    calibration wow!
    • Dugeeundefined
      Dugee
      been working on calibration for about 2 hrs, mostly 3 factor, keeping it simple, then moved onto 6 factor. 1st height map shown here. I am astounded. For a printer I paid less than £90 for (then spent much more on some decent upgrades) I am seriously impressed.
      • Dugeeundefined
        Dugee
        So..................
        beautifully calibrated delta, great terrain map, can't get a print.
        I've looked through the forum using a search for 1st layer adhesion and mid air printing but can't seem to find anything jump at me as to why my prints are starting 4-5mm above the bed.
        Typically this machine likes a tool offset of about Z0.28 which I have set in my tool set up in the config using G10, but I cant see anything that leads me to print mid air. Help!
        My config:
        ; Configuration file for Duet Maestro (firmware version 2.03)
        ; generated by RepRapFirmware Configuration Tool v2.0.3 on Sat Sep 14 2019 00:35:56 GMT+0100 (British Summer Time)
        M550 P"My Printer" ; set printer name
        M665 R62 L121 B50 H124.12 ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P0 S0 ; physical drive 0 goes backwards
        M569 P2 S0 ; physical drive 2 goes backwards
        M92 X100.00 Y100.00 Z100.00 E101.00 ; set steps per mm
        M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
        M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
        M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 Z0 S1 ; set minimum Z
        M574 X2 Y2 Z2 S0 ; set active low and disabled endstops
        M558 P5 H5 I1 F360 T6000 ; set Z probe type to switch and the dive height + speeds
        G31 p0001 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
        M557 R54 S20 ; define mesh grid
        M305 P0 T100000 B4092 R2200 ; set thermistor + ADC parameters for heater 1
        M143 H0 S120 ; set temperature limit for heater 1 to 120C
        M305 P1 T100000 B4092 R2200 ; set thermistor + ADC parameters for heater 2
        M143 H1 S280 ; set temperature limit for heater 2 to 280C
        M106 P0 S0 I0 F255 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P1 S1 I0 F255 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M563 P0 D0 F0 H1 ; define tool 1
        G10 P0 X0 Y0 Z0.28 ; set tool 1 axis offsets
        G10 P0 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
        My config override is:
        ; config-override.g file generated in response to M500 at 2019-09-14 21:24
        ; Delta parameters
        M665 L121.000:121.000:121.000 R62.151 H130.213 B50.0 X-0.230 Y-1.103 Z0.000
        M666 X0.147 Y0.090 Z-0.237 A0.00 B0.00
        ; Heater model parameters
        M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
        M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
        M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
        G10 L2 P1 X0.00 Y0.00 Z0.00
        G10 L2 P2 X0.00 Y0.00 Z0.00
        G10 L2 P3 X0.00 Y0.00 Z0.00
        G10 L2 P4 X0.00 Y0.00 Z0.00
        G10 L2 P5 X0.00 Y0.00 Z0.00
        G10 L2 P6 X0.00 Y0.00 Z0.00
        G10 L2 P7 X0.00 Y0.00 Z0.00
        G10 L2 P8 X0.00 Y0.00 Z0.00
        G10 L2 P9 X0.00 Y0.00 Z0.00
          dc42 administrators @Dugee
          @Dugee said in calibration wow!:
          Have you calibrated the trigger height of the Z probe? I suspect not, because you have set it to zero in the G31 command in config.g. What type of probe is it?
            If this is a delta you should try using firmware 2.04rc1 due to some delta bugs in 2.03 that may be causing you issues.
            • Dugeeundefined
              Dugee
              I had done it earlier, but as you say, it is now set to 0.
              I'm using the bed switches on a monoprice Mini delta, wired in parallel instead of individually, which is actually giving me me amazing repeatability, Over a sequence of 5 probes, I'm almost always having the last 4 the same to 3 decimal places and the 1st probe +0.02mm greater., all around the +/- 0.5mm mark.
              I'm giving up for tonight but tomorrow I'll do the G31 probing again and check I have the correct figure again, and as suggested by @Pheadrux I'll also move to firmware 2.04rc1.
              I knew it must be something straightforward as I had a couple of prints last week, but I've been staring too much at it today. Beginning to go fuzzy!
              thanks for the help
              edited to change wiring of bed switches
