    Add laser for duet2 wifi
    Laser Cutters
    5.0k
    • EasyTargetundefined
      EasyTarget @yaman
      @yaman said in Add laser for duet2 wifi:
      SO I have to make this PCB board ?
      You can do, yes. Though possibly with less whitespace around it.
      It's an idealised circuit, but it provides a clean 5v PWM signal to the laser, which is good and has an interlock to stop the laser blipping full power during powerup.
      is it possible to use heater 6 PWM
      I dont know much about the expansion board. If it is a 5V signal then yes!
      But if it is a 24v heater output, no.
      Edit; looks good, thanks @T3P3Tony
      The issue here is that common laser modules set their PWM line to 5V and expect the controller to then pull that to 0v for the off part of the PWM cycle. This 5V is enough to damage the Duet if you put it directly on a controller pin. You need some sort of buffer between the two.
      In the circuit above this is done by the 74HCT020, which is a 5V logic chip, but will trigger with the 3v3 signal from the duet too. It's also fast and transmits a clean signal.
      There are quite a few options, you can possibly get a circuit like the one above from aliexpress etc already. Though it's not a complex one to build if you know how. Another great option is an optoisolator. But you lose the 'blip' protection.
      I'd suggest more research, try searching on more general topics like 'how do I control a 5V pwm laser module with a 3v3 controller', etc.
      A 'hidden' advantage of the circuit above is that, unlike many transistor/mosfet pwm drives which have internal capacitance, the 74HC chip produces a very clean signal. for the laser. And this is an advantage for lasers like ours.
      edit: Another great reason to use the expansion card solution..
      • once you have it working, try a fairly low PWM frequency (like 100 Hz. low) and 50% PWM cycle (power), this is when the 15/8W modules are 'pulse' cutting, you can do this continuously and get good results so long as your feedrate is slow (or you get a row of dots). There are a bunch of videos about this on youtube and elsewhere too, part of the secret is a clean PWM signal. I get good results, it's much more powerful at this sort of engraving than my 5W unit is at 100%.
      Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
      PrintPy2024 to the rescue!
      MicroPython based; with simple wiring and and no custom PCB.
      yamanundefined 1 Reply Last reply Reply Quote 2
      • yamanundefined
        yaman @EasyTarget
        @EasyTarget
        thanks for your replay
        I like to buy circuit then make one
        I found everywhere I look this things
        1- PWM Laser Power Output Regulator/Frequency&Duty Adjustable
        2-EleksMaker® PWM To TTL Transition Module
        My laser is PWM and TTL
        so any suggestions ?
        EasyTargetundefined 1 Reply Last reply Reply Quote 0
          EasyTarget @yaman
          I can appreciate that 🙂
          This is not what you want. It is a standalone controller for when you are using the laser on a bench etc. It creates the PWM/ttl signal itself. The specs say it has a serial control (but I don't see that in the pictures) which could make it useful for some cnc stuff. But not for the Duet; serial control is nowhere near fast enough for our use.
          This looks more like it! so long as it can be driven from a 3.3v input. The eleksmaker controller is 5v, but this adaptor might be fine with 3.3v too. If so, it looks like exactly what you want.
          • its late here, I'll try and find time to look at this properly (find the circuit or something) before Monday.
          • in the meantime here is a thread that may prove educational about this module:
            https://github.com/openfab-lab/toolsDocs/issues/13
          That is also good to know, it means the 'PWM pin should be properly driven both high and low (TTL PWM) for best results. Non TTL PWM only pulls the pin low, it has to be pulled back high by a resistor and for this reason can be a little bit less precise in timing; I've seen this discussed to death in CNC forums.
          This explains things nicely too.
          If you have money to burn, order one of those modules so that it is on the way.. I'm pretty sure it is a good plan but wont be held responsible if not.
          PS: Nederlands?
          nicolasdb created this issue in openfab-lab/toolsDocs
          open laser module TTL vs PWM #13
          yamanundefined 2 Replies Last reply Reply Quote 1
          • yamanundefined
            yaman @EasyTarget
            @EasyTarget said in Add laser for duet2 wifi:
            Nederlands
            Ok let's burn some money and see if will work 🤞 🤞 🤞 🤞 🤞
              EasyTarget
              @yaman Sorry for not getting back earlier, I still think this card will suit your needs.
              I've just spent all week fitting a 32bit 3.3v controller to my cnc/laser rig (not a Duet, something based on a 7 Euro ESP32 NodeMCU module) , this and the above discussion has me a bit over-focused on laser driving from 3.3v. systems.
              The laser on my upgraded rig is a 5.5W unit with a pure TTL input. I'm lucky, it can simply be wired to my controller directly; the float voltage on this pin (measured) is 3.27v, and it is high-impedance meaning it does not absorb or supply any real power, it simply follows the voltage. Switch on voltage is around 1.5V . I can simply connect this to the relevant pin of the ESP module.
