    Finding the MAC address
    2.0k
    • heoconnorundefined
      heoconnor
      M122 just comes back with: Emergency stop! Reset the controller to continue.ok 😕
      • PaulHewundefined
        PaulHew
        Your IT dept could tell you the MAC address if they wanted.
        You could plug it into the network tell them the IP address and they can find the MAC that way.
        Or ask them for an IP address, set it, they can scan and cross reference the IP to the MAC.
        • DocTruckerundefined
          DocTrucker
          MAC address is usually set in config.g.
            DocTrucker
            Run M540
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M540_Set_MAC_address
            Edit: M540 on its own should return MAC address. Read the link to see how to set MAC address.
              A Former User @DocTrucker
              @DocTrucker said in Finding the MAC address:
              Run M540
              aye, that works! didn't see it was specified ethernet, and not sure if it works for the wifi?
                DocTrucker @A Former User
                @bearer Oh yeah, didn't think about the wifi half of the equation!
                  DocTrucker
                  "Note on the Duet 2 Wifi the MAC address is unique and set on the Wifi Module so this command has no effect. The default MAC address on a Duet 2 Ethernet is generated from the unique processor ID so there is normally no need to change it."
                  So trying to set it with M540 won't work. Whether or not it reports the correct address would have to be checked. Can you access your router and confirm from there?
                    OP seems to be on Ethernet so thats okay, I was just curious about the wifi for future reference; ultimately a moot point as M122 doesn't seem include mac address for Ethernet (on the Maestro at least)
                      Phaedrux Moderator @heoconnor
                      @heoconnor said in Finding the MAC address:
                      I think you might have sent M112
                      https://duet3d.dozuki.com/Wiki/Gcode#Section_M112_Emergency_Stop
                      • Danalundefined
                        Danal
                        Via a Windows machine command prompt:
                        C:\Users\Danal>ping 192.168.7.100
                        Pinging 192.168.7.100 with 32 bytes of data:
                        Reply from 192.168.7.100: bytes=32 time=3ms TTL=255
                        Reply from 192.168.7.100: bytes=32 time=36ms TTL=255
                        Reply from 192.168.7.100: bytes=32 time=168ms TTL=255
                        Reply from 192.168.7.100: bytes=32 time=64ms TTL=255
                        Ping statistics for 192.168.7.100:
                            Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
                        Approximate round trip times in milli-seconds:
                            Minimum = 3ms, Maximum = 168ms, Average = 67ms
                        C:\Users\Danal>arp -a 192.168.7.100
                        Interface: 192.168.7.210 --- 0x13
                          Internet Address      Physical Address      Type
                          192.168.7.100         2c-3a-e8-0b-2f-27     dynamic
                          DocTrucker @Danal
                          @Danal neat, copies directly to linux to:
                          doctrucker@BURPSPC:~$ arp -a 192.168.82.1
                          fritz.box (192.168.82.1) at e0:28:6d:bb:41:cc [ether] on enp8s0code_text
                            heoconnor
                            Got it using the M540 - Thanks everyone!!
