    Heater showing 2000
    644
    • Elliotundefined
      Elliot
      OK so I know this has been asked many times before. I have looked through the posts and have not found one that answers my issue.
      Everything is connected properly, there is no shorts or lose wires.
      My extruder heater shows 2000. As a test, I unplugged my bed thermistor (which is showing the correct temperature) and plugged it in to my extruder thermistor and it also shows 2000, which I believe confirms that it is definitely not the wiring. Can someone please help?
      • JoergS5undefined
        JoergS5 @Elliot
        @Elliot if it's a thermocouple it could be a shortage to the heater block: https://forum.duet3d.com/topic/6272/thermocouple-faults-to-2000
        You can check resistance between thermistor and heat block and check whether cabling is ok.
        To help better, additional information is helpful: where did you connect, what type of thermistor do you use, image of thermistor and connection to the board, Duet board version and configuration file.
        • EasyTargetundefined
          EasyTarget
          1. When you tested with the bed sensor; what happens when you switch it back; does the bed now show the correct temp again?
          2. As JoergS5 says; to help you we need to see the type of both sensors; and to know if they are both thermistors, etc.
          3. Are the M305 P0 & M305 P1 settings from your config the same? Please share these here.
          With thermistors a reading of 2000 normally means a disconnected sensor; open circuit.
          I once saw something identical (but with the bed sensor).
          • In my case it was a RTFM confusion; I was plugging the thermistor into a fan circuit, not into the bed sensor.. This destroyed the sensor; I got through a couple of them before finding my face with my palm.
          Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
          PrintPy2024 to the rescue!
          MicroPython based; with simple wiring and and no custom PCB.
          • Elliotundefined
            Elliot
            @JoergS5 @EasyTarget I am not by my printer at the moment, but as soon as I am I will post pictures of both the board and thermistors.
            They are both stock ender 3 wires that I plugged into the corresponding places on the Duet.
            When I unplugged the bed thermister from the extruder slot and put it back in its right place, the beds temp was correct.
            Here is my config file. I have also tried plugging the extruder into e1 instead of e0, and changed the config file to M305 P2 instead of P1.
            ; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time)
            M550 Pe3 ; Set machine name
            M552 S1 ; Enable network
            ;*** Access point is configured manually via M587
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M569 P0 S0 ; Drive 0 goes backwards
            M569 P1 S0 ; Drive 1 goes backwards
            M569 P3 S0 ; Drive 3 goes backwards
            M92 X80.00 Y80.00 Z400 E95 ; Set steps per mm
            M566 X1000 Y1000 Z100 E30000 ; Set maximum instantaneous speed changes (mm/min)
            M203 X6000 Y6000 Z500 E1500 ; Set maximum speeds (mm/min)
            M201 X300 Y300 Z100 E5000 ; Set accelerations (mm/s^2) was 500 you changed it to 300 for stall guard
            M906 X500 Y500 Z500 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S300 ; Set idle timeout
            M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
            M208 X258.5 Y246 Z260 S0 ; Set axis maxima
            M574 X1 Y1 S1 ; Set active high endstops
            M574 Z1 S2 ; Set endstops controlled by probe
            M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
            M307 H4 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
            M558 P9 H2.5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
            G31 P25 X-31 Y0 Z1.86 ; Set Z probe trigger value, offset and trigger height
            M557 X50:185 Y50:185 S65 ; Define mesh grid
            M305 P1 X150 T"K" ; Set THERMOCOUPLE parameters for heater 1 X150 is the right channel (terminal block) on the daughterboard. X151 is the right channel.
            ;M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
            M143 H1 S345 ; Set temperature limit for heater 1 to 345C
            M106 P0 S0 I0 B0.5 F250 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S1 I0 B0.5 F500 L255 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Minimum Speed is 1/3 aka 87 Thermostatic control is turned on triggered at nozzle temp 45;
            M106 P2 S0 I0 B0.5 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M563 P0 D0 H1 ; Define tool 0
            ; Automatic power saving
            M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
            ; Custom settings
            M591 D0 P5 C3 R10:300 E3.0 S1 ; Duet3D laser sensor for extruder drive 0 is connected to endstop input 3 (E0), tolerance 10 to 120%, 3mm comparison length
            • Vetiundefined
              Veti @Elliot
              @Elliot said in Heater showing 2000:
              If they are stock ender 3 then the current M305 line is wrong as you do not have a thermocouple.
              uncommend the line underneath and comment the line above.
              Elliotundefined 1 Reply Last reply Reply Quote 1
              • Elliotundefined
                Elliot @Veti
                @Veti Thanks I have done that. I still have the 2000 problem though.
                I take that back! it works!
                Thank you so much
                • Elliotundefined
                  Elliot
                  I have two other issues. should i open new threads for them (to do with the screen and bltouch)
                  • JoergS5undefined
                    JoergS5 @Elliot
                    @Elliot I would seperate, so if someone searches with a similar question in the future, he finds it easier. Nice that you fixed your problem.
                    • Elliotundefined
                      Elliot
                      I spoke too soon. I am now getting an error temperature rising much more slowly than expected 1.8c / sec
                      Edit: Fixed it, hotend wires were in the wrong place e1 and not e0
