 Y600
        G30 P0 X0 Y13 Z-99999 ; probe near a leadscrew
        G30 P1 X238 Y450 Z-99999 ; probe near a leadscrew
        G30 P2 X460 Y13 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
        G1 X0 Y0
        undefined 1 Reply Last reply 13 Sept 2019, 13:01 Reply Quote 0
          dc42 administrators @gtj0
          @gtj0 said in RepRapFirmware 3.0 first official beta is out:
          It was new in this release.
          Please share your homing files. When you say "If I then home XY", do you mean you send G28 XY, or G28 X followed by G28 Y, or something else?
            gtj0
            I almost always home X/Y then Z
            ; homexy.g
            G91 ; relative mode
            G1 H1 X-490 Y-490 F3000 ; coarse home X or Y
            G1 H1 X-490 ; coarse home X
            G1 H1 Y-490 ; coarse home Y
            G1 H2 X5 F600 ; move away from the endstops
            G1 H1 X-10 ; fine home X
            G1 H1 Y-10 ; fine home Y
            G92 X0 Y0
            ; homez.g
            G91 ; relative positioning
            G1 Z2 F200 S1 ; lift Z relative to current position
            M400
            G1 Z-450 F600 S1 ; dive to probe
            M400
            G1 Z5 F600 S2 ; lift Z relative to current position
            G90
            G1 Z0.10
            G92 Z0
              The G92 X0 Y0 may be messing things up. Please remove it, and use M208 to set up the positions at which the homing switches trigger instead.
              undefined 1 Reply Last reply 13 Sept 2019, 16:48 Reply Quote 0
                gtj0 @dc42
                Didn't change anything. Z still increases. It appears that Z increases by whatever value is in the heightmap for the XY coordinates at which the XY homing was triggered. In my first example, it kept increasing by 0.173 because I was moving to the same XY coordinates before each try.
                The second issue of the extra 0.700 is really baffling and it's actually causing the nozzle to crash into the bed because the Duet thinks the bed is higher than it really is.
                  stewwy
                  Trying to set up for RRF3 here is the relevent bits from my config.g file:
                  M569 P0 S1 ; Drive 0 goes forwards X
                  M569 P1 S1 ; Drive 1 goes forwards Y
                  M569 P2 S0 ; Drive 2 goes backwards Z1
                  M569 P3 S1 ; Drive 3 goes forwards bondtech (backwards for titan)
                  M569 P4 S0 ; Drive 2 goes backwards Z2
                  M584 X0 Y1 Z2:4 E3 ; Mapping drives X drive 0 Y1 Z2&4 E3
                  M671 X-50:325 Y110:110 S0.5 : Leadscrew positions for bed tramming
                  M350 X16 Y16 Z16 E16 I1 ; Configure micro-stepping with interpolation
                  M92 X100 Y100 Z1600 E144.1 ; Set steps per mm ( 99.5 for standard extruder)
                  M566 X2220 Y2220 Z600 E2220 ; Set maximum instantaneous speed changes (mm/min) jerk settings. was 600 600 40 Maximum jerk rates: X: 2220.0, Y: 2220.0, Z: 400.0, E: 2040.0
                  M203 X18000 Y18000 Z600 E3000 ; Maximum speeds (mm/min)
                  M201 X2000 Y2000 Z120 E1000 ; Set accelerations (mm/s^2) from X480 Y240 Z250 E1000
                  M204 P500 T1200 ; Lower accelerations when printing though
                  M906 X1600 Y1600 Z1600 E700 I30 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  G21 ; Work in millimeters
                  M208 X-5:280 Y0:230 ; X carriage moves from -5 to 280, Y bed goes from 0 to 230
                  ; Endstops and set ir sensor
                  ;M574 X1 Y2 S0 ; X home to min. Y home to max. N0pen micro-switches.
                  ;M574 Z1 S2 ; Define Z to use Probe. Home to Min.
