Precision piezo auto bed compensation issues. Please help.
821
    PeterA
    Hi.
    So I’ve fitted the Piezo and have my printer homing as it should. It triggers perfectly and homes great. Then my problems start. If I run the Auto bed compensation from the web interface it pushed the nozzle into the bed, about 3-5mm. The Piezo triggers (blue led comes on as it touches the bed) but it carries on down 5mm or so then gives the error: Error: Z probe was not triggered during probing move
    If I use the G30 command from the counsel it does the same except it try’s to find each corner, each time pushing the bed down. I can see that the piezo triggers when it touches the bed (blue led on the piezo comes on) but it ignores that. The error at the end is: G30 Error: Z probe was not triggered during probing move
    I am lost can anyone advise?
    Config.g has this in it.
    ; generated by RepRapFirmware Configuration Tool on Mon Dec 24 2018 18:36:17 GMT+0200 (South Africa Standard Time)
    ; M550 P"TEVO BLACK WIDOW"
    M550 P"PETERS TEVO BLACK WIDOW" ; Set machine name
    M552 S2 ; Enable Network in Acess mode
    ;M552 S1 ; Enable network In Normal WiFi Mode
    M589 S"TEVOBWDO" P"POIUYTRE" I10.5.0.19 ; Configure access point. You can delete this line once connected
    ;M587 S"Tech5_753CE0_EXT" P"landeach108" ; Configure access point. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0
    M569 P1 S0 ; Drive 1 goes backwards
    M92 X80 Y80 Z1600 E448 ; Set steps per mm
    M566 X700 Y700 Z12 E10 ; Set maximum instantaneous speed changes (mm/min)
    M203 X2000 Y2000 Z500 E1200 ; Set maximum speeds (mm/min)
    M201 X500 Y500 Z300 E200 ; Set accelerations (mm/s^2)
    M906 X1050 Y1050 Z1000 E1050 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S10 ; Set idle timeout
    M208 X335 Y250 Z270 S0 ; Set axis maxima
    M574 X1 Y1 Z1 S0 ; Set active low endstops
    ;M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
    M557 X0:335 Y0:240 S20 ; Define mesh grid
    ;Piezo settings
    M558 P5 I1 R0.4 F300 X0 Y0 Z0
    G31 X0 Y0 Z-0.1 P500
      Veti
      @PeterA said in Precision piezo auto bed compensation issues. Please help.:
      you configured z as an endstop rather than a probe
        PeterA
        @Veti said in Precision piezo auto bed compensation issues. Please help.:
        M574 Z1 S2
        Thanks for helping,
        I put the M574 Z1 S2
        in my file, but now it drills down into the bed. ;(
        I tried this as well
        M574 X1 Y1 S0
        M574 Z1 S2
        Didn't get to the auto mesh as it drills down when homeing. Is the config.g the right place to put this?
          grizewald
          I use the Orion on my CoreXY printer. It works very nicely!
          In my config.g I have the following to set up the probe and grid, the Orion is connected to the Z-probe input on the Duet WiFi:
          M574 Z1 S2 ; Z end stop is probe at low value
          M558 P8 R0.4 I1 H5 F360 T6000 ; Set Z probe type to inverted, unfiltered piezo and the dive height + speeds
          G31 P500 X0 Y0 Z-0.015 ; Set Z probe trigger value, offset and trigger height
          M557 X5:290 Y5:275 P14 ; Define mesh grid
          When I home Z, my homez.g macro contains:
          G91 ; relative positioning
          G1 Z5 F360 S2 ; lift Z relative to current position
          G90 ; absolute positioning
          G1 X148 Y140 F6000 ; go to homing probe point
          ; Lift Z again after probing
          G1 S2 Z5 F360 ; lift Z relative to current position
          And when I create a new levelling mesh, I have a macro which does this:
          M291 P"Do you really want to create a new levelling mesh?" R"Create Levelling Mesh" S3
          G28 ; Home all
          G91 ; Set relative positioning
          G1 Z50.0 F360 ; Move the platform down to save cooking things
          M291 P"Heating, don't go away!" R"Create Levelling Mesh" S0 T5
          M104 S130 ; Start heating extruder
          M190 S75.0 ; Heat bed and wait for it to reach temperature
          M109 S130 ; Wait for extruder to reach temp before proceeding
          M291 P"Make sure head is free from plastic and press OK" R"Create Levelling Mesh" S2
          G29 S2 ; clear any current levelling map
          M561 ; clear any bed transforms to start levelling from scratch
          G28 ; Home all (also does three motor Z plane correction)
          G29 S0 ; Do mesh probing, save and activate results
          G1 Z50.0 F360 ; Move platform down
          M104 S0 ; hot end heater off
          M140 S0 ; bed heater off
          M291 P"Finished!" R"Create Levelling Mesh" S0 T5
          When printing, I put G32 in my start g-code in the slicer. Instead of having G32 create a new levelling mesh via bed.g, I first make sure that the bed and hot end are heated to the same temperature as I used when creating the levelling mesh, then G32 makes bed.g run which merely does this:
          G29 S2 ; clear any currently active mesh
          G29 S1 ; Load heightmap.csv and activate it
          undefined 1 Reply Last reply 10 Oct 2019, 12:50 Reply Quote 1
            PeterA @grizewald
            @grizewald
            Hey thanks for that. I’m not at the printer till tomorrow now but I will defiantly try a few of those settings.
