    Job status by filament usage
    Firmware wishlist
    15
    54
    3.3k
    • gnydickundefined
      gnydick @dc42
      @dc42 sorry I've been away, @dc42 . The prusa slicer bug is what I'm referring to. The DWC shows nothing for filament usage.
      When was that fixed?
      dragonnundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • dragonnundefined
        dragonn @gnydick
        @gnydick said in Job status by filament usage:
        Did you read what dc42 has written? Please post a sample g-code file with this problem and config.g. And maybe M122 response because I use Prusa Slicer too and don't have any problems with filament usage.
          dc42 administrators @gnydick
          There is an entry for Prusa slicer in the version 2.03 section of the whatsnew file. Is that the one you mean?
          • chas2706undefined
            chas2706
            • chas2706undefined
              chas2706
                dc42 administrators @chas2706
                Firmware version?
                • chas2706undefined
                  chas2706
                  Its a Duet Ethernet on version 2.02RTOS. Luckily I have a camera so I can guestimate myself.
                    @chas2706 said in Job status by filament usage:
                    Please try 2.04RC4.
                    • chas2706undefined
                      chas2706
                      Ok thanks I will try it out later and let you know.
                        droftarts administrators
                        "Recognise filament usage comment in Prusa slicer" was added in RRF 2.03.
                        If you're going to update, don't forget to check through the What's New document to see how changes to the firmware may effect your configuration. And back up your existing, working config, so you can revert to it if necessary.
                        • chas2706undefined
                          chas2706
                          Ok will do, thanks for that.
                          • chas2706undefined
                            chas2706
                            Just Updated to 2.04RC4 and everything looks good.
                            Many thanks.
                              Many thanks.
                              Thanks for the confirmation!