                  M574 X1 S0 P"xstop" ; X min N0pen endstop switch
                  M574 Y2 S0 P"ystop" ; Y max N0pen endstop switch
                  M574 Z1 S2 P"zstop" ; Z min active high endstop switch
                  M574 U1 S2 P"zstop" ; U min active high endstop switch
                  M558 P1 C"zprobe.in" H3 F600 T6000 X0 Y0 Z1 ;RFF3.x Set Z probe type/mode 1. Not using on XY, but using it on Z. F400 dive speed T6000 travel speed
                  G31 P500 X15 Y-2 Z1.46 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                  M557 X10:260 Y5:205 S50 ; Define mesh grid at edge old M557 X0:250 Y0:210 S40
                  M308 S0 P"bed_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700 ;RFF3.x Set thermistor + ADC parameters for heater 0 BED
                  M308 S1 P"e0_temp" Y"pt1000" X501 R4700 ;RFF3.x Heater 1 uses a PT1000 connected to thermistor channel 1 which has a 4.7K series resistor
                  M950 H0 C"bed_heat" T0 ;RFF3.x heater 0 uses the bed_heat pin, sensor 0
                  M950 H1 C"e0_heat" T1 ;RFF3.x heater 1 uses the e0_heat pin and sensor 1
                  M143 H1 S280 ; Set temperature limit for heater 1 to 280
                  M307 H1 A639.9 C269.5 D8.2 S1.00 V13.7 B0 ; Auto-tune copper block
                  M307 H0 A148.7 C890.0 D1.2 S1.00 V13.9 B0 ; AUTO-TUNE bed RESULT
                  M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P1 S255 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M563 P0 S"Hotend" D0 H1 ; Define tool 0
                  I'm a bit stuck. I use drives 2 and 4 for Z and for bed leveling, do I still need to use seperate M574 commands, and can I still used bed leveling ?
                  undefined 1 Reply Last reply 13 Sept 2019, 17:39 Reply Quote 0
                    dc42 administrators @stewwy
                    @stewwy said in RepRapFirmware 3.0 first official beta is out:
                    Do you really mean bed levelling (using the Z probe, see https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors), or do you mean independent endstop switches on each of the Z motors? Your config.g file isn't right for either.
                    undefined 1 Reply Last reply 13 Sept 2019, 18:45 Reply Quote 0
                      gtj0
                      I think I solved my Z 0.700 issue. I don't know how but...
                      G31
                      Current reading 0, threshold 500, trigger height 0.70, offsets X0.0 Y0.0
                      Nowhere in my configs to I set 0.700 for anything.
                      Anyway, a restart seems to have solved that issue.
                      I'm retesting mesh probing and the heightmap thing now.
                        stewwy @dc42
                        @dc42 bed leveling using the bed leveling probe (an ir sensor, one of yours πŸ™‚ )
                          gtj0
                          Yeah I still have the issue with the Z height changing when homing XY when a heightmap is in effect.
                          undefined 1 Reply Last reply 13 Sept 2019, 20:25 Reply Quote 0
                            On my list to investigate, but may have to wait until after TCT.
                            undefined 1 Reply Last reply 13 Sept 2019, 20:41 Reply Quote 0
                              gtj0 @dc42
                              No problem. I'll nose around a bit this weekend.
                                kraegar
                                Odd one. Heater faulted halfway through a print. Print kept going, but shows 100% for a status (can't cancel it anymore). Obviously not extruding, just still moving. DWC went unresponsive on me, too. Really odd.
                                No idea why the heater faulted yet.
                                undefined 1 Reply Last reply 14 Sept 2019, 07:40 Reply Quote 0
                                  wilriker @kraegar
                                  @kraegar This means this issue has not been fixed, yet. 😞
                                  EDIT: which version of DSF are you using? That might make my above assumption incorrect.
                                  Manuel
                                  My Tool Collection
                                    Marco Bona
                                    With this build I encounter problems with heater mapping. The values ​​found are -273 with the exception of the heated chamber which is correct.
                                    ; 9 _ HEATERS
                                    M308 S0 P"bed_temp" Y"thermistor" A"Bed thermistor" T100000 B3950
                                    M308 S1 P"spi.cs1" Y"rtd-max31865" P"spi.cs1" A"RTD1"
                                    M308 S2 P"spi.cs2" Y"rtd-max31865" A"RTD2"
                                    M308 S3 P"e2_temp" Y"thermistor" A"Chamber thermistor" T100000 B4725 C7.06e-8
                                    M950 H2 C"e1_heat" T2
                                    M950 H3 C"duex.e2heat" T3
                                    undefined undefined 2 Replies Last reply 14 Sept 2019, 11:08 Reply Quote 0
                                      T3P3Tony administrators @Marco Bona
                                      @Marco-Bona said in RepRapFirmware 3.0 first official beta is out:
                                      are you definitely using .cs1 and .cs2 not .cs0 and .cs1 (i.e you have one daughter board) also remove the second P value
                                        @kraegar I recommend using DSF 1.0.3.3
                                        undefined undefined 2 Replies Last reply 14 Sept 2019, 12:03 Reply Quote 0
                                          Marco Bona @T3P3Tony
                                          @t3p3tony
                                          Sorry but the second P value was a bonding problem.
                                          For DSF I realized that it was only for Duet3, I'm using Duet2. If it is to be installed where can I find the file?
                                          11 out of 132
