    Checksum errors
    PanelDue
    2.3k
    • 3dwareundefined
      3dware
      Hello everybody
      I have a checksum error every few minutes on a new duet with paneldue.
      cable I have already tested and is so far io.
      I have already tried to use a shielded cable, but I get the same error.
      it may be that the sd card is not good?
      06:00:39
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3SJ-6JKDA-3SD6Q-1VXRF
      Used output buffers: 4 of 24 (19 max)
      Static ram: 25680
      Dynamic ram: 93816 of which 0 recycled
      Exception stack ram used: 436
      Never used ram: 11140
      Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,3820) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:05:07 ago, cause: power up
      Last software reset at 2019-09-27 05:47, reason: User, spinning module GCodes, available RAM 11224 bytes (slot 2)
      Error status: 0
      Free file entries: 9
      MCU temperature: min 26.1, current 27.7, max 27.9
      Supply voltage: min 26.6, current 26.9, max 27.1, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: ok, SG min/max 0/354
      Driver 1: ok, SG min/max 0/346
      Driver 2: ok, SG min/max 63/240
      Driver 3: ok, SG min/max 0/82
      Driver 4: ok, SG min/max 1/356
      Date/time: 2019-09-27 06:00:38
      Cache data hit count 1063112760
      Slowest loop: 56.25ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 163, MinFreeDm: 132, MaxWait: 22034ms
      === DDARing ===
      Scheduled moves: 399, completed moves: 395, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Heater 0 is on, I-accum = 0.2
      Heater 1 is on, I-accum = 0.3
      Segments left: 1
      Stack records: 3 allocated, 0 in use
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is doing "G1 X297.694 Y-16.907 E238.1284" in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 13.93ms; fastest: 0.00ms
      HTTP sessions: 2 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.21
        WiFi MAC address 60:01:94:2e:9e:d0
        WiFi Vcc 3.35, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 16592
        WiFi IP address 192.168.55.162
        WiFi signal strength -63dBm, reconnections 0, sleep mode modem
        === Filament sensors ===
        Extruder 0 sensor: ok
      • 3dwareundefined
        3dware
        Paneldue 1.23.2
        freeram 28636
        • 3dwareundefined
          3dware
          and i can not send a gcode to duet
          • aidarundefined
            aidar
            Hi
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M575_Set_serial_comms_parameters , check S parameter of M575 command.
            • 3dwareundefined
              3dware
              M575 P1
              Channel 1: baud rate 57600, requires checksum
              • aidarundefined
                aidar
                Turn checksum requierment off and try then.
                • 3dwareundefined
                  3dware
                  M575 P1
                  Channel 1: baud rate 57600, does not require checksum
                  now the error still comes
                  • 3dwareundefined
                    3dware
                    I have the problem only with the paneldue 1.23.2
                    I do not have that with the old 1.22
                    • 3dwareundefined
                      3dware
                      I have now switched to a duet ethernet and still have the same errors.
                      Scachiundefined 1 Reply Last reply Reply Quote 0
                      • Scachiundefined
                        Scachi @3dware
                        @3dware said in Checksum errors:
                        I had similar issues. For me the fix was using a shielded cable for the paneldue connection and having the shield connected to the - panel due pin on the duetwifi board. The correct solution for my case should be grounding the whole printer correctly.
                        https://forum.duet3d.com/topic/11104/paneldue-checksum-errors-when-heater-on-or-hand-near-pdue-cable
                          Do you get the checksum errors when the printer is idle, or only when it is printing?
                          • 3dwareundefined
                            3dware
                            Only when the job run
                            • 3dwareundefined
                              3dware
                              And the print job is just finished in the middle of the program. Then the printer can no longer operate and only after a network reset it is reflected
                                Please post a new M122 report when a job has been running and checksum errors have been reported. I am particularly interested in the Hiccup Count. Note, every time you run M122 this value is reset to zero and starts counting again. So start a print, run a job until several checksum errors have been reported, then run M122 and post the results of that command.
                                Also, please post your config.g file.
                                • NAK_3Dundefined
                                  NAK_3D
                                  I am having similar issues with prints just randomly stopping and the printer not functioning till its reset. I am also seeing the same checksum errors.. Has there been any resolution found yet?
                                    droftarts administrators @NAK_3D
                                    @NAK_3D It looks like the OP never responded to @dc42 request, so we haven't been able to track down the bug. Could you?
                                    • NAK_3Dundefined
                                      NAK_3D
                                      Here is the M122 file you requested.. sorry for the lost format..
