Firmware retraction wipe settings
Is there anyway to set a wipe setting with firmware retraction? Slic3r has it greyed out when firmware retraction is enabled.
for wiping you would need to know about the model that you are printing in order to wipe somewhere.
the duet only executes the g code in the file line by line and has no concept of where it could wipe.
Thanks for the information
Configuring pressure advance should eliminate the need for wipe anyway.
