    run out sensor
    Filament Monitor
    717
    • tdybare69undefined
      tdybare69
      i would like to ask for help again. y'all were so very helpful getting my bl touch working maybe y'all can help with run out sensor. i got it to work by doing what M591: Configure filament sensing says to do. problem is that when i pull the filament out of the sensor it does an emergancy stop, not a filament change, or pause. here is my file setup , any ideas?
      M574 X1 Y1 Z1 S0 ; set active low and disabled endstops
      M581 E0 T0 S0 C0 ; invoke trigger 1 when rising edge is detected on the E0 endstop input and a file is being printed
      M591 D0 P2 C3 S1 ; sensor drive 0 is connected to EO endstop input, enabled
      • aidarundefined
        aidar
        Hi. Your M581 T0 parameter means you invoke trigger 0, that is emergency stopp. See https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_Configure_external_trigger
        tdybare69undefined 1 Reply Last reply Reply Quote 0
          A long time ago, before we introduced the M591 command, we suggested using M581 to implement filament run out detection. Now we have M591 to configure it. So you should remove the M581 command.
          tdybare69undefined 2 Replies Last reply Reply Quote 0
            tdybare69 @aidar
            @aidar i read that,i tried T1 and it doesn't work at all.
              tdybare69 @dc42
              @dc42 thank you.
                tdybare69 @dc42
                @dc42 i took the 581 out, and it doesnt work at all now.
                  What type of filament run out detector is it, and which firmware version are you running?
                    tdybare69
                    sunhokey firmware version 2.03
                      tdybare69
                      sunhokey sensor. firmware2.03
                        @tdybare69 said in run out sensor:
                        sunhokey
                        When you run M591 D0 to report the filament sensor status, does it report the correct present/not-present status?
                          tdybare69 @dc42
                          @dc42 i don't know what you mean about report. i put it in the firmware ,then run the extruder and pull the filament out by hand
                            T3P3Tony administrators @tdybare69
                            @tdybare69 send M591 D0 in the console and look at the response, then try again with the filament present and see if there is a difference.
                              tdybare69
                              Simple filament sensor on endstop 3, disabled, output high when no filament, filament present: yes. with the filament out.
                              Simple filament sensor on endstop 3, disabled, output high when no filament, filament present: no. with the filament in.
                                So the logic is reversed. change the M591 command to be M591 D0 P1 C3 S1 as show here:
                                https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
                                Pnn Type of sensor: 0=none, 1=simple sensor (high signal when filament present), 2=simple sensor (low signal when filament present), 3=Duet3D rotating magnet sensor, 4=Duet3D rotating magnet sensor with microswitch, 5 = Duet3D laser sensor, 6 = Duet3D laser sensor with microswitch, 7 = pulse-generating sensor
                                  tdybare69
                                  Thanks, changed it to that got this reading, but does not stop when i pull the filament out while its extruding.
                                  Simple filament sensor on endstop 3, enabled, output low when no filament, filament present: yes. while the filament is in.
                                  Simple filament sensor on endstop 3, enabled, output low when no filament, filament present: no. while the filament is out.
                                    tdybare69 @tdybare69
                                    @tdybare69 THIS IS WHT MY CODE LOOKS LIKE.
                                    M591 D0 P1 C3 S1 ; sensor drive 0 is connected to EO endstop input, enabled, trigger M83
                                      @tdybare69
                                      sorry about the caps
                                        droftarts administrators
                                        I think the way your are testing it is flawed; from M591
                                        Note that filament monitoring in RRF is only active when printing from SD card.
                                        So you probably need to create a short test gcode file with a number of extrude commands in it, run that, and pull the filament out.
                                          tdybare69
                                          your right. i ran a gcode print on small item cut the filament. it worked. thank you
