    RepRapFirmware 3.0 first official beta is out
    Beta Firmware
    15
    132
    9.0k
    • kraegarundefined
      kraegar
      Failed again, at 14.50mm of an 80mm print. Reports it's 100% but definitely is not.
      • kraegarundefined
        kraegar
        I'd only used systemctl to restart all the duet processes. Trying a print from a known reliable slice from my duet2, with a fresh boot on the latest software on the unstable branch.
          T3P3Tony administrators
          @kraegar Please can you check the firmware viserion uning M115 and the versions on DSF you have through this command on the Rpi:
          apt list 2>/dev/null | grep duet | awk -F'[/ ]' '{print $1" "$3 }'
          (thanks @wilriker for the awk foo)
          • kraegarundefined
            kraegar
            @T3P3Tony said in RepRapFirmware 3.0 first official beta is out:
            FIRMWARE_NAME: RepRapFirmware for Duet 3 v0.5 FIRMWARE_VERSION: 3.0beta10 ELECTRONICS: Duet 3 prototype v0.5 FIRMWARE_DATE: 2019-09-12b1
            duetcontrolserver 1.0.3.3
            duetruntime 1.0.3.3
            duetsd 1.0.2
            duetsoftwareframework 1.0.3.3
            duettools 1.0.3.3
            duetwebcontrol 2.0.0-4
            duetwebserver 1.1.0.0
            • wilrikerundefined
              wilriker @T3P3Tony
              @bearer is the one to deserve credits for the awk-foo. I try to avoid awk where I can. 😁
              Manuel
              My Tool Collection
              A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 1
                A Former User @wilriker
                @wilriker said in RepRapFirmware 3.0 first official beta is out:
                you mean you don't want the blame? ... awkward! 😂
                • kraegarundefined
                  kraegar
                  awk is great. Learn to love it 🙂
                  I meant to kick off a ~4 hour print. Grabbed the slice and didn't check it, closer to a ~14 hour print. I'm a bit over 2 hours into it. So, this should be a good test of the duet3 after a fresh startup, so far so good.
                    T3P3Tony administrators @wilriker
                    @wilriker , cheers sorry @bearer 😄
                    • kraegarundefined
                      kraegar
                      Guess it's good I used the 14 hour slice, it froze about 12 hours in. It started to occasionally pause (could hear the stepper go still for a second or two), then it totally stopped moving and shut off the heaters. Wish I hadn't used my good filament, though!
                      https://i.imgur.com/IuEyyvB.jpg?1
                      • Dougal1957undefined
                        Dougal1957
                        OK Managed to get the Duet3 powered up and connected to the PI4 using the supplied image DWC came up on the Pi Monitor. so far so good. But how do I connect to it from elsewhere on my network I have tried to SSH in but don't have the Password for it and VNC doesn't want to connect either. I am guessing I need to set this up on the PI but being a total newby with Linux I could do with some pointers if someone could be so kind.
                        Doug
                          A Former User
                          @Dougal1957 said in RepRapFirmware 3.0 first official beta is out:
                          Not sure how this image is prepared, but the default raspbian user/password is pi/raspberry could try that while waiting. (Are you getting a login prompt at all when trying SSH? Default is not having SSH enabled)
                          Edit: although you should be able to configure the Duet3 part through the file editor in DWC just like on Duet2, however to update DSF/DWC i think you'll need SSH access for now.
                          Dougal1957undefined 1 Reply Last reply Reply Quote 1
                            Dougal1957 @A Former User
                            @bearer I am getting a response from SSH but it throw's me out after 3 PW attempts also bring to connect to the IP Address thru a browse doesn't seem to work either I am starting to wonder if I have the right IP Address for it
                              A Former User
                              Hmm, if you're running an OS that can mount Linux filesystems you should be able to mount the SD card in your computer and simply add your ssh key to /home/pi/.ssh/authorized_keys and log in regardless of passwords.
                              If you're on windows you could try resolving the hostname of the IP, might give you a clue if its the right address.
                              C:\Users\bearer>ping -a 10.10.193
                              Pinging duet3.lan [10.10.0.193] with 32 bytes of data:
                              Reply from 10.10.0.193: bytes=32 time=2ms TTL=64
                              Linux equivalent would be
                              bearer@rama:~$ nslookup 10.10.0.193
                              193.0.10.10.in-addr.arpa        name = duet3.lan.
                                T3P3Tony administrators @Dougal1957
                                @Dougal1957 its the default pi / raspberry
                                  T3P3Tony administrators @T3P3Tony
                                  @bearer AFAIK the way the image is setup has SSH enabled, using passwords. so no need to so that.
                                    T3P3Tony administrators @kraegar
                                    @kraegar did you manage to get an M122 captured?
                                    kraegarundefined 1 Reply Last reply Reply Quote 0
                                      A Former User @T3P3Tony
                                      i'd assume that but, the answer would still help determine if he has got the correct IP.
                                        @bearer I'm using a mac and my router does show that IP as being the Duet3
                                        When I try either pi or raspberry I get permission denied
                                        Also is there a terminal on the image as it does look very different to the std Rasbian image that came with the PI
                                          A Former User @Dougal1957
                                          @Dougal1957 ah, if you're connecting from a terminal to the ip address you probably need to specify the username.
                                          try ssh pi@192.168.0.102 or what your IP address is. Then use raspberry for the password
                                          edit: screenshot hadn't loaded when I replied, changed ip, but that should take care of it.
                                            @bearer Nope same again permission denied
