    Duet 3: "Attempt to move motors when VIN is not in range" @ 30V
    Beta Firmware
    1.0k
    • evan38109undefined
      evan38109
      I've finally made it to testing out stepper motors with the new Duet 3 6HC. When I try to move one, I get Error: Attempt to move motors when VIN is not in range.
      Voltage is steady at 30V with a Mean Well power supply:
      My quick reading of the code in Platform.cpp:L98 and related sections is that voltages over 29V count as overvoltage and cause the drivers to shut down.
      Is this just a bug, or can the Duet 3 not run at 30V? Or am I doing something else wrong?
      Thanks in advance!
      Diagnostics in case they help:
      M122
      RepRapFirmware for Duet 3 v0.6 version 3.0alpha running on Duet 3 version v0.6
      Board ID: 08DGM-9T66A-G63SJ-6J1FA-3S86Q-TB0HA
      Used output buffers: 1 of 32 (6 max)
      Static ram: 67772
      Dynamic ram: 156184 of which 0 recycled
      Exception stack ram used: 476
      Never used ram: 168784
      Tasks: NETWORK(ready,2044) HEAT(blocked,1276) CanReceiv(suspended,3804) CanSender(suspended,1496) CanClock(blocked,1448) TMC(suspended,632) MAIN(running,4216) IDLE(ready,156)
      Owned mutexes:
      Last reset 00:06:48 ago, cause: power up
      Last software reset at 2019-09-23 04:50, reason: Unknown, spinning module Platform, available RAM 169084 bytes (slot 2)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0442b000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      SD card 0 detected, interface speed: 0.2MBytes/sec
      MCU temperature: min 22.7, current 30.3, max 30.5
      Supply voltage: min 29.9, current 30.0, max 30.2, under voltage events: 0, over voltage events: 0, power good: no
      12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
      Driver 0: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 1: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 2: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 3: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 4: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 5: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Date/time: 2019-09-27 01:42:36
      Slowest loop: 4.90ms; fastest: 0.21ms
      Hiccups: 0, FreeDm: 375, MinFreeDm: 374, MaxWait: 65155ms
      === MainDDARing ===
      Scheduled moves: 2, completed moves: 2, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      === AuxDDARing ===
      Segments left: 0
      Stack records: 1 allocated, 1 in use
      Movement lock held by http
      http* is idle in state(s) 0 8, running macro
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon* is ready with "M122" in state(s) 0
      queue is idle in state(s) 0
      lcd is idle in state(s) 0
      spi is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.05ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 0 of 8
      - Ethernet -
      State: 0
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 51ms ago
      RX/TX seq numbers: 26139/26139
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v1.0.4.1
      Code buffer space: 2048
      Configured SPI speed: 2000000 Hz
      Full transfers per second: 50.63
        A Former User
        Sounds like a bug in the code or the specs; the updated specs say 12-32v https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview
        • Vetiundefined
          Veti
          @evan38109 said in Duet 3: "Attempt to move motors when VIN is not in range" @ 30V:
          i would say its a bug. from the documentation
          VIN in the range 12V-32V must be provided to the Duet.
          • piperswundefined
            pipersw
            I have the same bug with Duet2Wifi@24V, when I do the first movement of a stepper (homing). Does not seen after.
              evan38109
              I tried with a lower-voltage power supply this evening and the steppers move just fine. I'm now reasonably confident that this is a bug.
              (...or maybe I'm missing a voltage setting somewhere? There's always a chance this is my fault. 😉 )
              Is there a preferred method to file a bug report, or is this kind of forum post sufficient?
                T3P3Tony administrators @evan38109
                In this case comments here will be seen by @dc42 so no need to file a bug report on GitHub.
                  It's a bug. That code should be active for the Duet WiFi/Ethernet build but not for the Duet 3 build of RRF. I will fix it in the next beta.
                    evan38109
                    Thank you, @T3P3Tony and @dc42!
                      evan38109
                      I've updated to the latest firmware version, and this issue persists.
                      If it helps, the web app is reporting these versions:
                      Board: Duet 3 version v0.6 (MB6HC)
                      DSF Version: 1.1.0.5
                      Firmware: RepRapFirmware for Duet 3 v0.6
                      3.0beta11 (2019-10-21b1)
                      I don't want to be a jerk, but...any ETA? It's been a month now.
                        dc42 administrators @evan38109
                        Are you certain that it isn't fixed? I put the fix in the source code well before beta 11.
                        • Vetiundefined
                          Veti
                          @dc42 the current v3-dev still has
                          https://github.com/dc42/RepRapFirmware/blob/v3-dev/src/Platform.cpp
                          constexpr uint16_t driverOverVoltageAdcReading = PowerVoltageToAdcReading(29.0); // voltages above this cause driver shutdown
                          • wilrikerundefined
                            wilriker @Veti
                            @Veti said in Duet 3: "Attempt to move motors when VIN is not in range" @ 30V:
                            This constexpr needs to stay for Duet 2 (and possibly other boards as well) - it's the place where it is used that seems to fail for Duet 3 to do the right thing.
                            Manuel
                            My Tool Collection
                            • Vetiundefined
                              Veti
                              but should there not be a constexpr for the duet3 over voltage where it shuts down?
                                I am sorry, there were two places where maximum VIN was enforced, and I only changed one of them. New firmware build coming soon.
                                  evan38109
                                  Awesome -- thanks, @dc42!
                                    You can try the new firmware at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0 if you like. This isn't an official beta, but it's running OK on my test setup.
                                      evan38109
                                      Just tried the firmware from dropbox, and it works like a charm. Thanks for taking the time to put this out on a weekend! 👍
                                      Also -- and I'm sure you get this a lot -- but I can't get over how easy the firmware update was. Kudos.
