Solved Hotend faulting
@larabe said in Hotend faulting:
The only thing not happening are the heaters, they will not energize, no voltage or amperage output.
you have verified that with a multimeter?
@Veti
Yes I have as i thought the led might have failed. -
when you checked with the other board. did you move everything over, including the sd card?
@Veti
I copied the sd card from the working V1.04 to this board so they would be the same settings. -
ok lets check the mosfet.
check that there is 5V between the MOSFET gate and source pins when the heater is turned on, and 0V when off.
@Veti
I will give it a try. -
@Veti
I only get 0's. -
only get 0's.
i think that means the mosfet has failed. but post your config.g to rule out a misconfiguration.
; generated by RepRapFirmware Configuration Tool v2.0.4 on Wed Oct 16 2019 09:01:29 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M584 X0 Y2 Z1 E3 ; set drive mapping
M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
M208 X300 Y300 Z375 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z2 S0 ; set active low and disabled endstops; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequAency. Thermostatic control is turned on; Tools
M563 P1 S"EXTRUDER" D0 H1 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1B4138 is the default and most likely wrong for your thermistor
you are configuring heater 1 but connected the wires to heater 2.
@Veti
Had tried using heater 2, but went back to heater 1. Will check thermistor settings, but these settings were from the configuration tool. -
yes but you have to enter the correct ones yourself. B4138 is the default value.
the configuration tool had no way of knowing which thermistor is on your printer.another check. you are selecting tool 0 using gcode T0 before doing any tests?
@Veti
apparently the B value should be 3950. will try this and retest.
Thankyou. -
Thankyou.that was a side note. a wrong value will just result in the wrong temperature of the thermistors.
@Veti
ok so this doesn't resolve the 0 power to heaters. -
@larabe please answer the question above, posed again here:
Please also post a screenshot of Duet Web Control, so we can see the terminal/console, where you enter T0, and the fault condition.
@elmoret
The wifi does not function on this board, so i am unable to use web control. Tool selection was set up in the configuration tool. -
@elmoret
Also I am using usb connection with simplify 3d software. -
what have you done to counter the grounding loop that you are creating?
https://duet3d.dozuki.com/Wiki/USB_ground_loops -
@elmoret
The wifi does not function on this board, so i am unable to use web control. Tool selection was set up in the configuration tool.You stated: “please note everything on the board works except the extruders.”
It will be difficult to help you without accurate information about things.
You still have not answered the question about T0.