                                      11:10:44 PM: M122: === Diagnostics ===RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04RC1 running on Duet WiFi 1.02 or laterBoard ID: 08DGM-917DA-G4MSD-6J9DD-3SJ6K-18T39Used output buffers: 1 of 24 (9 max)=== RTOS ===Static ram: 25680Dynamic ram: 94108 of which 372 recycledException stack ram used: 524Never used ram: 10388Tasks: NETWORK(ready,640) HEAT(blocked,1236) MAIN(running,3820) IDLE(ready,160)Owned mutexes:=== Platform ===Last reset 09:11:01 ago, cause: power upLast software reset at 2019-11-03 10:39, reason: User, spinning module GCodes, available RAM 10600 bytes (slot 2)Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414dError status: 0Free file entries: 9SD card 0 detected, interface speed: 20.0MBytes/secSD card longest block write time: 3.7ms, max retries 0MCU temperature: min 21.8, current 32.3, max 33.2Supply voltage: min 23.6, current 24.0, max 24.4, under voltage events: 0, over voltage events: 0, power good: yesDriver 0: open-load-B, SG min/max 0/1023Driver 1: ok, SG min/max 0/1023Driver 2: standstill, SG min/max not availableDriver 3: ok, SG min/max 0/1023Driver 4: standstill, SG min/max not availableDate/time: 2019-11-03 23:10:40Cache data hit count 4294967295Slowest loop: 25.82ms; fastest: 0.08msI2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0=== Move ===Hiccups: 0, FreeDm: 160, MinFreeDm: 106, MaxWait: 131709msBed compensation in use: none, comp offset 0.000=== DDARing ===Scheduled moves: 950081, completed moves: 950041, StepErrors: 0, LaErrors: 0, Underruns: 0, 0=== Heat ===Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1Heater 0 is on, I-accum = 0.0Heater 1 is on, I-accum = 0.5=== GCodes ===Segments left: 1Stack records: 1 allocated, 0 in useMovement lock held by nullhttp is idle in state(s) 0telnet is idle in state(s) 0file is idle in state(s) 0serial is idle in state(s) 0aux is idle in state(s) 0daemon is idle in state(s) 0queue is idle in state(s) 0autopause is idle in state(s) 0Code queue is empty.=== Network ===Slowest loop: 20.65ms; fastest: 0.00msResponder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)HTTP sessions: 1 of 8- WiFi -Network state is runningWiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0WiFi firmware version 1.23WiFi MAC address ec:fa:bc:2d:e6:4bWiFi Vcc 3.41, reset reason Turned on by main processorWiFi flash size 4194304, free heap 25712WiFi IP address 192.168.1.9WiFi signal strength -51dBm, reconnections 0, sleep mode modemSocket states: 0 0 0 0 0 0 0 0=== Filament sensors ===Extruder 0: pos 97.03, ok, measured sens 26.32mm/rev min 61% max 128% over 32898.0mm, errs: frame 7 parity 0 ovrun 0 pol 138 ovdue 0
                                      • NAK_3Dundefined
                                        NAK_3D
                                        Here is my config.g
                                        ; generated by RepRapFirmware Configuration Tool v2.0.4 on Sat Oct 05 2019 18:12:48 GMT-0400 (Eastern Daylight Time)
                                        M550 P"Squire" ; set printer name
                                        M667 S1 ; select CoreXY mode
                                        M552 S1 ; enable network
                                        M587 S"" P"" ; Configure access point. You can delete this once connected
                                        M586 P0 S1 ; enable HTTP
                                        M586 P1 S0 ; disable FTP
                                        M586 P2 S0 ; disable Telnet
                                        M569 P0 S1 ; physical drive 0 goes forwards X
                                        M569 P1 S1 ; physical drive 1 goes forwards Y
                                        M569 P2 S0 ; physical drive 2 goes backwards Z
                                        M569 P3 S0 ; physical drive 3 goes Backwards E0
                                        M92 X200.00 Y200.00 Z69.67 E811.49 ; set steps per mm
                                        M566 X900.00 Y900.00 Z12.00 E900.00 ; set maximum instantaneous speed changes (mm/min)
                                        M203 X18000.00 Y18000.00 Z1000.00 E3000.00 ; set maximum speeds (mm/min)
                                        M201 X1000.00 Y1000.00 Z500.00 E1000.00 ; set accelerations (mm/s^2)
                                        M906 X1000 Y1000 Z2300 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                                        M84 S30 ; Set idle timeout
                                        M208 X-48 Y0 Z0 S1 ; set axis minima
                                        M208 X237 Y305 Z10000000000000000000 S0 ; set axis maxima
                                        M574 Z0 S0 ; set active low and disabled endstops
                                        M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                                        M305 P0 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 0
                                        M143 H0 S110 ; set temperature limit for heater 0 to 110C
                                        M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                                        M106 P1 S0 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                        M591 D0 P3 C3 S0 R68:132 L24.8 E3.0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length
                                          dc42 administrators @NAK_3D
                                          @NAK_3D said in Checksum errors:
                                          Was that M122 run during or immediately after running a print during which checksum errors were displayed?
                                          NAK_3Dundefined 1 Reply Last reply Reply Quote 0
                                          • NAK_3Dundefined
                                            NAK_3D @dc42
                                            @dc42 the M122 was run during a print after several errors had occurred.