            Keep my fingers crossed as I've spent hours trying to solve it.
            I'll let you know how it goes.
            undefined 1 Reply Last reply 10 Oct 2019, 13:25 Reply Quote 1
              grizewald @PeterA
              @PeterA My settings should work fine for you. The important things are that the probe is defined as such and not as an end stop, as Veti pointed out. Also that your probe is connected to the Z-probe input and not an end-stop input.
              I've actually refined my solution even more. I noticed that the way my print bed deforms is very temperature dependent. It's much more flat at higher temperatures, so I now have two macros to create a levelling map - one at 55C and the other at 75C. So I have two maps to choose between and I use filament specific G-codes in my slicer to load the correct map depending on if I'm printing PLA or PETG/nylon.
              You should also check that your probe triggers properly. If I've replaced a part or worked on my hot end mount, I always double check that the probe is working as expected before homing or doing anything that depends on the probe. I've found that just tapping the nozzle from underneath with a fingernail should always make the blue LED blink on and the red LED go off for a moment. If that happens and the configuration is correct then I know that probing from 5mm height with a speed of 6mm/s will always result in the probe triggering
              Good luck!
                PeterA
                Still problems.
                My piezo wors as it it triggers great. Red led on, touches bed blue flashes and when homing it works.
                When using home all or home z it works beautifully with the homez.g settings bellow. however my config.g has to have this line
                If I put M574 Z1 S2
                Then when homing it pushes down into the bed.
                The problem is trying to set it on auto mesh, the z triggers (blue light as touches the bed) but it pushed down at least 5mm. The error is as before Error: Z probe was not triggered during probing move But I can see it was and when normal homing it triggers and works correctly.
                The auto mesh starts and homes, triggers great and sets itself, then it moves on to the first point and moves down onto the bed, blue light triggers as before, but it goes down a further 5mm.
                I’ve tried @grizewald settings but it drills down into the bed on homing unless I change the m574 to z1 s0. Then back to the original problem. Homing then works but everything else drills down into the bed.
                My homez.g
                ;G31 Z0 P1000 ; peters attempt and the piezo
                G1 Z3 F800 S2 ; lift Z relative to current position
                G1 S1 Z-275 F400 ; move Z DOWN until the endstop is triggered
                G1 Z2 F300 S2 ;LIFT Z FOR SECOND PROBE
                G1 S1 Z-5 F80 ; move Z DOWN until the endstop is triggered
                G92 Z-0.2 ; set Z position to axis minimum (you may want to adjust this)
                undefined 1 Reply Last reply 11 Oct 2019, 07:44 Reply Quote 0
                  PeterA
                  is there any way the wireing could be wrong with the red light on and the blue light triggering? It doesn't seem logical but I'm lost.
                    grizewald
                    Post your entire config.g, homeall.g and bed.g
                    Can you confirm that your Orion is connected to the port labelled "Z Probe Header" in this picture?
                      grizewald @PeterA
                      Still problems.
                      If I put M574 Z1 S2
                      My homez.g
                      Your homez.g is using the probe as an end stop and not as a probe. If you look again at my homez.g you will see that I use the command G30 to home the Z axis. G30 means "probe the bed". You are telling the printer that you are using a Z end stop and not a Z probe.
                      You must configure the probe as a probe and use it as a probe. It is not an end stop!
                        PeterA
                        @grizewald said in Precision piezo auto bed compensation issues. Please help.:
                        G32
                        Holy Cow!! How backward can I be. My wires are connected to the endstop. Thanks for the picture, with out it I would have been convinced we where talking about the same thing.
                        I've just redone it now and started the mess. Looks like its working.
                        Many Many thanks. You've been a huge help.
                        undefined 1 Reply Last reply 11 Oct 2019, 09:17 Reply Quote 1
                          grizewald @PeterA
                          G32
                          My pleasure!
                          4 out of 12
