    Configuring Pause/Resume in Single External Trigger M581
    • kishan_042undefined
      kishan_042
      I am using duet wifi with Duet Expansion Breakout Board.
      I want to put Three physical button for Emergency Stop, Pause, Resume.
      Now I have only Two I/O available to configure external trigger E0_STOP & E1_STOP in the board.
      Now Can i configure Pause and Resume in Single Button ?
      or else suggest the solution.
        kishan_042
        E0_Stop is used Emergensy STOP (T0)
        E1_Stop is used for Pause (T1)
        for Resume i want to configure trigger.g but there is no I/O available.
        • Dougal1957undefined
          Dougal1957
          you do have e2-e6 stop available on the expansion header or you could purchase a Duex
          see the wiring diag
            kishan_042
            I am using Duet Expansion Breakout Board so Expansion headers are occupied, so is there any other way without buying Duex ?
            something like if I push a Button, that triggers a trigger2.g
            trigger2.g contains following
            if machining is running then this trigger do stop the machine,
            & if Machine is in pause condition then the same trigger do resume the machine ?
              A Former User
              You can redefine the trigger with the g-code in the trigger, and you can use start.g etc to set new triggers based on status.
              In the next version of reprap firmware you can do conditional g-code which will make such things simpler
