Solved Hotend faulting
@larabe said in Hotend faulting:
T0 was set up in the configuration tool.
this is not reflected in your config
@Veti
Quote from Duet3D "mitigating the problem" USB ground loops
Pass the USB cable a few times through a ferrite ring, or use a USB cable that has a ferrite ring fitted already, or buy a split ferrite bead and clamp it over the lead. This mitigates the effect of ground transients. -
thats only mitigation. what is wrong with your wifi anyway?
@Veti
Don't know what to say, Board was working one day and then not the next and i hadn't touched the config.g file. -
@larabe
what is the error message that you are getting from the wifi modul? -
@Veti
I was not able to get wifi going at all so proceeded to use usb while i tried to get the wifi going.
of three boards i have this is the only one I cannot get connected to wifi. -
@Veti
this site cannot be reached. -
that is not an output from the wifi modul.
@Veti
How do I get output from the output module?
Thankyou. -
The question about T0 is still unanswered. Without selecting a tool, your hotend will not heat.
@Veti
Sorry had a major brain fart. wifi now working.
thankyou.Now let me work on tool selection then i will check back in.
@elmoret
Will work on tool selection and then be in touch.
thank you. -
@Veti
Nice, good progress!
@elmoret
Everything now is working fine.
Please accept this appology from a cranky old man who should have checked the basics. Also a heart felt thankyou for your help , patience, and expertise.
Larry
