    Job status by filament usage
    Firmware wishlist
    15
    54
    3.3k
      dc42 administrators @robm
      @robm said in Job status by filament usage:
      gnydick believes the time to finish estimation based on filament usage became less accurate after a recent firmware update.
      Can you link to the post where he says that?
      msbailly thinks that the filament usage counter employed for that estimate is off because it counts retractions but not the return from retraction.
      If that were the case, the filament used so far that is reported just before the print finishes would be much less than the filament usage reported by the slicer. I haven't noticed that happen, but I'll watch it carefully in my next print.
      It's also possible that the slicer has the opposite bug, i.e. in reporting the filament needed it counts re-prime moves but not retractions. If a slicer has this bug, I'm not sure than anyone not running RRF would notice it.
      One thing that might throw off the calculation is if firmware retraction is used and in M207 the re-prime amount is set differently from the reaction amount. This will obviously cause the filament consumption to be different from the amount reported by the slicer, and I don't think RRF allows for that. Again, the opposite bug could affect the slicer if it doesn't take account of the "extra restart distance".
        I watched the figures given by DWC for my latest print as it approached the end. The filament-based estimated end time remained fairly accurate and converged to zero time remaining at the end of the print. The filament usage count at the end tallied exactly with the expected usage count as far as I could tell, certainly within 1mm. This was on a print sliced by S3D version 4.0.0 and not using firmware retraction.
        If there really is a problem in RRF in this area, I need more information so that I can reproduce it; for example a sample GCode file along with config.g settings that will enable me to replicate it.
          PS - one thing I noticed during testing is that if you turn the printer off in the middle of a print and then resurrect it, the print times are inaccurate. This is because the resurrection data doesn't include the amount of filament consumed, so it counts from zero again. I'll make a note to fix this.
          • gnydickundefined
            gnydick @dc42
            @dc42 sorry I've been away, @dc42 . The prusa slicer bug is what I'm referring to. The DWC shows nothing for filament usage.
            When was that fixed?
            dragonnundefined dc42undefined 2 Replies Last reply Reply Quote 0
            • dragonnundefined
              dragonn @gnydick
              @gnydick said in Job status by filament usage:
              Did you read what dc42 has written? Please post a sample g-code file with this problem and config.g. And maybe M122 response because I use Prusa Slicer too and don't have any problems with filament usage.
                dc42 administrators @gnydick
                There is an entry for Prusa slicer in the version 2.03 section of the whatsnew file. Is that the one you mean?
                • chas2706undefined
                  chas2706
                  • chas2706undefined
                    chas2706
                      dc42 administrators @chas2706
                      Firmware version?
                      • chas2706undefined
                        chas2706
                        Its a Duet Ethernet on version 2.02RTOS. Luckily I have a camera so I can guestimate myself.
                          @chas2706 said in Job status by filament usage:
                          Please try 2.04RC4.
                          • chas2706undefined
                            chas2706
                            Ok thanks I will try it out later and let you know.
                              droftarts administrators
                              "Recognise filament usage comment in Prusa slicer" was added in RRF 2.03.
                              If you're going to update, don't forget to check through the What's New document to see how changes to the firmware may effect your configuration. And back up your existing, working config, so you can revert to it if necessary.
                              • chas2706undefined
                                chas2706
                                Ok will do, thanks for that.
                                • chas2706undefined
                                  chas2706
                                  Just Updated to 2.04RC4 and everything looks good.
                                  Many thanks.
                                    Many thanks.
                                    Thanks for the confirmation!
