    Add laser for duet2 wifi
    Laser Cutters
    5.0k
    • yamanundefined
      yaman @EasyTarget
      @EasyTarget
      thanks for reply
      II am Waiting for my shipping to arrive (right now in SHANGHAI, Arrival at outward office of exchange)
      and I wish you luck with your project with ESP32 ☺
      until it's arrive I want to know
      is there any specific command i have to add to connect the laser in config file ?
      • yamanundefined
        yaman @EasyTarget
        @EasyTarget
        so after Received the part and test
        it won't work
        it's just convert PWM to TTL ONLY
        the DC plug it's just for test the Laser If it work or not
        so we back to Square 0
        Right now I thinking to use mosfet Or make the the 74HCT02D
        • Danalundefined
          Danal
          I know you want to buy a circuit... nonetheless, you might want to try this, it can be built for a few cents, and no board:
          Note the original diagram shows 13V in. 24V in (from the heater 6 connector) will require NO changes.
          It also shows 3.3V out. For five volt out, change the 150K and 39K in the lower right to 100K and 100K.
          This is "old school" analog conversion. It will not make the signal any cleaner, but it won't make it any worse, either, in that nothing in that diagram has a limited switching speed.
          • yamanundefined
            yaman
            @Danal said in Add laser for duet2 wifi:
            thanks Danal for your Replay ☺
            I think this circuit is easy to build
            here you can see the change I make for heater 6-7
            EasyTargetundefined Danalundefined 2 Replies Last reply Reply Quote 0
            • EasyTargetundefined
              EasyTarget @yaman
              @yaman said in Add laser for duet2 wifi:
              it won't work
              I'm sorry for putting you off-course with this, I see what you mean about the DC power port being for testing; I'd assumed that was the principle power port, my apologies.
              Your values and @Danal 's circuit look much more suitable. And easy to source all the parts for.
              For reference in this thread: I just drew up the circuit I plan to drive my similar 15/8w diode laser module from a 3v3 controller (esp32 based) .
              I will use an optocoupler, I have some at home already; the basic circuit looks like:
              The OutputLimiter resistor is probably being over-cautions, the 4n35 can take 100mA/30v, but the laser module might provide enough residual power on the PWM lines to make it a good idea.
              (Edit; I just looked at my circuit, I refer to 'nagative' values, probably a faux-pas, not a typo.]
              Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
              PrintPy2024 to the rescue!
              MicroPython based; with simple wiring and and no custom PCB.
              yamanundefined 1 Reply Last reply Reply Quote 1
              • Danalundefined
                Danal
                @EasyTarget circuit also looks quite good. More "standard" way in the digital world... 😉
                • Danalundefined
                  Danal @yaman
                  @yaman Yes, your modifications to the values are correct. Solder it up, wrap it in tape, and give it a try.
                  yamanundefined 1 Reply Last reply Reply Quote 0
                  • yamanundefined
                    yaman @Danal
                    @Danal
                    here are the complete drawing between Laser ; header and the circuit
                    do I need to add anything else
                    EasyTargetundefined 1 Reply Last reply Reply Quote 0
                    • yamanundefined
                      yaman @EasyTarget
                      @EasyTarget
                      never mind it's only 10$ ☺
                        EasyTarget @yaman
                        Looks good to me; I was going to suggest a switch but I see you have that covered.
                        • Danalundefined
                          Danal
                          Looks correct, and the values given will work with a Duet (expansion) at 12V or 24V.
                          As with any project, verify as much as possible with a voltmeter or o-scope, every step of the way.
                          yamanundefined 1 Reply Last reply Reply Quote 2
                          • yamanundefined
                            yaman @Danal
                            @Danal
                            @EasyTarget
                            OK so after some work with solder
                            the circuit not work exactly but after I make little change the Laser finally work 😇 😇
                            youtube for Laser Test
                            https://www.youtube.com/watch?v=1KxYv2g96GY
                              EasyTarget
                              AhHA! a 10V pwm input. Same as mine; when I was looking at this last year I'd noted that 10V pwm/analogue seems to be a bit of a standard in the laser world. It's common in many CO2 lasers.
                              • hectorundefined
                                hector
                                Something like this would work?
                                https://www.amazon.com/Voltage-0-100-Linear-Conversion-Transmitter/dp/B00U7GJDVO
                                connected to a fan or heater, take the pwm at 24v and transform it to 0-5V DC
                                • yamanundefined
                                  yaman @hector
                                  @hector
                                  thanks for you replay
                                  but this circuit will not work in my case because I don't have Fan 2
                                  fan 2 I use it for tool 2
                                  I have heater 6 -7 with 5v PWM
                                  https://forum.duet3d.com/assets/uploads/files/1570300649740-laser_cable_2.jpg
                                  • Danalundefined
                                    Danal
                                    Sounds like that laser wants 10V in.
                                    Some want 5V (TTL), some want 10V. The two versions of the circuit above will work for the respective cases.
                                    • yamanundefined
                                      yaman @Danal
                                      @Danal
                                      @EasyTarget
                                      @T3P3Tony
                                      Thanks for your replay
                                      that what I find maybe the real test will be in G code file and let the machine work for hours
                                      but first I have to do some work at Firmware
                                      Right now I'm at Version 2.0.0-RC2
                                      so any Suggestions for good version work fine with 3dprinter and Laser ?
                                      • Danalundefined
                                        Danal
                                        I haven't personally tried laser, so can't comment on releases.
                                        I can say I've had very good results using the "latest", including release candidates.
                                          EasyTarget @yaman
                                          The latest release, always the latest.
                                          https://github.com/dc42/RepRapFirmware/releases/latest
                                          Duet makes upgrading super easy, there is no real excuse for not upgrading asap and when new releases come out. Currently it is 2.03.
                                          This is especially true if doing CNC machine control, Duet3D are pushing heavily in this direction at present and related features are appearing in each new release.
                                          If you want to throw caution to the wind, try the latest 2.0x Release candidate, but I would avoid the 3.0 series betas at this time for general users. Though the 3.x series will eventually bring even more CNC related feature goodness.
                                          • yamanundefined
                                            yaman
                                            Laser Engraving picture
                                            EasyTargetundefined 1 Reply Last reply Reply Quote 2
