    RepRapFirmware 3.0 first official beta is out
    Beta Firmware
    15
    132
    9.4k
    • smoki3undefined
      smoki3 @dc42
      @dc42 said in RepRapFirmware 3.0 first official beta is out:
      The Homing Failed message means that the homing switch was not triggered before the move completed. If using stall detection, it means no stall was detected.
      But it is detected because it move to the end position and then it do the rest of the script (move a bit away from the end position end so on). Otherwise the printer should crash normally because it have to go another 400mm if the stall is not detected
        T3P3Tony administrators @kraegar
        @kraegar please try 1.0.4.0 @chrishamm believes this is fixed
        kraegarundefined 1 Reply Last reply Reply Quote 0
        • kraegarundefined
          kraegar @T3P3Tony
          @T3P3Tony Will do, thanks for the quick update @chrishamm!
          • kraegarundefined
            kraegar
            Looking much better so far!
            • smoki3undefined
              smoki3
              As you can see here the drivers are detecting the stall very well.
              https://photos.app.goo.gl/DMTiBbvibGsSs42Y7
              But it looks like the signal get not processed correctly.
              smoki3undefined 1 Reply Last reply Reply Quote 0
              • kraegarundefined
                kraegar
                Testing yesterday and today has so far shown 1.0.4.0 to be stable, and fixed the quality issue that cropped up in 1.0.3.5
                • smoki3undefined
                  smoki3 @smoki3
                  @smoki3 said in RepRapFirmware 3.0 first official beta is out:
                  If I put a G92 X"xx.xx" in the homing scipt than it is working as it should
                  • stewwyundefined
                    stewwy @wilriker
                    @wilriker , any chance I can look at your duet2 config files for RRF3, your machine is close to mine and I'm just getting ready to try RRF3?
                    • wilrikerundefined
                      wilriker @stewwy
                      @stewwy Yeah, no problem. I can provide it to you tomorrow. But be warned the post I link to in my signature is a bit outdated.
                      Manuel
                      My Tool Collection
                      • kintaundefined
                        kinta
                        This post is deleted!
                        • stewwyundefined
                          stewwy
                          Hi, could someone look at these, from my config.g and see if they are correct for RRF3?
                          M574 X1 S1 P"xstop" ; X home to min.
                          M574 Y2 S0 P"ystop" ; Y home to max. N0pen micro-switches.
                          M574 Z1 S2 P"zprobe.in" ; Define Z to use DC42 irProbe. Home to Min.
                          ;ZProbe
                          M558 P1 C"zprobe.in" H3 F600 T6000 X0 Y0 Z1 ; Set Z probe type/mode 1. Not using on XY, but using it on Z. F400 dive speed T6000 travel speed
                          G31 P500 X15 Y-2 Z1.46 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                          M671 X-50:325 Y110:110 S0.5 ; Leadscrew positions for bed tramming
                          Thanks in advance
                          Edit: I should mention I am using 2 motors for Z
                          • triumphantdukeundefined
                            triumphantduke
                            @dc42 please don't take this the wrong way, but just for some planning purposes.. when do you think the next release will be out? 😁🎁
                              dc42 administrators @triumphantduke
                              @triumphantduke said in RepRapFirmware 3.0 first official beta is out:
                              Soon, perhaps tomorrow.
                              triumphantdukeundefined 1 Reply Last reply Reply Quote 1
                                dc42 administrators @stewwy
                                @stewwy said in RepRapFirmware 3.0 first official beta is out:
                                ;ZProbe
                                Thanks in advance
                                If you are using G30 commands to home Z in your homing files, you should remove the M574 Z command, because you have no Z endstop switch.
                                  triumphantduke @dc42
                                  @dc42 haha okay, standing by eagerly 🙇
