Solved Error: M280: Invalid servo index 0 in M280 command
I forgot a couple of things:
What version of firmware are you using?
Does the slicer profile specify the use of M420?
Yes thanks. Ive looked at the other files but cant see anything. I have no idea.
Firmware Version: 2.03RC4 (2019-05-29b4)
WiFi Server Version: 1.23
Web Interface Version: 1.21.2-dc42
Web Interface by Christian Hammacher
Licensed under the terms of the GPL v3; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool on Mon Dec 24 2018 18:36:17 GMT+0200 (South Africa Standard Time)
G91 ; relative positioning
G1 Z2 F1000 S2 ; lift Z relative to current position
G1 S1 X-340 F2000 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F2000 ; go back a few mm
G1 S1 X-340 F360 ; move slowly to X axis endstop once more (second pass)
;G1 Z-2 F1000 S2 ; lower Z again
G90 ; absolute positioning -
What slicer are you using?
Various slicers have the ability to specify to use/not user certain gcode commands.
@fcwilt Cura
Can see any extra codes? -
Zip up the gcode file you are trying to print and post it here.
It would seem to be the only place left to look.
Sure thank you.
TBW_overboost wheels draft.cad
Just rename the file extension from cad to zip -
@PeterA ok I see it in the compiled gcode from cura.
M280 P0 S160 ; release BLTouch alarm (OK to send for Non BLTouch)
M420 Z2 ; set fade leveling at 2mm for BLTouch (OK to send for Non BLTouch)
G28 ; home all
G29 ; probe bedNow to find the file in cura and delete that, cause its not in the start up gcode box
thank you for your help
I would think that somewhere in Cura there are settings you can change to control the generation of those bits of gcode.
What version of Cura are you using?
@fcwilt its 4.3.0
Do you have your cura settings properly set up to generate reprap code? It’s looking like marlin output. Check your main settings in cura.
@Nuramori said in Error: M280: Invalid servo index 0 in M280 command:
sorry been hecktic busy. Thank you for your advice. I will try see what my Cura is set up to use.
