    Duet Software Framework
    Beta Firmware
    1.1k
      A Former User
      As of 1.0.3.3 M550 controls the displayed name in DWC, but indeed it can only be set to the same name as the current hostname; however it defaults to "My Duet"
      9/20/2019, 12:12:51 PM	M550 P"Duet3"
      9/20/2019, 12:12:37 PM	M550 PDUET3
      9/20/2019, 12:12:22 PM	M550 PTEST
      Error: Machine name must consist of the same letters and digits as configured by the Linux hostname
      9/20/2019, 12:12:14 PM	Connected to 10.10.0.195
        T3P3Tony administrators @A Former User
        @bearer yep, so best to leave it commented out until a future version when we can use DWC to set the hostname
        pdundefined 1 Reply Last reply Reply Quote 0
        • pdundefined
          pd @T3P3Tony
          @T3P3Tony Yes apologies I should have mentioned that. The next error message I received said the name set by M550 had to be exactly the same as the host name. Is this a function of RRF 3 or the duet framework setup?
            T3P3Tony administrators @pd
            @pd its the way that printer names and hostnames are related right now. For now please comment out M550 and then set your hostname to whatever you want to be the network name and printer name.
              A Former User @T3P3Tony
              @T3P3Tony said in Duet Software Framework:
              @bearer said in Duet Software Framework:
                @bearer weird - my does not it shows the hostname
                T3P3Tonyundefined A Former User? 2 Replies Last reply Reply Quote 0
                  T3P3Tony administrators @T3P3Tony
                    After downloading the DuetPi.img to test, it comes up as "My Duet" with the hostname "duet3"
                    pi@duet3:/opt $ hostname
                    duet3
                    But the name in Duet Web Control does change to "duet3" after creating an empty config.g which seems odd that a value should have effectively two defaults at different stages of booting.
                    pi@duet3:/opt/dsf/sd/sys $ touch config.g
                      one is the default for the DWC application. the other is what DSF will set once it has booted.
                        I get that, but I don't think many user will differentiate between having an empty config file and the defaults attached to DSF and a missing config file and the defaults attached to DWC.
                          @bearer well an empty config.g is not a state i would expect the system to be in except on initial setup. at which point, whatever is shown in DWC is not as important.