              I'm also going to put my 8/15W unit into a new machine with a big bed (fabric/leather cutting and decorating is the main goal) but have not worked out the specifics of this yet, it's somewhat low priority, and whatever I do will be a full custom solution. For your application I think a unit like you are getting is ideal.
              yamanundefined 1 Reply Last reply Reply Quote 1
              • yamanundefined
                yaman @EasyTarget
                @EasyTarget
                thanks for reply
                II am Waiting for my shipping to arrive (right now in SHANGHAI, Arrival at outward office of exchange)
                and I wish you luck with your project with ESP32 ☺
                until it's arrive I want to know
                is there any specific command i have to add to connect the laser in config file ?
                • yamanundefined
                  yaman @EasyTarget
                  @EasyTarget
                  so after Received the part and test
                  it won't work
                  it's just convert PWM to TTL ONLY
                  the DC plug it's just for test the Laser If it work or not
                  so we back to Square 0
                  Right now I thinking to use mosfet Or make the the 74HCT02D
                  • Danalundefined
                    Danal
                    I know you want to buy a circuit... nonetheless, you might want to try this, it can be built for a few cents, and no board:
                    Note the original diagram shows 13V in. 24V in (from the heater 6 connector) will require NO changes.
                    It also shows 3.3V out. For five volt out, change the 150K and 39K in the lower right to 100K and 100K.
                    This is "old school" analog conversion. It will not make the signal any cleaner, but it won't make it any worse, either, in that nothing in that diagram has a limited switching speed.
                    • yamanundefined
                      yaman
                      @Danal said in Add laser for duet2 wifi:
                      thanks Danal for your Replay ☺
                      I think this circuit is easy to build
                      here you can see the change I make for heater 6-7
                      EasyTargetundefined Danalundefined 2 Replies Last reply Reply Quote 0
                        EasyTarget @yaman
                        it won't work
                        I'm sorry for putting you off-course with this, I see what you mean about the DC power port being for testing; I'd assumed that was the principle power port, my apologies.
                        Your values and @Danal 's circuit look much more suitable. And easy to source all the parts for.
                        For reference in this thread: I just drew up the circuit I plan to drive my similar 15/8w diode laser module from a 3v3 controller (esp32 based) .
                        I will use an optocoupler, I have some at home already; the basic circuit looks like:
                        The OutputLimiter resistor is probably being over-cautions, the 4n35 can take 100mA/30v, but the laser module might provide enough residual power on the PWM lines to make it a good idea.
                        (Edit; I just looked at my circuit, I refer to 'nagative' values, probably a faux-pas, not a typo.]
                        • Danalundefined
                          Danal
                          @EasyTarget circuit also looks quite good. More "standard" way in the digital world... 😉
                          • Danalundefined
                            Danal @yaman
                            @yaman Yes, your modifications to the values are correct. Solder it up, wrap it in tape, and give it a try.
                            yamanundefined 1 Reply Last reply Reply Quote 0
                            • yamanundefined
                              yaman @Danal
                              @Danal
                              here are the complete drawing between Laser ; header and the circuit
                              do I need to add anything else
                              • yamanundefined
                                yaman @EasyTarget
                                @EasyTarget
                                never mind it's only 10$ ☺
                                  EasyTarget @yaman
                                  Looks good to me; I was going to suggest a switch but I see you have that covered.
                                  • Danalundefined
                                    Danal
                                    Looks correct, and the values given will work with a Duet (expansion) at 12V or 24V.
                                    As with any project, verify as much as possible with a voltmeter or o-scope, every step of the way.
                                    • yamanundefined
                                      yaman @Danal
                                      @Danal
                                      @EasyTarget
                                      OK so after some work with solder
                                      the circuit not work exactly but after I make little change the Laser finally work 😇 😇
                                      youtube for Laser Test
                                      https://www.youtube.com/watch?v=1KxYv2g96GY
                                        EasyTarget
                                        AhHA! a 10V pwm input. Same as mine; when I was looking at this last year I'd noted that 10V pwm/analogue seems to be a bit of a standard in the laser world. It's common in many CO2 lasers.
                                        • hectorundefined
                                          hector
                                          Something like this would work?
                                          https://www.amazon.com/Voltage-0-100-Linear-Conversion-Transmitter/dp/B00U7GJDVO
                                          connected to a fan or heater, take the pwm at 24v and transform it to 0-5V DC
                                          • yamanundefined
                                            yaman @hector
                                            @hector
                                            thanks for you replay
                                            but this circuit will not work in my case because I don't have Fan 2
                                            fan 2 I use it for tool 2
                                            I have heater 6 -7 with 5v PWM
                                            https://forum.duet3d.com/assets/uploads/files/1570300649740-laser_cable_2.jpg
