    Looms
    436
    • becky9undefined
      becky9
      Whats are peoples thoughts about wiring looms?
      I hate the mess of cables, and would much rather have a loom on the printer, a loom on the duet and one or two connectors that link them. Looking at 2 x 24 pin molex at the moment. Will make it really easy swappping boards out between printers too. x
      • Vetiundefined
        Veti
        there are some people on the forum who used cat 5/6 cables to reduce the number of wires.
        i used a nylon sleeve from an old atx power supply to make the cables neat.
        • oliofundefined
          oliof
          Additional connectors introduce additional failure points, so it's a tossup between convenience and reliability. Add more connectors for tool changer / quick change and any search for a bad connection becomes a long ordeal rather than checking both ends of a cable.
          Tidy wire routing on the other hand is an underappreciated form of craftsmanship (-:
          becky9undefined 1 Reply Last reply Reply Quote 0
          • becky9undefined
            becky9
            I tried Cat 5 but didn't like the bulk.
            A standardised loom would be cool, be like having a plugin ecu, that could be whipped in and out easily.
            • becky9undefined
              becky9 @oliof
              @oliof said in Looms:
              Yes indeed on both counts!
                The Duet 0.6 had a header for a wiring loom, 40 pin AFAIR, but it never took off so it was dropped in subsequent Duets.
                For Duet 3 we've made some prototype tool head boards, so that only power and CAN bus need to go to the tool instead of 10 to 16 wires.
                • becky9undefined
                  becky9 @dc42
                  @dc42 Yes I saw the tool boards and the Duet3 at TCT and I want them!!! 🐵
                  • EasyTargetundefined
                    EasyTarget
                    I use several different sizes of this:
                    https://www.canford.co.uk/TECHFLEX-BRAIDED-SLEEVING-Split-Spring-Wrap
                    (from a differnt supplier but these guys look much cheaper 🙂 )
                    All my external wiring on the Printer and CNC uses this and the effect is great.
                    For the Delta's main loom I use a softer and more flexible version (sorry, no link) and it is really nice being able to carefully re-run a single cable without disturbing the rest.
                    Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
                    PrintPy2024 to the rescue!
                    MicroPython based; with simple wiring and and no custom PCB.
