    very low / nil extrusion in one corner of the print
    555
    • JoergS5undefined
      JoergS5 @Milan
      @Milan Maybe X motor became too warm (weakest of the 3 motors) and is damaged. Neodym looses magnetism when more than 80 °C.
      • JoergS5undefined
        JoergS5 @Milan
        @Milan If you configuration of the other thread is your current configuration, the current settings for the drivers is very low (only 800 mA in M906), so maybe your stepper is still intact and only too weak for X, firmware thinking you're finished in X and stopping extruding.
        • Milanundefined
          Milan
          The motors at normal temp, that rattling happening only in that region alone
          • Milanundefined
            Milan
            should I try increasing the current 800mA to 1000mA -1200mA, hope that helps
            • JoergS5undefined
              JoergS5 @Milan
              @Milan Your stepper should have a specification about current, then set according to https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Rated_current
              But check first whether the external drivers support the high current also.
              Nema 23 and Nema 34 have typically between 2.5 and 7 A current, but on the datasheet the correct current should be mentioned.
              • fcwiltundefined
                fcwilt
                One or more of the wires to the stepper may be poorly connected and movement into that area causes the connection to be intermittent.
                • Milanundefined
                  Milan
                  I've changed , but no change, uploading the video..
                  JoergS5undefined 2 Replies Last reply Reply Quote 0
                  • JoergS5undefined
                    JoergS5 @Milan
                    @Milan Can you please send an image of the printer in complete view (there may be printer type specific reasons like for a Delta) and your current config file?
                    • JoergS5undefined
                      JoergS5 @Milan
                      @Milan And one more idea: exchanging the driver/stepper between X and Y would show:
                      • if nothing changes, problem is with extruder, or filament stuck
                      • if problem moves to a different corner, the problem is with the X stepper/driver/configuration
                      • Milanundefined
                        Milan
                        Wow, wiring issue, one of the wire poorly connected..@fcwilt was right
                        now working well
                        Thanks a ton @JoergS5 JoergS5 and @fcwilt Fcwilt
                        • JoergS5undefined
                          JoergS5 @Milan
                          @Milan Nice to hear that you have the solution!!👏
