Duet wifi print stalls
Hi Folks,
It's been some time since I first equipped my detla printer with duet 3d WiFi board.
I have run a number of successful prints however now I'm facing issues that I cannot resolve.Problem:
With longer or prints my printer suddenly stalls.
Previously I run prints overnight fine but now after 1h or 2h it stalls.
By stall I mean printhead stops moving (randomly) but heaters keep heating (OMG!). Web GUI shows printer state as "paused" but nobody paused the print...
When I hit Resume button only one axis moves. Sending G28 also fails as only one motor moves.Restarting via "emergency stop" or power cycle fix the problem.
Today I run 3 times into this issue and couldn't finish prints.
I have a M122 output from two last attempts:
5:48:31M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3S8-6J9DG-3S46S-TVJ3F Used output buffers: 1 of 20 (14 max) === RTOS === Static ram: 28476 Dynamic ram: 96392 of which 16 recycled Exception stack ram used: 428 Never used ram: 5760 Tasks: NETWORK(ready,272) HEAT(blocked,1248) MAIN(running,3548) Owned mutexes: === Platform === Last reset 03:00:42 ago, cause: power up Last software reset at 2019-10-22 10:50, reason: User, spinning module GCodes, available RAM 5840 bytes (slot 0) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 2.7ms, max retries 0 MCU temperature: min 35.1, current 45.0, max 45.4 Supply voltage: min 11.4, current 12.6, max 12.7, under voltage events: 0, over voltage events: 0 Driver 0: standstill, SG min/max 0/474 Driver 1: standstill, SG min/max 0/467 Driver 2: standstill, SG min/max 0/468 Driver 3: standstill, SG min/max 0/1023 Driver 4: standstill, SG min/max not available Date/time: 2019-10-26 15:48:27 Slowest loop: 251.58ms; fastest: 0.07ms === Move === Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 120, MaxWait: 3653980ms, Underruns: 18, 0 Scheduled moves: 138950, completed moves: 138949 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 Heater 0 is on, I-accum = 0.2 Heater 1 is on, I-accum = 0.3 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is doing "G1 X-53.272 Y19.900 E7.6444" in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 182.45ms; fastest: 0.08ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.21 WiFi MAC address 80:7d:3a:15:1e:1c WiFi Vcc 3.40, reset reason Turned on by main processor WiFi flash size 4194304, free heap 15880 WiFi IP address 192.168.5.110 WiFi signal strength -46dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 === Expansion === And second
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3S8-6J9DG-3S46S-TVJ3F Used output buffers: 3 of 20 (14 max) === RTOS === Static ram: 28476 Dynamic ram: 96392 of which 16 recycled Exception stack ram used: 436 Never used ram: 5752 Tasks: NETWORK(ready,328) HEAT(blocked,1248) MAIN(running,3540) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 02:07:55 ago, cause: power up Last software reset at 2019-10-26 15:49, reason: User, spinning module GCodes, available RAM 5760 bytes (slot 1) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 50.4ms, max retries 0 MCU temperature: min 26.4, current 43.4, max 45.7 Supply voltage: min 11.4, current 12.6, max 12.7, under voltage events: 0, over voltage events: 0 Driver 0: standstill, SG min/max 0/468 Driver 1: standstill, SG min/max 0/459 Driver 2: standstill, SG min/max 0/458 Driver 3: standstill, SG min/max 0/1023 Driver 4: standstill, SG min/max not available Date/time: 2019-10-26 19:05:23 Slowest loop: 104.33ms; fastest: 0.07ms === Move === Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 120, MaxWait: 215158ms, Underruns: 20, 0 Scheduled moves: 145400, completed moves: 145399 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is doing "G1 X47.940 Y-70.150 E3.9089" in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 52.86ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.21 WiFi MAC address 80:7d:3a:15:1e:1c WiFi Vcc 3.40, reset reason Turned on by main processor WiFi flash size 4194304, free heap 15960 WiFi IP address 192.168.5.110 WiFi signal strength -55dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 === Expansion === My system
Firmware Name: RepRapFirmware for Duet 2 WiFi/Ethernet Firmware Electronics: Duet WiFi 1.02 or later Firmware Version: 2.01(RTOS) (2018-07-26b2) WiFi Server Version: 1.21 Web Interface Version: 1.22.3 I thought it's an SD card issue and replaced it but again print failed.
I don't know how to find the root cause as currently I'm really nervous of leaving printer alone as when stall occurs heaters keep heating and print could burn after a while...
No additional errors occured.
Thank you for help
please update to the latest duet firmware and try again (2.04RC version as 2.03 has a bug with deltas)
also. did you follow dc42 suggestion to decrease your microstepping to the recommended x16 with interpolation?
@Veti yes
Ok I'll update to recommended firmware version and let You know.
The only thing that bothers me is that printer generally was working fine until yesterday so I wouldn't blame firmware in the first place as it looks very similar to SD card issues (but I replaced it and then same problem was encountered).
How about power supply? Undervoltage event should be visible in m122 command shouldn't it?
Shall I enable some additional debug verbosity level? (And how?)
@morf said in Duet wifi print stalls:
Ok i upgraded firmware to 2.04RC4 but it didn't solve my problems directly however with new firmware onboard when the "stall" occured in the Console window I got message saying that print was paused due to low voltage.
I replaced my power supply and restart the print.
So far it seems that this problem is gone and it was connected to faulty PS.
