    So, I blew up a WK8 P9 at TR5
    616
    • Legrandundefined
      Legrand
      As the subject says, I have a Duet WiFi, V1.02, and a wire was ripped from the hot end assembly (fan wire, if I recall correctly) which shorted the board. The board boots up but it's not working correctly anymore. It appears as though a component labeled "WK8 P9" (transistor, I assume) with three leads on it located at TR5 blew up.
      Can someone tell me what this is so I can attempt to get a replacement and fix the board?
      • grizewaldundefined
        grizewald
        TR5 is a PMV40UN2 N-Channel MOSFET.
        Data sheet here: Nexperia PMV40UN2
        It controls the part cooling fan, so that matches with the short circuit.
        • Legrandundefined
          Legrand
          Awesome. Thank you!
          • worekarolisundefined
            worekarolis
            Anyone knows if PMV40UN2R is the same ting? Cant get PMV40UN2 anywhere 😞
            droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
              droftarts administrators @worekarolis
              @worekarolis see https://docs.duet3d.com/en/User_manual/Troubleshooting/Parts#fan-mosfet for alternatives.
                dc42 administrators @worekarolis
                @worekarolis is the board working apart from that fan output?
                worekarolisundefined 1 Reply Last reply Reply Quote 0
                  worekarolis @dc42
                  @dc42 @dc42 Yes seemingly everything works except fan and smart effector lights.
                  Also I think I've found right MOSFET:
                  https://www.digikey.com/en/products/detail/onsemi/MMBFJ211/1049196
                    @worekarolis that mosfet is not suitable.
