    G30 / G28 Bad Command
    430
    • JohnnyCeeeundefined
      JohnnyCeee @Veti
      @Veti
      Yes, all work fine. Pin Down, Pin Up, Selfe Test ON and OFF.
      also the Z Probe value (1000) is displayed in the test
      • Vetiundefined
        Veti
        what is the size in bytes of the deploy and retract script
        JohnnyCeeeundefined 1 Reply Last reply Reply Quote 0
          JohnnyCeee @Veti
          @Veti
          here the whole content of the files
          Deploy:
          ; deployprobe.g
          ; called to deploy a physical Z probe
          ; generated by RepRapFirmware Configuration Tool v2.0.4 on Thu Sep 26 2019 16:26:18 GMT+0200 (Mitteleuropäische Sommerzeit)
          M280 P3 S10 I1
          Retract:
          ; retractprobe.g
          ; called to retract a physical Z probe
          M280 P3 S90 I1
            JohnnyCeee @Veti
            @Veti said in G30 / G28 Bad Command:
            200 Bytes Deploy
            202 Bytes Retract
            • Vetiundefined
              Veti
              can you issue the commands M401 and M402?
                JohnnyCeee @Veti
                Yes, Pin is moving out and in.
                But:
                16:49:18M402
                Error: Bad command:
                16:49:11M401
                Error: Bad command:
                • Vetiundefined
                  Veti
                  there is something wrong with your deploy and retract scripts.
                  delete everything and type the commands per hand
                  JohnnyCeeeundefined 2 Replies Last reply Reply Quote 0
                    JohnnyCeee @Veti
                    now this happend.
                    if i type M280 P3 S10 I1 it works. But M401 not
                      JohnnyCeee @Veti
                      @Veti
                      this is my library
                      • fcwiltundefined
                        fcwilt
                        Delete the probe files and create new ones with just the M280 command,
                        Perhaps there is something in the existing file that is causing the problem.
                          JohnnyCeee @fcwilt
                          @fcwilt
                          Same problem
                          M401
                          Error: Bad command: M280 P3 S10 I1
                          Their is only the M280 command in the file.
                            JohnnyCeee
                            Okay. now it works fine.
                            I deleted all again and created again. Thank you very much!!
