Request for variable acceleration(slower acceleration at higher speed)
I'm thinking the term acceleration might not be the best approach here.
Goals should be outlined:
- I want the printer to move as fast as possible where possible
- I want the printer to be careful in some areas where too much speed will cause quality issues
- I want to be able to adjust the settings to best fit my printer model to achieve #1 and #2
So this might be speed and/or acceleration change. It might be as simple as a dynamic implementation of the speed factor already present based on move complexity.
Jeff
A further point. This is already achievable in slicers to a certain extent by setting different max speeds for different areas. maybe the right answer is get slicers to have a "max velocity" as well as max speed.
Btw Shen - that is one solid looking printer (/cnc machine!)
Well that would be nice, unlikely to happen…but nice.
@(In)Sanity:
Well maybe unlikely to happen, depends on your slicer and how much coding you fancy doing
I think there are sometimes calls for implementing features in firmware that are best left to the slicer to achieve. This one is on the fence because it relates to the specifics of the machine, but slice3rs already make decisions about print speed/quality based on the area of the object being sliced.
@(In)Sanity:
Kind of a mixed bag really, if you have hardware/firmware that makes all slicers work that much better it's a win win. In the end you really want all printers to want to run your hardware, so firmware features can really help with sales. Just look at the mobile phone industry.
@bot:
I can't understand at all why accelerating fast, for slow moves makes sense. Maybe that is what deckingman is thinking. What is the point of variable acceleration, if not to improve visual print/surface finish quality? If the point is to improve surface finish, I don't see how accelerating FASTER during slow moves and slower during fast moves is going to help at all. This is why I proposed the opposite – which would be useful to everyone, including those with ballscrews instead of belts for motion.
Why would it be useful to accelerate faster during slow moves, and slower during fast moves?
In my case I don't get ringing when decelerating from under 60mm/s with high acceleration, but I do when decelerating from 100mm/s with high acceleration. However I don't get ringing when decelerating from 100mm/s with low acceleration. This probably caused by the resonance frequency of the printer? I'm sorry if I'm misleading, but I'm not trying to say high acceleration at low speed is the way to go. I only wanted a way to set this so we can adjust it according to our needs.
Thanks. Yes, I designed it to be a printer and cnc machine based on the tool head. It prints very nicely, but with the 6kg Y gantry the vibration is huge I had to put it in the basement.
Okay, I think we are all confusing each other. At the end of the day, we all seem to agree. Tony's conclusions seem best for now. Set your feedrate for the region as best as your slicer can. I agree with him that it would be nice if slicers could change acceleration on the fly. This would actually be very easy for it to do, though I'm not sure if acceleration change gcodes are executed in-time with the motion-planning. If not, this would be a good place to start for this: to allow the slicer to set the acceleration (and jerk values?) in real time.
I made small test, it looks like there is a small delay to the M201 command which changes the acceleration. I'm going to see if there is any command that would cause the M201 command to apply(as a side effect).
Update: Looks like adding a G92 command before the M201 command produces the correct behavior, at least for the simple test I made. I will run some variable acceleration test, as soon as I finish reworking my extruder/hotend assembly. -
Interesting discussion.
Update: Looks like adding a G92 command before the M201 command produces the correct behavior, at least for the simple test I made. I will run some variable acceleration test, as soon as I finish reworking my extruder/hotend assembly.M201 will not affect the acceleration of moves that are already in the move queue. If you want to insert M201 in a gcode file, put a M400 command before it to wait for all previous moves to complete.
I'm assuming this firmware is fast enough that the M400 wouldn't even be noticed , i.e. the queue will empty and fill again before the motors even have a chance to slow ?
Jeff
No, the motors will come to a standstill because the move scheduler won't know that a new move is about to arrive.
No, the motors will come to a standstill because the move scheduler won't know that a new move is about to arrive. However, I've thought about it some more, and I don't believe the M400 is necessary after all. The situation in which you get a delay is if you are printing from SD card and you send the M201 command from another channel e.g. the web interface.
Makes sense, so more or less the speed change from the SD card just falls inline with the normal queue and nothing else is needed. Got it.
Jeff
I was wondering, that, too. So if it's inline with the gcode, it will be picked up just like any other move gcode and put in the queue?
Also, would it be easy to implement a "dwell" term to the jerk rate? As in, a period of time in ms that would be waited after hitting the jerk rate, before acceleration begins? This might make it easy to tune the ringing out of corners while maintaining a high acceleration.
@bot:
That was exactly my point - well one of them.
Back to basic physics. The first derivative of position with respect to time is velocity. The second derivative is acceleration. So variable acceleration would be the third derivative - i.e the rate of change of acceleration. Now go look up the definition of the third term of position - I'll save you the time, it's variously known as jerk, jolt, lurch, or surge. This is what you want to introduce?
Ian, yes that would appear to be what is being asked for. but I am still not sure its required to maintain the desired velocity curve.
The velocity is actually the variable we are trying to control.
That is my point. The rate of change of velocity is acceleration and it should be linear for smooth motion. The moment you start varying it, i.e putting a curve on to it, you introduce jerk (in the physics sense). It is unavoidable.
A couple of simple illustrations. When you are driving your car and you break to a standstill, it may sop with jerk. Learner drivers do this all the time. Some of us adapt and just before the car actually stops we ease off the brake, very slightly (my wife doesn't and all the passengers nod their heads). You probably do it subconsciously but next time you are out driving, think about how you come to a stop. What happens is that as the breaks heat up, they become more efficient and the rate of deceleration actually increases for the same pedal pressure, so you come to stop with jerk. When you ease off the brake pedal ever so slightly, you maintain a linear deceleration and come to a smooth stop. It is very important to know that you are NOT slowing the rate of deceleration when you do this, otherwise you would never actually come to a stop at all, you are merely maintaining linear deceleration.
We see it in engineering all the time. Camshaft profiles are designed to give linear acceleration to the valve stem. When they don't, valves bounce off their seats instead closing smoothly. In extreme circumstances the torsional vibration will strip the teeth of the belts or pulleys and wreck the whole valve train. Have you ever driven a car with severe turbo lag? It's awful and another example of non-linear acceleration. Designers and engineers spend hours and hours designing throttle linkages so that you get nice progressive, linear response to the movement of the pedal. If they didn't you'd find either the first 1/16 of the pedal movement gave you half the acceleration and the remaining 15/16th gave you the other half (or vica versa) which would make the car un-driveable.
So having spent half a lifetime dealing with various manifestations of non-linear acceleration and deceleration, you can maybe begin to understand why I think it a bad idea.
If my driving had a jerk setting it would be around 150
It best start fast and stop sudden, I rarely have passengers.
