    G32 w BLTouch and Z-endstop
    750
    • jontek2undefined
      jontek2
      I'm used to G32 from Smoothie.
      Just tried G29 and it does the exact same as in the video..
      • fcwiltundefined
        fcwilt
        Did you create the deployprobe.g and retractprobe.g files?
        G32 has it's uses for bed leveling but for creating the height map used by mesh compensation (which deals with bed irregularities) you use G29.
        • jontek2undefined
          jontek2
          Thanks! I'll start using G29 instead.
          Yes, i've created the two files:
          Deployprobe.g
          M280 P3 S10 I1
          Retractprobe.g
          M280 P3 S90 I1
          • fcwiltundefined
            fcwilt
            So all is working now?
            • jontek2undefined
              jontek2
              No.
              I had the two files already and i'm getting the same result (as in the video) with G29.
              • fcwiltundefined
                fcwilt
                When I specified the area to be probed I had to take into account my Z-probe offsets.
                • jontek2undefined
                  jontek2
                  I've also done that, see the config above.
                  • fcwiltundefined
                    fcwilt @jontek2
                    @jontek2 said in G32 w BLTouch and Z-endstop:
                    Well you are cutting the X axis a bit close but I guess it's ok.
                    Clearly something is wrong as the probe is deployed while moving.
                    Do M401 and M402 work correctly?
                    • jontek2undefined
                      jontek2
                      The M401 did deploy the probe and M402 retracted it.
                      Any examples of how your BLTouch is configured?
                      Could I have wired it wrong?
                      • jontek2undefined
                        jontek2
                        Either there is something wrong with the wiring, however i doubt that since all of the commands are working.
                        Therefore it must be something wrong with the configuration.
                        What i've done is:
                        Wired the BLTouch
                        Added the two files
                        Added the following code:
                        M557 X5:170 Y5:170 S20 			; Define mesh grid
                        M558 P9 H5 F1000 T4000 X0 Y0 Z0          ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
                        G31 P25 X30 Y15 Z5.0                    ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                        Is there something i'm missing?
                        • fcwiltundefined
                          fcwilt @jontek2
                          @jontek2
                          Hmm...
                          You have X0 Y0 Z0 parameters in M558.
                          According to the docs they are obsolete so try removing them.
                          And if you are not using the most recent firmware upgrade and see if that makes a difference.
                          • jontek2undefined
                            jontek2
                            Thanks. There's seems to be an update to it in the latest firmware.
                            I just redid all of the wiring to the BLTouch and got it working 🙂 The crimping must have gone bad in one of the signal-wires.
                            But got some new errors:
                            Warning: Skipping grid point (0.0, 0.0) because Z probe cannot reach it
                            It should be able to probe at 0, 0 since the offset is 30 and Y.
                            • fcwiltundefined
                              fcwilt @jontek2
                              M557 shows X5:170 Y5:170 S20
                              Why is it now trying to probe 0, 0?
                              • jontek2undefined
                                jontek2
                                Ok, here's an update:
                                I've got everything to work with the BLTouch and my config now is the following:
                                M558 P9 H5 F100 T2000			; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed moves
                                G31 X30 Y15 Z1.688 P25			; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                                However i'm getting the following message when i'm trying to do a G29
                                 Error: G29: No valid grid defined for bed probing
                                My "Define Area for Mesh Grid Compensation" is the following:
                                Start coordinate in X direction: 0
                                End coordinate in X direction: 210
                                Spacing in X direction: 20
                                Start coordinate in Y direction: 0
                                End coordinate in Y direction: 210
                                Spacing in Y direction: 20
                                However, if try to enter G29 two more tries - it works. Is this a known bug or am I doing something wrong?
                                • fcwiltundefined
                                  fcwilt
                                  What happened to M557 X5:170 Y5:170 S20?
                                  • jontek2undefined
                                    jontek2
                                    170x170 was something i had in size from Smoothie.
                                    seemed to be something from an earlier firmware version.
                                    • fcwiltundefined
                                      fcwilt @jontek2
                                      I would put it back. It is taking into account the z-probe offsets, as it should.
                                      Though I would be inclined to use X5:165 and Y5:185 to keep the z-probe away just a bit from X and Y max.
                                      • jontek2undefined
                                        jontek2
                                        According to the documentation (https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe) the M557 commands is used for the Touch-Mi.
                                        • fcwiltundefined
                                          fcwilt @jontek2
                                          That is simply mentioned there because of the characteristics of that type of probe.
                                          M557 is used to specify the area to be probed for mesh compensation.
                                          From the docs:
                                          M557: Set Z probe point or define probing grid
                                          Parameters to define G29 probe grid (all values in mm)
                                          Xaaa:bbb Minimum and maximum X coordinates to probe
                                          Yaaa:bbb Minimum and maximum Y coordinates to probe
                                          Raaa Radius to probe
                                          Saaa Probe point spacing (RepRapFirmware 1.19beta10 and later also support Saaa:bbb)
                                          Pnn or Pxx:yy (RRF 2.02 and later) Number of points to probe in the X and Y axis directions (alternative to specifying the probe point spacing)
                                          • jontek2undefined
                                            jontek2
                                            Hmmm then why are there a function in the GUI for "Define Area for Mesh Grid Compensation"?
