Cannot connect to DWC Simple fix??
@AMPMAKER said in Cannot connect to DWC Simple fix??:
I asked someone who is more knowledgeable than me, that's said the Orbi is a mesh network
and most likely the issue.If it IS a mesh setup that still would not explain the problem.
There is often a setting in the WiFi portion of a router configuration which allows enabling "client isolation".
When this is enabled wireless devices (WiFi) cannot communicate with wired devices.
That sounds like it might be the case.
Ok, Just fix the address? What exactly do you mean?
my IP shows 192.168.1.31 on the Duet when I enter M552
see below. But when I try to Ping I get no response.m552
WiFi module is connected to access point ORBI, IP address 192.168.1.31<LF>ok<LF>The Blue light flashed for a bit and entered M552 again and got a different IP.
m552
WiFi module is changing mode<LF>ok<LF>WiFi module is connected to access point ORBI, IP address 192.168.1.4<LF>Now it is connected.... Wow very frustrating but all I did.. I Think.. is turned off the ORBI (cycled Power)
while the Duet was plugged into and powered by the USB cable.
Now I enter 192.168.1.4 and the Duet screen comes up.Thank you all for the suggestions and help. Would have been a long time trying to figure this out without help.
Issue solved.. -
Will the Duet remember the IP address? Or do I need to send another M command?
Got it M552 S1 is already in the Network config.g file.
You can specify a static IP Address for the Duet WiFi in the M587 command which is NOT meant to always be present in your config.g file.
It's fine to put it there just to get the correct values stored in the WiFi module but once everything is working you need to comment out or remove the M587 command from your config.g.
Now the only problem with using a static IP address is that the router may try to handout that same address to another device that is asking for an IP address from the router.
You can avoid this problem by limiting the range of addressed the router can handout. This is a setting in the router configuration.
For example you could configure the router to handout IP address from x.x.x.21 to x.x.x.254, leaving addresses 2 through 20 for assignment to hardware like your Duet.
This is not my strongest area to be working in, so it is very frustrating when I get it to
work and now it doesn't. I unplugged the duet from the USB ate lunch came back to reconnect
and back to square one. Now no YAT. Saying com5 is closed, and no wifi of course.
Device manager see's it plugged into com 5??? What am I missing.I do understand handing out IP address above a certain range, but shouldn't the device always
have the same IP, once it is set. -
Device manager see's it plugged into com 5That is odd. When I first started with a Duet WiFi I had the odd problem with WiFi but I never had a problem using the USB connection. Perhaps you already have another instance of YAT running and connnected to COM5? Windows only allows one connection at a time to a COM port.
have the same IP, once it is set.If a device like a Duet is setup to use DHCP every time it powers up/resets and asks for an IP address it may get a different one.
The only way to insure that it ALWAYS gets the same one is with a IP reservation. If you can find a link to the manual for your router I will be glad to take a look and see if and how IP reservations can be done.
Frederick thank you for the offer, I will keep that offer a bit, but if I don't work this through I may never learn
how it's done. I have been able to get back to a YAT connection with the Duet. Still no internet Although.M552
WiFi module is connected to access point ORBI, IP address 192.168.1.4<LF>ok<LF>
M587
Remembered networks:<LF>TNCAP2FCC19 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0<LF>ORBI65 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>ORBI IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>ok<LF>I did find this on instructables.com Whats your thought on trying it.
https://www.instructables.com/id/Duet-WiFi-Activate-and-Connect-the-WiFi-When-It-Do/
I did contact the company that sold the Duet to us and he suggested a different router 2.4 of course just
for the duet. But I think that isolating the IP is the most Logical. -
I found this post from
dc42 ADMINISTRATORS 8 Mar 2018, 12:54
Either:- Send M552 S0, then send M552 P192.168.1.xx, then send M552 S1. You should then be able to connect DWC. In DWC go to the System editor and edit the M552 command in config.g to have that IP address.
Or:
- Move the SD card to a PC and use a text editor to make the same change to the M552 command in config.g.
So I was able to get connected to the DWC again, I just don't know if I turn this off if it will reconnect.
We shall see. The IP recorded in the config.g was different than the IP that came up when entering the
M552 command.Do I always have to go thru YAT to get to DWC or should it come up when the Duet is powered on??
Read about M552 a little more closely.
Notice:
"On the Duet 2 WiFi running firmware 1.19 and later, the IP address is set in the M587 command when you configure the access point details."
Once you get the WiFi configured correctly it is saved in the WiFi hardware "flash" memory and you can connect any time you power/reset the Duet.
@fcwilt Concerning YAT not connecting, what was described above is what happened to me. I opened a second instance of YAT and got connection errors. I also closed all connections and had some issues connecting back again.
I am having this same issue:
Duet 2 WIFI running 2.03 suite of firmware and drivers from github
Made it through Step 8 in the "Getting Connected to your Duet" guide
Connection to YAT works great
Connection to Pronterface works great
M552 returns:
ok
WiFi module is connected to access point SkyNet Guest, IP address 192.168.0.192
My tp-link router shows a wireless client at the 192.168.0.192 address but cannot identify it. (shows a "*" )I am clearly set up and connected, but I get the "can't reach this page" error every time. (I've tried both the IP address and the duettest.local routes)
@spudaddict said in Cannot connect to DWC Simple fix??:
The "Guest" part suggests to me that it is configured for client isolation. Which means a WiFi device connected using that SSID can see the Internet but nothing else on the local network. And nothing else on the local network can see the device.
Can you ping 192.168.0.192 from the PC where you are attempting to connect a browser?
You could try setting the Duet WiFi up in access point mode to check that it's definitely your network. I agree through it sounds like the Guest segment of your network could be restricting access.
Thanks to all that helped get us connected. Configuring the access was the final answer to
getting connected. Now I can turn on the Duet board and it will find our wifi.
Now on to the next hurdle, to actually configure the setting to this printer.
When I re-load the config.g to the board with the new setting will this stage of connection be lost.Maybe this should go to a new discussion.
I have hard wired all the motors, five in all two extruder motors. Optical limit switches and heaters ect.
I also have a Panel Duet 5i. I get no response from the panel, but I guess that is because I have not configured
and uploaded the new parameters. Still new to setting this up so should the old Config.g file be saved before
loading a new one? Does any on have a config file for a JGAurora A8 printer?Mark
Configuring the access was the final answer to getting connected.
What exactly do you mean by that?
Maybe the lingo was not correct..sorry
